Old 09-07-2019, 05:02 PM #1
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Purpose of lever panhard bar?
I'm sure original suspension angles is the answer, But with the small lift, and without longer sway bar links, can someone tell me what I'm experiencing vs. Level panhard and longer endlinks?
Is the rear suspension under slight tension instead of neutral right now?
gaber6 is offline   Reply With QuoteReply With Quote
Old 09-07-2019, 05:27 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
There is no tension with the panhard angle, simple geometry tells us the roll center of the rear axle/body is the exact center of the panhard bar, so raising the axle side mount with a panhard correction kit levels the panhard and increases the height of the roll center, and levels out the panhard. I've experienced the panhard correction kit and it does a good job of reducing sway when turning.
Leveling out the panhard either by lowering your suspension to stock angles or the panhard correction kit, can help with bump-steer. Your panhard bar is the only thing holding your axle side to side, and as your suspension articulates the panhard moves up and down. Even though the panhard is long, this still causes the axle to shift side to side which effects your steering when hitting bumps. Leveling the panhard will mean it can articulate further either direction before pulling/pushing your axle side to side. The further it is from level, the rate at which it pulls/pushes your axle will increase. For example with made up numbers, with the panhard unlevel by 4 degrees it pulls the axle 1/4" to the right but if it's unlevel by 8 degrees it pulls the axle 1" to the right. So level at ride height is ideal.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 09-07-2019, 05:34 PM #3
montijo505's Avatar
montijo505's Avatar
I recently installed the bracket to level mine out and noticed a big difference. Zim is correct in that there is less sway. The biggest difference for me was getting rid of the rear end float at highway speeds. Before when I hit larger bumps in the road the rear always had a weird floating sensation to it before it settled. That is now gone. For how inexpensive it is it’s a no brainer.
Old 09-07-2019, 05:42 PM #4
Thanks for the answers. That all makes sense.
bar , longer , neutral , panhard , suspension
Panhard Correction Kits for the 4th gen - fix that panhard bar angle! eimkeith 4th Gen T4Rs 109 01-08-2021 04:21 PM
Shift Lever Bushings Replaced! Lever is now TIGHT! BamaDrewski 3rd gen T4Rs 4 05-26-2018 06:22 PM
Panhard bar drop vs adj panhard bar Swimmerboy2112 3rd gen T4Rs 30 01-15-2018 04:29 PM
lever in front of rear air suspension broken. what does that lever do? (pic) Jclason.neuro1 4th Gen T4Rs 1 10-01-2017 01:34 AM
Purpose for this(need?) cbreze 5th gen T4Rs 8 01-19-2015 09:39 PM
