Old 05-13-2019, 11:05 PM #1
level0five level0five is offline
level0five is on a distinguished road
Is this rust as bad as it looks?
Hello beautiful T4R world. Newb here seeking advice. Looking at a 06 SR5 V8. It's well appointed, everything seems to be in great shape, and the belt, water pump was replaced recently. Was feelin great until they sent pics of the undercarriage. It's 500 mi away so one can't simply swing by and have a poke. Is it salvageable without cutting/welding or should I just let my love die and keep fishing? Any help is greatly appreciated
Is this rust as bad as it looks?-attach9133_20190513_182521[1]-jpg
Is this rust as bad as it looks?-attach9134_20190513_182527[1]-jpg
Is this rust as bad as it looks?-attach9135_20190513_182547[1]-jpg
Is this rust as bad as it looks?-attach9137_20190513_182806[1]-jpg
Is this rust as bad as it looks?-attach9138_20190513_182823[1]-jpg
Is this rust as bad as it looks?-attach9139_20190513_182838[1]-jpg
Is this rust as bad as it looks?-attach9140_20190513_182856[1]-jpg
level0five is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 12:18 AM #2
lj4r lj4r is offline
lj4r is on a distinguished road
Not at all. You should make sure all of the bolts are there the sway bar clamp bolt is missing. An hour or so with a wire brush and some por15 will work wonders. Phil
lj4r is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 12:52 AM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Attachment 334383
Attachment 334384
Attachment 334385
Attachment 334386
Attachment 334387
Attachment 334388
Attachment 334389
From the photos the rust doesn't look to be real bad....BUT there could be other rust not shown that could be bad, if the rest of the frame is about the same then it's worth at least going and getting a first hand look at it, you really won't know without seeing it in person and poking and tapping the worst areas with a big screwdriver or similar, if all is good and solid it will take some work (way more than an hour IMHO) to clean the frame to put some rust preventative on the frame.
I would try and get them to replace any severely rusted, missing or broken bolts...the "missing" bolt for the sway bar clamp is BROKEN off (the rest of it can still be seen in the threaded hole)and will need to be drilled out and a tap ran through the treads and then a new bolt installed, there could be other broken or frozen from rust that will need to be addressed in a similar fashion or if your lucky and can get them out without breaking them before replacing with new ones, the skid plate bolts will all most likely be rusted in.
2004 Limited V8
Old 05-14-2019, 06:58 AM #4
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
This is great advice, and I definitely agree that making the trip would be worthwhile before plunking down the balance, even if you just send an initial deposit to hold it. If putting a deposit, I would be sure an agreement was in place that you would be able to get your deposit back if the in person inspection was not satisfactory. Depending on the part of the country you are in, or the vehicle is in makes a huge difference, which you didn’t mention in the first post because that amount of rust, while normal for the age in parts of the country that use salt, would be a hard pass for folks living in places like AZ, CA, etc. where they aren’t used to seeing any, or very little corrosion. You also never mentioned price, or mileage which are also important deciding factors. If for example they were asking $10-$13k with that rust AND the miles were over 150k, then I’d say it would be a hard pass.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 08:34 AM #5
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
not bad at all!
hinmo24t is offline   Reply With QuoteReply With Quote
great , poke , salvageable , simply , swing
Any rust issues on Gen 5? Beach rust prevention. Fomer_FJ_owner805 5th gen T4Rs 8 09-19-2016 01:08 PM
Rust lojeff 4th Gen T4Rs 9 08-08-2015 01:23 PM
How much rust is too much rust? huntsman General Discussions 9 10-24-2011 11:24 PM
Has anyone in the rust belt had luck with a DIY rust inhibitor? MilesRacker 3rd gen T4Rs 5 10-17-2008 02:46 PM
Rust and rust prevention Thai Maintenance/Detailing 0 02-21-2007 10:58 PM
