Old 05-14-2019, 02:44 PM #1
SummitRunner SummitRunner is offline
SummitRunner is on a distinguished road
Flashing TPMS Light Fixed
I've had the flashing TPMS dash light since buying the 4Runner. I assumed it was a dead battery in the wheel sensor and just ignored the dash light.
Then I bought some new tires. After installation the shop owner spent about 20 minutes working in the driver's seat. I had no idea what was going on. When he finished he said that the TPMS sensor had probably been replaced in the past and that there were "multiple registrations" in the computer.
So the TPMS light was now off! I've never seen the dash with no lights illuminated
I pulled out of the shop and suddenly the vsc/trac lights light up
When I got home I did the zero point calibration, and now, for real, NO LIGHTS IN MY DASH
So if you're really good with OBD-2 you might be able to fix a flashing TPMS light like my tire guy did.
2004 4Runner Limited, v8, 4WD
Overlanding Travel App for iPhone
"Great things are done when men and mountains meet." -William Blake
SummitRunner is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 03:51 PM #2
L8Shift's Avatar
L8Shift L8Shift is offline
L8Shift will become famous soon enough L8Shift will become famous soon enough
L8Shift's Avatar
Since you mentioned registration of IDs...
Each TPMS sensor has a unique ID number that needs to be registered to the the cars computer system, for communications to be established.
To upload the TPMS IDs, a TPMS scanner (which connects to the OBD2 port) is the easiest way I know of to communicate this info to the T4R..
We have 5 TPMS sensors to include the spare tire..
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
L8Shift is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 07:34 PM #3
jabloomf1230 jabloomf1230 is offline
jabloomf1230 is on a distinguished road
Depending on how old your truck is, the batteries in the sensors may be dead and that is the most common cause of the TPMS light flashing. Autel makes a nice TPMS meter that can check the sensor state and reset the TPMS light in most vehicles:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
For $229 US, you are probably better off to find someone with one to test out your vehicle
jabloomf1230 is offline   Reply With QuoteReply With Quote
Old 05-14-2019, 08:25 PM #4
jonb2 jonb2 is offline
jonb2 is on a distinguished road
I purchased one of those about a year ago. Works great. Used it on a few different cars to read and also replace the sensors.
jonb2 is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 09:03 AM #5
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
Or buy a $35 cable and use techstream (as well as have sooooo much more capability) to reprogram TPMS ID's. Or remove sensors and short the lamp wire to ground at the TPMS controller.
blackoutt is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 10:35 AM #6
L8Shift's Avatar
L8Shift's Avatar
But can you scan the TPMS Sensors with that TechStream solution?
I use an Autel scanner, which can read TPMS sensor battery level, let alone being able to read PSI without touching the vehicle. I use that, and Torque Pro for DIY diagnostics..
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
Old 05-15-2019, 12:05 PM #7
blackoutt's Avatar
blackoutt's Avatar
Yes it is the Toyota software capable of reading anything the dealer can do!
Old 05-18-2019, 10:41 PM #8
L8Shift's Avatar
L8Shift's Avatar
I have no idea what the dealer Toyota Techstream can do...
So I am asking, can the Techstream solution you have, scan a TPMS sensor for PSI/IDs without connecting to the vehicle (OBD2 port)?
Just wondering?
I need to check sensor data on wheels not installed on any vehicle, every so often.
This is my Autel display, from scanning my T4R 315 mhz sensors.
Flashing TPMS Light Fixed-27418-jpg
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
Old 05-25-2019, 09:47 PM #9
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Mine blinked all winter. I just moved my BlueTooth mic in front of the light. As soon as it warmed up, it stopped blinking.
gaber6 is offline   Reply With QuoteReply With Quote
dash , flashing , light , lights , tpms
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
4WD lights flashing - fixed (I hope) cbelisle 4th Gen T4Rs 2 04-10-2018 10:43 PM
TPMS Light Randomly Started Flashing thirstyturtle 4th Gen T4Rs 20 05-02-2016 06:51 PM
TPMS Flashing imdav2u 4th Gen T4Rs 8 12-08-2014 02:46 PM
