Old 05-14-2019, 11:52 PM #1
Brian3676 Brian3676 is offline
Brian3676 is on a distinguished road
Sand dunes now steering wheel is not straight
Took my 08 4Runner to the sand dunes. I didnt hit anything or do any jumping, just played around on the dunes and trails.
When leaving I noticed my steering wheel was turned about 45 degrees when the truck is going straight. Drives perfectly straight, doesn't drift off, wobble or anything odd. Only issue is the wheel is turned 45 degrees.
Removed inner and outter tie rods, they are perfect, lower control arms are perfect (ball joints, bushings, they are straight), knuckles are reinforced with TC gussets, and all is good, no cracked welds and are straight.
Removed rear links/arms. All perfectly straight.
Checked steering rack and bushings, rack did not move and bushings are good.
I am suspicious something happened inside the steering rack, maybe skipped a tooth? But I dont know thats possible without breaking a tooth or something. Whatever happened is effected the overall steering, not just one wheel because as I said it drives perfect. I dont think the steering shaft splines twisted in the shaft coupler, the 12mm bolts that pinch it are tight and I dont see any cracks.
Anyone have this happen or got suggestion? The wheel was flawlessly straight when I left for the trip.
Brian3676 is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 09:09 AM #2
hinmo24t hinmo24t is offline
hinmo24t will become famous soon enough hinmo24t will become famous soon enough
happened to someone else recently im pretty sure!
hinmo24t is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 10:46 AM #3
JD914's Avatar
JD914 JD914 is offline
JD914 is on a distinguished road
JD914's Avatar
4th gens seem to be notorious for this. It used to happen to mine every time Iíd take it off road till my alignment guy really put some grunt into tightening the front end. Problem went away until I replaced my tie rods myself. The steering wheel went off again after my first excursion off pavement. I guess I didnít tighten them up quite enough.
Iíd say put everything back together and over tighten the tie rods.
04 V8 Limited
Lifted, lit, locked, protected
Coffee machine and crock pot equipped
JD914 is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 03:39 PM #4
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff will become famous soon enough
BackOff's Avatar
Real Name: Derek
That happened to me about the first of this month, avoiding a head-on in a corner.
Another crooked steering wheel
Not sure how tightening anything down is going to do anything.
It seems to be internal to the rack and pinion.
I even tried to 'force' it back the other way with a couple controlled braking turns to the other side...probably not the best idea, none the less it did not fix it.
That rack is $630 new OEM.
A few on RockAuto for much less.
Mine is dry, no leaks and still feels the same...no floaty loose steering feel or anything.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 05-15-2019, 06:05 PM #5
AuSeeker AuSeeker is offline
Real Name: Skip
AuSeeker is just really nice AuSeeker is just really nice AuSeeker is just really nice AuSeeker is just really nice
Real Name: Skip
Do you have a link for the new OEM rack for $630, the best I have seen is around $820.
2004 Limited V8
Old 05-15-2019, 10:53 PM #6
Well all it needed was an alignment. After I spent hours inspecting it, took it to a alignment specialty shop, he inspected everything. Did a standard alignment and itís good to go.
Old 05-16-2019, 12:37 AM #7
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
Dang the one i saw was for a 3rd gen.
RoyalSouth Toyota, Ebay.
I was just browsing around when i saw it so i guess i didn't look at the details close enough.
Looks like they have the OEM 4th gen for over a grand!
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 05-16-2019, 01:20 AM #8
If you want a quality oem remanufactured one give CVJ a call.
Old 05-16-2019, 02:25 AM #9
Real Name: Skip
Real Name: Skip
Here's the one I found.
Gear Assembly - Toyota (44200-35061) | Toyota Parts
2004 Limited V8
bushings , perfect , steering , straight , wheel
Steering wheel not always straight jman11788 3rd gen T4Rs 4 07-13-2016 12:09 AM
Took my new Trail to Sand Dunes (pics!) taylour 5th gen T4Rs 11 09-11-2012 11:28 AM
A day at the sand dunes jreiter 5th gen T4Rs 5 12-17-2010 05:39 AM
Great Sand Dunes are on FIRE! CSL Off-Roading 1 06-13-2010 02:04 PM
Silver Lake Sand Dunes racedirt1 Gallery 7 07-13-2009 11:34 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
