Old 05-16-2019, 11:49 AM #1
K-D-Runner's Avatar
K-D-Runner K-D-Runner is offline
K-D-Runner will become famous soon enough
K-D-Runner's Avatar
Best Toyota Shop in Phoenix, AZ?
Finally getting around to buying the Doug Thorley Shortie Headers, Magnaflow High Flow Cats, and CEL's from Jason of Burtman Industries.
Was hoping some other AZ runners could point me to a good Toyota shop or even just an exhaust shop you've had good experiences with in order to have everything installed.
The runner's registration is up at the end of this month, and I'm quite confident it won't pass with the headers in their current state. Plus Im just excited for the increase in power and gas mileage, and I've been driven crazy by the ticking.
Thanks in advance!
Sent from my Pixel 3 XL using Tapatalk
K-D-Runner is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 10:38 PM #2
0verland's Avatar
0verland 0verland is offline
0verland will become famous soon enough 0verland will become famous soon enough
0verland's Avatar
Go give Chris a call at Scottsdale Muffler & Automotive. They put on m DT headers and exhaust. Great work and fair pricing.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
Old 05-17-2019, 02:24 AM #3
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
Thumbs up
I have e-mailed Lopers Performance in Phoenix. I was Told they can do the Headers and Y-pipe No Problem. I will give them a Call about Price. I am going DT Long Tube, and DT Y-pipe. Then maybe Dirty Deeds Cat Back. So No Cutting or Welding. I will report back on there Estimate.
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 05-17-2019, 10:43 AM #4
K-D-Runner's Avatar
K-D-Runner's Avatar
I thought it wasn't possible to pass emissions here with the long tubes?
Old 05-17-2019, 01:07 PM #5
0verland's Avatar
0verland's Avatar
Available at your local automotive store. Spark Plug Non Fouler PN 42009 ($4.99)
You now need to drill out 1 of the non foulers using a 1/2" drill bit. When finished this is what it will look like.
Side by Side comparison of the original and now modified non foulers
O2 Sensor inserted in the modified non fouler
Second, unmodified non fouler now installed on modified non fouler
Original non fouler->Modified non fouler->O2 sensor
Fully installed one of my other vehicles, but I did the exact same with my DT setup.
You can use one longer non-fouler which is what I did after the first time I did this, just make sure it is the same diameter for the O2 sensor. Whatever route you go make sure you have a setup for both sides of the exhaust. They also have these on Ebay and other vendors, however they are usually $15+ for the same thing. Up to how much work you want to put in, if drilling is too much.
What this does is it moves the O2 sensor further away so a limited amount of exhaust gets to the O2 sensor, it is a VERY little amount that actually gets to the sensor but as long as it is considerably less than the primary O2 sensor then it wont cause a CEL.
2006 V8 Limited 4WD
Old 05-17-2019, 06:44 PM #6
K-D-Runner's Avatar
K-D-Runner's Avatar
So essentially you could just use the CEL eliminators that Jason Burtman sells and put those on the long tubes and it'll still pass emissions here?
Thanks again
Old 05-17-2019, 07:21 PM #7
0verland's Avatar
0verland's Avatar
Thanks again
Him, Ebay, or just make your own for cheap. Whatever you wanna do...
2006 V8 Limited 4WD
Old 05-17-2019, 09:32 PM #8
K-D-Runner's Avatar
K-D-Runner's Avatar
So you're gonna run no cats essentially? Are you worried about the smell at all? Or worried about getting a visual inspection during emissions testing and them seeing there's no cats?
Old 05-18-2019, 12:47 AM #9
Az4runnin's Avatar
Az4runnin's Avatar
All they have ever done is Plug it in. They have Never looked under it. As Long as No CEL's you should be Good.
Old 05-19-2019, 08:32 PM #10
K-D-Runner's Avatar
K-D-Runner's Avatar
Just a heads up for anyone in AZ in the future, Scottsdale Muffler and Automotive quoted me just $486 to install the DT Shorty headers and high flow cats on my '04. Including a free re-torque after 5-7 days! Sounds more than fair if you ask me, but thanks to some input from members on here I might be doing the long tubes instead.
Old 05-19-2019, 10:09 PM #11
Az4runnin's Avatar
Az4runnin's Avatar
Thumbs up
Very Cool. Hey man we should hook up and Wheel some time.
Old 05-19-2019, 11:23 PM #12
K-D-Runner's Avatar
K-D-Runner's Avatar
Yeah dude, are you on the AZ 4runners Facebook group?
Old 05-20-2019, 11:03 AM #13
codeman528 codeman528 is offline
codeman528 is on a distinguished road
Chiming in with a +1 for Scottsdale Muffler!
2005 V8 Sport Edition 4WD | Bilstein 5100 | OME 885 and 895 | TRD Pro Wheels | 265/70/17 Falken Wildpeak AT3s | USA Spec Bluetooth Audio | Rago Fabrication Molle Panel | Victory 4x4 Front and Rear Bumpers | BajaDesigns Squadron Sport Ditch Lights | Morimoto HID Retrofit
codeman528 is offline   Reply With QuoteReply With Quote
Old 09-25-2020, 01:37 PM #14
Az4runnin's Avatar
Az4runnin's Avatar
Thumbs up
I had to bring a vehicle down here from work for some muffler work. Chris the Owner is Very Cool. Gona talk to him about doing my headers when I get them.
Old 09-26-2020, 03:32 PM #15
0verland's Avatar
0verland's Avatar
Glad the recommendation is able to help so many. Scottsdale Muffler is hands down the best in the valley.
2006 V8 Limited 4WD
good , headers , runners , shop , toyota
good shop in Phoenix metro area?? rookyboy 3rd gen T4Rs 2 10-23-2013 03:20 PM
T-Tech shop in the Phoenix area? Phx994Runner 3rd gen T4Rs 4 01-27-2013 04:22 PM
Any recommendations on a shop in Phoenix area? Flor4 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-26-2011 05:18 PM
Off Road shop in Phoenix, AZ dyollp General Discussions 1 06-08-2009 02:29 PM
Phoenix Shop Recommendations?? TitaniumToy General Discussions 2 03-29-2009 12:54 AM
