Originally Posted by Seasparrow
Not sure if this helps, sorry if it doesn't. Only tube types I can find is on Urban runners. Always discontinued.
You said bolt and there are several. I attatched the diagram but you can use the link to go to the web page to make sure. The diagrams are selectable, this diagram is 612186-C. The vehicle entered into the parts menu was 2007 v6 4.0 4wd Sport Edition.
How are the limited and SR5 different, just asking ?
Some of the part numbers on the diagram need to be cross referenced using the list below the diagram (not shown). The rack in the diagram is listed as Bar. The main bolt that holds the foot down is 63230 42010 BOLT ASSEMBLY, REMOVABLE ROOF.
Hope this helps.
thanks ill look into it, its the main bolt. the limited and SR5 main bolt uses a 12mm to remove it, while the sport edition uses i believe a T-30. I'm assuming because of the design of the rail cover.
