Old 04-12-2019, 08:28 PM #1
nasdaqer nasdaqer is offline
nasdaqer is on a distinguished road
Too much frame rust to buy?
Long time listener, first time caller...
Planning on looking at a 2006 4 Runner tomorrow morning for my oldest boy. I asked the gentleman selling the truck for some pictures of the frame to see what we were dealing with rust - wise.
Obviously I’m no mechanic, but having owned 2 tacos and 2 4Runners, I’m hoping to get my boy into one.
Is this rust normal for a WI truck of this age? Should I pass? Seller wants around $9500 for the truck and it has 165k miles on it. Would appreciate the input!!
Too much frame rust to buy?-27edb94f-ab1b-4854-9d9e-cb90376cacc4-jpeg  Too much frame rust to buy?-48664b99-625c-4a92-9568-2600f06f7b5f-jpeg  Too much frame rust to buy?-fc9c9723-33a2-4691-9d43-7c36b1573cd2-jpg  Too much frame rust to buy?-6533ecbe-efd1-4bdf-b997-15647a8e24ca-jpg  Too much frame rust to buy?-626f20f0-c85b-4031-b814-5c77dfcef26c-jpeg  Too much frame rust to buy?-1c6d64e6-96ed-49a2-8731-e6125d625ac7-jpg  Too much frame rust to buy?-abc5cbee-01ef-4f1e-babd-7021753919d2-jpeg  Too much frame rust to buy?-fdd9c4da-22fa-4895-a22e-5c77a47c1a6c-jpg
nasdaqer is offline   Reply With QuoteReply With Quote
Old 04-12-2019, 08:30 PM #2
One last pic..
Too much frame rust to buy?-c69f1aa8-d821-4796-9823-e5f2bf9bdcdc-jpg
Old 04-12-2019, 08:40 PM #3
SwayzeExpress's Avatar
SwayzeExpress SwayzeExpress is offline
SwayzeExpress is on a distinguished road
A little heavy for the midwest - I bet hes on a gravel road. In the rural areas here it beats up the frame all summer and leaves it exposed all winter. If it's a good deal and not gonna be put through extreme stress itll do the trick but dont expect it to get better. Dont be shy to buy further from home - uship got me a samurai to Illinois from north Carolina for around 500. I guess I'm saying all SUVs near us are rusting like that OR going for a premium.
What's leaking in the last pic?
Good luck!
SwayzeExpress is offline   Reply With QuoteReply With Quote
Old 04-12-2019, 09:01 PM #4
4RunnerMexico 4RunnerMexico is offline
4RunnerMexico is on a distinguished road
Yeah, that's just to the level of too much... I'd pass
4RunnerMexico is offline   Reply With QuoteReply With Quote
Old 04-12-2019, 09:15 PM #5
Wow - so this is a hard pass at $9500? Again, I have to plead ignorance as I typically lease. I thought this would be a fun project vehicle to work on with my boy, eventually doing some modding. Also wanted something safe enough for him to drive his sister to school. I was going to go take a look at the truck tomorrow, but now I’m wondering if I should just pass.
Old 04-12-2019, 11:40 PM #6
Offer 7k, you'll get that in two years if you maintain everything assuming aesthetics are decent. It's not crazy for the midwest if you will leave it stock but any spending other than maintenance will be good after bad
Old 04-13-2019, 08:56 AM #7
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
I agree with the above poster, especially if the exterior body, paint, and interior is in good shape. Also make sure stuff such as the 4lo works! I’m sure you have read the countless threads dealing with that failing from lack of use, but if you weren’t aware, at least you know one more thing to check. That rust is about on par with what mine had when I bought it. I sandblasted the whole frame, then re-primed, and painted it so that it would slow down any corrosion, as well as making problem areas easier to spot moving forward. If you don’t have access to a sandblaster, or someone that can do it for you, a lot of guys have had luck just grinding down the rust spots, or cleaning them up with a powered wired wheel, and then re-painting, or coating with rust treatment coatings such as POR-15. If you end up buying that truck, I’d highly recommend doing something so the rust doesn’t continue, or you WILL eventually have holes. Once the outside is dealt with, then it’s a good idea to spray inside the frame with Fluid Film, oil, or some other internal rust preventative since it is boxed, and not accessible to blasting and painting.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 04-13-2019, 10:33 AM #8
Formidable's Avatar
Formidable Formidable is offline
Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light
Formidable's Avatar
Run for the hills. The above is beyond surface rust... No amount of rustoleum will fix this.
2002 Thundercloud | TRD Supercharger | TRD Headers | URD 2.2 Pulley | Toytec | Addicted Offroad | 4xinnovations | Icon | SCS | BRIDE
BUILD THREAD
Formidable is offline   Reply With QuoteReply With Quote
Old 04-13-2019, 03:44 PM #9
sumday sumday is offline
sumday is on a distinguished road
not a deal breaker for me. typical and prolly better than mine.
so far toyota has recalled sequoia, tundra, and tacoma frames. not banking on the 4runner frame recall but i think the chances are good they will.
sumday is offline   Reply With QuoteReply With Quote
Old 04-13-2019, 05:36 PM #10
subdued76 subdued76 is offline
subdued76 is on a distinguished road
Good reminder to keep engaging my 4Lo once and a while.
subdued76 is offline   Reply With QuoteReply With Quote
Old 04-13-2019, 05:59 PM #11
Last Man Standing Last Man Standing is offline
Last Man Standing is on a distinguished road
Around these parts Upstate, NY and surrounding states that is a vehicle that will sit until they lower the selling price to $6500+/-. I am no expert on frames so cannot comment. $9500 should have you around 100K miles or under and a cream puff cosmetically. Keep at it and you will find deals.
LMS
Last Man Standing is offline   Reply With QuoteReply With Quote
Old 04-13-2019, 09:57 PM #12
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Looks pretty typical for a 4runner that has been through 12 winters with salted roads to me. If you like the car otherwise, best bet is to have a mechanic check the frame out/ get it up on a lift and make sure there arent any points that are in danger of creating rot holes/ causing inspection problems.
I dont usually mess around with frame rust or any chance it could collapse or give out in an accident, but looks pretty typical in my experience
Old 04-14-2019, 09:04 PM #13
mikewhiskey's Avatar
mikewhiskey mikewhiskey is offline
mikewhiskey is on a distinguished road
Too much rust for my taste but the truck is far from falling apart at this amount. This amount isn't just unsightly though, it will make a lot of repairs and maintenance a pain. And the price for this particular 4Runner is a bit high imo.
mikewhiskey is offline   Reply With QuoteReply With Quote
Old 04-15-2019, 01:23 AM #14
mack10 mack10 is offline
mack10 is on a distinguished road
Wait, so you have owned 2 tacos and 2 4Runners and you are asking if this is OK? Did your other trucks have no rust at all? If you want to wrench on it everything is 10x more difficult and or structurally deficient. If you are planning on seriously modding as a project get a southern truck. I still drool uncontrollably every time I watch that Car Angel guy wrench on random Toyotas. Life would be perfect with only minor surface rust on your exhaust system.
mack10 is offline   Reply With QuoteReply With Quote
Old 04-15-2019, 01:39 PM #15
jcaino jcaino is offline
jcaino will become famous soon enough jcaino will become famous soon enough
Take a hammer to it and see how solid (or not) it really is. You can only tell so much from pictures.
That said, I would definitely walk at that price. If they're OK with knocking a few grand off (and providing your hammer doesn't yield any holes or soft spots) then I'd consider it if you have access to a lift and feel like doing some work to slow down the rust....
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
jcaino is offline   Reply With QuoteReply With Quote
boy , i’m , rust , time , truck
Frame rust someone tell me ho bad it is Arnezie 3rd gen T4Rs 26 04-15-2019 01:11 AM
Need Advice: Frame Damage From Accident and Frame Rust Whammy 4th Gen T4Rs 11 08-29-2018 07:46 PM
Frame rust M1911 4th Gen T4Rs 92 03-15-2018 01:52 PM
Frame Rust bergmerc General Discussions 3 11-25-2013 10:47 AM
Frame rust- too much? maltedbarley 3rd gen T4Rs 10 07-08-2012 06:11 PM
