Old 05-16-2019, 10:09 PM #1
capri_auto capri_auto is offline
capri_auto is on a distinguished road
How to purposely break off a weldnut?
I drilled out some broken skid plate bolts in order to retap. I butchered one on the trans skid. I drilled through the side of it somehow. Its the front, driver side, weldnut on the trans skid and there is a nice access hole right next to it. I want to break the whole weld nut off and install an M10 rivnut in its place. Any tips on how to break it off? I dont have an airhammer.
capri_auto is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 10:36 PM #2
CJFONNER CJFONNER is offline
CJFONNER is on a distinguished road
Once it’s drilled out a few strategic blows with hammer and punch should do the trick. Aim for where the welded nut makes contact with the frame. It should pop off pretty easily. I did the same with M8 rivnuts a couple years ago. Been holding up fine since...
CJFONNER is offline   Reply With QuoteReply With Quote
Old 05-16-2019, 10:41 PM #3
_chassis_ _chassis_ is offline
_chassis_ is on a distinguished road
Die grinder, dremel, or cold chisel.
_chassis_ is offline   Reply With QuoteReply With Quote
Old 05-17-2019, 04:29 PM #4
MikeinNH67's Avatar
MikeinNH67's Avatar
Usually a big hammer and chisel does the job.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 05-17-2019, 04:36 PM #5
Surf13 Surf13 is offline
Surf13 is on a distinguished road
I used a hammer and punch a couple of weeks back. Takes a couple of minutes, but works fine.
Surf13 is offline   Reply With QuoteReply With Quote
Old 05-17-2019, 07:38 PM #6
sharpie223 sharpie223 is offline
sharpie223 is on a distinguished road
My first choice would be a Dremel with a thin grinding bit, less likely to gouge out excess material than a full grinder. If there's no room for that, a cold chisel and hammer, aimed to work its way under an unwelded seam if there is one. If that fails, try a bigger hammer until it works
sharpie223 is offline   Reply With QuoteReply With Quote
Old 05-17-2019, 09:22 PM #7
Thanks will try a punch and BFH.
Old 05-20-2019, 06:07 PM #8
I ended up knocking 4 of the weldnuts out with a punch and hammer. The ones on the radiator support took a lot of persuasion bit I got them all out and put m8 rivnuts in using the bolt and nut method. Replaced the bolts with grade 8 flange bolts and applied anti seize. Good as new and all the bolts are the same now. Pain in the ass factor was high.... end result was worth it.
break , drilled , skid , trans , weldnut
Did You Break 4WD? 1engineer 5th gen T4Rs 84 05-27-2022 02:19 PM
What did I break? vthokie 3rd gen T4Rs 13 10-20-2011 06:01 PM
Purposely Ran My Truck Out of Gas KeatonMP 3rd gen T4Rs 25 07-22-2011 01:46 AM
hard break during 'break in' phase Fareastplaza 5th gen T4Rs 3 04-05-2011 12:16 PM
