Old 08-11-2019, 08:11 PM #1
Buckaroo93 Buckaroo93 is offline
Buckaroo93 is on a distinguished road
Steering Knuckle
Ok Guys...this is the inside and outside of the driver side steering knuckle. Can the gasket be replaced? As you can see, it is pretty much destroyed with the spring thingy about to fall out. The pics got rotated 90 deg to the left. Sorry.
Steering Knuckle-img_1137-jpg  Steering Knuckle-img_1138-jpg  Steering Knuckle-img_1140-jpg
Buckaroo93 is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 08:29 PM #2
montijo505's Avatar
montijo505's Avatar
Yes that’s just a seal that can be had from a few manufacturers. Pry it out, clean with brake cleaner and tap in the new one with a piece of 2x4 being gentle. Piece of cake if you already have it apart.
Old 08-11-2019, 09:16 PM #3
Where do I "pry" from? The outermost lip? Don't want to pry at the wrong place.
Old 08-11-2019, 09:27 PM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
It doesn't matter where you pry on it, the seal is bad so any damage you do to it doesn't matter, the steering knuckle is cast iron so it would be hard to damage it.
Where you want to be careful is installing the new seal, make sure it goes in evenly when you tap it in or it will get bent and you will have to get another.
2004 Limited V8
Old 08-11-2019, 09:28 PM #5
2uyrunner 2uyrunner is offline
2uyrunner is on a distinguished road
Mine were completely shot and I knew I needed to replace them. I grabbed the outer edge with a vise grip and just pulled it out. Took a little force but nothing too bad. I did the inner seals yesterday while I was in there to do my cv axles. The inner seal is part# 710573. Not sure about the outer part #.
2uyrunner is offline   Reply With QuoteReply With Quote
Old 08-11-2019, 09:42 PM #6
montijo505's Avatar
montijo505's Avatar
Rockauto get the Beck/ArnleySteering Knuckle-img_1893-jpg
fall , knuckle , pics , rotated , steering
Steering Knuckle Buckaroo93 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 08-11-2019 07:58 PM
Need help separating UCA and steering knuckle techoguy 4th Gen T4Rs 25 12-05-2016 11:13 PM
Steering Knuckle knothead 3rd gen T4Rs 9 06-24-2013 08:42 PM
Taco steering knuckle vs. 4Runner steering knuckle ryankmasuda 3rd gen T4Rs 6 08-27-2012 09:05 AM
Steering Knuckle seal BCfish 4th Gen T4Rs 1 06-16-2012 12:53 PM
