Old 09-21-2019, 06:54 PM #16
bsthe bsthe is offline
bsthe is on a distinguished road
Originally Posted by 0verland View Post
Just a heads up. I still have the factory Y Pipe with HFC cats welded on my DT header and Gibson setup and the fumes are pretty heavy, especially on cold start. So don't expect too much of the smell to be cutdown. If anything it were me I would just put in a resonator to cut out any drone depending on which exhaust setup you go with, just a thought.
Are you saying that you installed shorty headers, new cats, left factory y-pipe and downstream cats... and have heavier fumes?
bsthe is offline   Reply With QuoteReply With Quote
Old 09-22-2019, 12:46 PM #17
0verland's Avatar
0verland 0verland is offline
0verland will become famous soon enough 0verland will become famous soon enough
0verland's Avatar
No. I installed DT shorty headers, new hfc, stock y-pipe and Gibson y-pipe back exhaust. The Gibson has no cats, its a straight through exhaust with one resonator.
DT---->HFC---->Factory Y-Pipe---->Gibson Cat Back---->
The Gibson was installed prior to the headers so I don't know how much of a difference the factory exhaust will make.
So naturally without the factory exhaust after the y-pipe the fumes will be stronger than stock with headers. Hope this helps.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
Old 10-04-2019, 06:34 AM #18
fulltimervexplorer's Avatar
fulltimervexplorer fulltimervexplorer is offline
Real Name: Justin Doggett
fulltimervexplorer is on a distinguished road
Was you ever able to get the CEL to go away?
2008 Toyota 4Runner 4.7l V8, Toytec 3 inch lift, 285-70-17 KO2s plus alot more i dont wanna write out.
fulltimervexplorer is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 01:45 PM #19
ralphwiggums's Avatar
ralphwiggums ralphwiggums is offline
Real Name: Chris
ralphwiggums is on a distinguished road
Real Name: Chris
I'd also like to know if there is a solution to the CEL.
I put an order in (group buy) with Jason B and was told the spacers would prevent error codes being thrown.
If that isn't true, or if there is a certain installation procedure to follow, can someone verify please?
2003 4Runner SR5 V8
LED interior lights & dash light swap - 5th gen brakes with Power Stop rotors & calipers - Pioneer AVH-W4400 NEX with backup camera - General Grabber tires on 20" Limited wheels - Bilstein 5100 shocks & Icon springs - JBA UCA's - Spidertrax spacers - Shrockworks front bumper with Run-D LED floods - safari rack (removed)
ralphwiggums is offline   Reply With QuoteReply With Quote
Old 10-07-2019, 04:46 PM #20
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
Say Hello to my Lil Friend
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 07-20-2022, 03:14 PM #21
UP driver UP driver is offline
UP driver is on a distinguished road
DT headers O2 issues
Originally Posted by duffdog View Post
Just an FYI - I manufacture the mini cats which are made to solve this exact problem forever. The problem is that if you install spacers, your wires smash against the frame, so how do you get correct operation without anything sticking out and without using spacers? The solution is to machine a mini-cat that goes inside the exhaust that does not protrude at all AND contains legit carb compliant material. PM me for details.
Howdy. I know this post is from a while ago, but do you still do this? Thanks
UP driver is offline   Reply With QuoteReply With Quote
Old 07-20-2022, 11:58 PM #22
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Unfortunately I do believe that @duffdog has stopped making and selling the "minicats", I have mentioned him in this post so maybe he will reply and elaborate, but he may not since he doesn't visit the forum that often anymore.
2004 Limited V8
Old 12-13-2022, 10:47 PM #23
Greasy Mike Greasy Mike is offline
Greasy Mike is on a distinguished road
Solved the v8 header o2 issue. Cel, traction control & check engine light off!
After months of trial and error I finally got the check engine light, the ABS light and the track control lights to go off on my 2003 v8. Im posting this so hopefully you can learn from my mistakes. I bought the car with cracked exhaust manifolds and all the lights on the dash were lit up like a Christmas tree..
I got a set of Doug Thorrley headers from Burtmann-Industries. They took forever to finally get here due to the pandemic. Anyways I finally got them on and all I can say is buy a stud extractor socket from the auto parts store before you tear into it. I’m running a K&N intake, longtube headers, y-pipe and Gibson exhaust. NO CATS!
Now I was told to put spacers on all of the o2 sensors, front and rear. DON’T DO THIS! put the front ones in like normal and then put 2 spacers in on the rear. I got 2 strait ones from burtmann and then ordered 2 - 90` ones from Walmart of all places. You want size 18x1.5
I ended up buying all new Denso o2 sensors from Rockauto.com for a lot cheaper than the stealership and I also had to get a Toyota brand gas cap cuz the lady I got the car from bought one of those cheap ones from autozone. Also the previous owner tried to rewire one of the o2 sensors and did a crappy job. They just twisted the wire together and wrapped it in electrical tape. So after all that trouble shooting there was only one thing left to do..
I did a zero point calibration and started it up! Haven’t had a check engine code or traction control light since.
Anyways this literally took me an entire year to figure out working on it in my free time, but I hope this can help someone.
Greasy Mike is offline   Reply With QuoteReply With Quote
Old 12-14-2022, 07:41 AM #24
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is online now
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Glad you got the CEL cleared.
Just for reference so that people are not confused.
You are correct, do not put spacers on the forward most sensors that are installed in the headers themselves. They are Air/Fuel Ratio sensors, not o2 sensors, and have to be installed like the factory configuration with NO spacers. They need to be in the normal exhaust flow to translate to the ECU if the fuel trims are working properly in real time.
The rear sensors are installed behind your Catalytic converters, and are your actual o2 sensors. They let the ECU determine if the Catalytic converter is up to temperature, and burning off the excess hydrocarbons that don't get burnt in the combustion chamber. Hence the need for spacers or simulators, when running a vehicle with no CATS.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is online now   Reply With QuoteReply With Quote
Old 12-14-2022, 01:15 PM #25
awhitney1 awhitney1 is offline
awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about
Exactly, I used a 90 degree o2 simulators on the rear.
awhitney1 is offline   Reply With QuoteReply With Quote
back , cel , code , sensor , spacers
Long tube headers and O2 simulator vs $5 option Adoniram 5th gen T4Rs 16 02-16-2021 03:12 PM
2.7 long tube headers project_lean 3rd gen T4Rs 2 09-03-2016 05:33 PM
Long tube headers and nj inspection. slowteg97 4th Gen T4Rs 2 07-01-2016 06:49 AM
Long tube headers luvmyt4r 4th Gen T4Rs 5 05-12-2013 12:03 PM
FS: Long Tube Headers, Cat, Muffler, & o2 Sensor K_Labs Classifieds - buy & sell (no commercial ads please) 5 09-03-2008 03:45 PM
