Old 05-20-2019, 10:02 PM #1
ShaftedTwice's Avatar
ShaftedTwice ShaftedTwice is offline
ShaftedTwice is on a distinguished road
Suspension Clunk
I've been hearing a deeper "clunk" noise of what sounds like metal hitting metal on potholes and bumps. I don't know if it is also related, but I'm also hearing a very high pitched metal squeak on uneven roads - it just takes the smallest amount of unevenness to set it off. Even further, every now and then if I go at a speed bump too quickly, I'll hear a kind of "ping" just once that's rather loud.
I've removed my front sway bar completely, I've installed new front lower control arms with new bushings and ball joint, and I've tightened every front suspension part down to torque specs. Upper ball joints seem to have good rubber with no cracks, but without actually looking inside it's hard to say. When the front wheels are off the ground, I'm getting the tiniest amount of play, just barely making a tap noise when rocking from 12 to 6 o'clock. Could wheel bearings be responsible for all this noise? May be an indication of inner tie rod needing replacement?
The outer tie rods can rotate with absolute ease - but don't have play when pushing them up or down -- this is normal correct? I've been driving myself absolutely crazy trying to track down these noises.
2006 V8 Sport Edition 4WD
5100 Bilsteins / OME 885 / 895
TRD Pro Wheels / BFG KO2 275/70/17
Rola Roof Rack / Custom Drawer System
ShaftedTwice is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 11:24 AM #2
alextmullis's Avatar
alextmullis alextmullis is offline
alextmullis will become famous soon enough
I’ve replaced every front suspension component and still get it. Thought it was my bad axle and replaced that when I swapped my diff yesterday but it’s still there
alextmullis is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 06:30 AM #3
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
The usual suspects apart from those you mentioned
1. loose under carriage shield/skid plate
2. bad ball joints, usually upper arm
3. loose bolts rattling around in the frame
4. brake dust shield hitting wheel
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 03:53 PM #4
GLP's Avatar
GLP GLP is offline
GLP is on a distinguished road
GLP GLP is offline
GLP's Avatar
Once I thought I for sure had suspension clunk and it turned out to be front brake pad clunk. Try lightly pressing on the brakes when you go over the noisy bumps. If the noise goes away replace your anti-rattle springs and maybe add a second spring to the top pin.
-2004 4Runner 4WD Limited V8, Bilstein 5100s, Wheeler's T12 Rear Springs, GY Silent Armor 265/70-17
GLP is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 11:58 PM #5
Hmm, tried holding the brake on bumps, it doesn't seem to quiet the clunking. I think that I've honed the noises down to different areas though.
Sounds like the front passenger makes the big clunks, is there a good method to check whether or not the upper control arm has a bad ball joint? It doesn't seem to be hitting on the spring.
The higher pitched metal screech seems to be on the left side - maybe a bad wheel bearing or rear sway bar link. Going to be putting the car up and turning the wheels to try and replicate. I think I'll change the rear sway bar links and bushings regardless.
Gave some good tugs on every part of the exhaust, doesn't seem to be coming from a mount of a heat shield on any part of it.
Old 05-23-2019, 12:52 PM #6
jacob7071 jacob7071 is offline
jacob7071 is on a distinguished road
Skid plate maybe? I had a clunk a few months ago - turned out one of the front skid plate bolts had rattled its way out.
Houston, TX - 2007 2wd Limited Build Thread
Dobinsons 296/220 front and 505/705 rear, Graphite Tundra split spokes, 5th gen Tube Running Boards
Sold '02 Sport Edition
jacob7071 is offline   Reply With QuoteReply With Quote
Old 05-23-2019, 05:06 PM #7
jscott6's Avatar
jscott6 jscott6 is offline
Real Name: Scott
jscott6 is on a distinguished road
jscott6's Avatar
Real Name: Scott
repalced xreas with Bilsteins and no more clunk
I had the 2 different sounding clunks, depending on the type of bump I hit. I had it looked over a couple of times and no one could find an issue that would cause any clunk. Then the right front shock started leaking, so I removed the XREAS suspension and replaced with Bilsteins and no more clunks of any kind.
jscott6 is offline   Reply With QuoteReply With Quote
Old 05-24-2019, 03:25 AM #8
pahaf91 pahaf91 is offline
pahaf91 is on a distinguished road
I had a "ping" noise in my 4runner after installing new lower control arms and getting alignment done.
turned out to be loose bolts on the front lower control arm bolts.
pahaf91 is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 07:34 PM #9
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
When mine stops clunking is when I'll worry. That means whatever is clunking finally failed.
gaber6 is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 03:00 AM #10
theoutbackdream's Avatar
theoutbackdream theoutbackdream is offline
Real Name: Matt
theoutbackdream has a spectacular aura about theoutbackdream has a spectacular aura about
Real Name: Matt
Video might help. Wheel bearings wouldn't make a clunk/squeak sound unless they are fubar'd, and at that point you should really feel it. Wheel bearings would cause a grinding sound.
If there's play, try isolating where the play is coming from. FWIW, my UCA boots looked fine on my driver side, with minimal cracking on the pass side, but upon further inspection, they were loose and caused clunking/squeaking sounds, along with the drivabilitly of the car changing from bumps.
Could be these too:
1. The top hat/strut bushing could be worn
2. Loose Strut nuts
3. Loose top hat bolts that mount the top hat to the frame
2007 Limited V6 4WD Build Thread
Find me on Instagram @t4r_explorer
theoutbackdream is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 07:28 AM #11
DZNUTS DZNUTS is offline
DZNUTS will become famous soon enough
Lower control arm ball joints or outer tie rods
1995 ECR33 GTS-T (sold)
1990 s13 coupe TONS of work
2005 4Runner Sport V8
DZNUTS is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 11:50 AM #12
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Also check the LCA adjustment bolts. Make sure they're torqued to 120 or so ft-lbs. If they're only at 50-60 ft-lbs or so the bushings will slip a bit as load changes and cause a clunk.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
amount , click , front , suspension , tie
Front suspension clunk settytb 4th Gen T4Rs 23 06-04-2019 07:17 PM
Suspension clunk after strut replacement. tstead60 4th Gen T4Rs 3 06-26-2014 11:11 PM
Front end suspension clunk PNWRunner 3rd gen T4Rs 8 02-24-2014 12:43 PM
Suspension (clunk) teneck31 4th Gen T4Rs 17 03-17-2013 06:44 AM
Suspension clunk? Bskelton 4th Gen T4Rs 16 11-01-2012 06:50 PM
