Old 05-21-2019, 10:40 AM #1
AceSpades AceSpades is offline
AceSpades is on a distinguished road
upgrade transmission cooling
Looking into upgrading the cooling for the V8 auto transmission, im going to be towing a 2500lb boat + cargo and family of 4 up Big Bear mountains in SoCal, which is a pretty steep incline and for long periods of time.
Before getting into additional cooling, what are your thoughts on bypassing the flow to coolant radiator? Are they known to be common failure points on 4Runners? The thought of a failing radiator mixing coolant with transmission oil is quite scary, and the Nissan guys are well aware of this common problem on Frontiers and Pathfinders, so id like to be cautious in this area
Options for additional cooling:
-replace original with larger cooler - any Brand /Model suggestions?
-keep original and add secondary oil cooler?
-water mist spray the oem cooler - I do this on my Ford V8 and works great! Im contemplating to go this route especially since i already have the hardware... Here are some pics below, its a pieced together kit and a custom bracket i made with scrap material laying around
AceSpades is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 11:32 AM #2
MT Runner's Avatar
MT Runner MT Runner is offline
MT Runner will become famous soon enough
MT Runner's Avatar
I donít know that adding an additional cooler would be necessary. From my understanding, the one you have pictured is already basically a second cooler. The tranny fluid line goes from the tranny to the bottom of the radiator first through a built in cooler there, then out to the auxiliary one, back to the tranny.
Iíve never heard of anyone having issue with a failing radiator mixing fluids on the 4Runner, but doesnít mean it hasnít happened. I just donít think itís a common issue.
Iíd say replace the stock cooler with a bigger unit and then add that water mister if you already have the parts and know how to install it. That should be plenty.
Iíd rather have more protection than less when it comes to transmission cooling too, but youíre well under half of the rated towing capacity, you should be just fine.
The only other thing Iíd recommend is to get a scangauge or something similar so you can actually monitor those temps in real time.
2005 SR5 V6
URD headers and MAF Cal
AFE Intake
Dobinson, JBA UCAís, 255/75R17 KO2ís, Level 8 MK6 wheels
MT Runner is offline   Reply With QuoteReply With Quote
Old 05-21-2019, 01:43 PM #3
Correct, it is well under the towing capacity, however Big Bear Mountain hills are very steep and go for long periods of time on top of 95į+ weather with the AC running and family of 4 with baggage, and boat. I cooked the transmission oil in my Expedition many years ago when i wasnt aware of how critical transmission fluid temps were. The 2nd time around i installed the water spray mist on it and was armed with Torque Pro app to monitor fluid temps, the water mist kept trans temps happily below 212į. That SUV has now been sold but i kept my water mist creation, and im debating which route to take for the 4Runner as we're planning on going again this July
Old 05-21-2019, 02:59 PM #4
MT Runner's Avatar
MT Runner's Avatar
I totally understand. I have the V6, so it only came with the cooler thatís inside the radiator. I added an aftermarket cooler and the scangauge to monitor it all.
I tow a roughly 3,500lb camper a few times a summer around MT and hit some steep and/or long hills and passes and Iíve never had the temp go above 225 while going up one of the hills.
I just think with a new, bigger cooler and then your misting gadget youíll be fine.
2005 SR5 V6
AFE Intake
Old 05-22-2019, 09:40 AM #5
KBToys KBToys is offline
KBToys is on a distinguished road
I think the 3rd gen 4runners had the issue with the transmission cooler cording in the radiator but haven't heard about the 4th gen
KBToys is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 10:37 AM #6
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
HD High Performance Radiator, FJ Cruiser, 4Runner, Tacoma 4.0L V6 - Underdog Racing Development
Why not just cool everything better?
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 11:24 AM #7
Chubbypanda Chubbypanda is offline
Chubbypanda will become famous soon enough
On my 3rd Gen I upgraded my radiator cooler and added a transmission cooler. I didnt bypass the transmission at all.
Maybe replace your radiator to a larger radiator and replace your transmission cooler to a larger one. Then run them in tandem from radiator to transmission cooler and back to transmission. After that add the mister.
Chubbypanda is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 10:17 AM #8
KIKNROX KIKNROX is offline
KIKNROX is on a distinguished road
What was the final Verdict on this? I'm running an 07 4th gen V6 2WD and towing at my max at 5,000lbs with Vehicle trailer and race car. The V6 didn't come with the external cooler to begin with. So going to add that.
Saving up for upgraded radiator:
BladeRunner Street Series Radiator | aFe POWER
Would also be interested in that water sprayer as well...
KIKNROX is offline   Reply With QuoteReply With Quote
Old 08-30-2022, 12:17 PM #9
apv97 apv97 is offline
apv97 is on a distinguished road
What's the verdict on this? I have a 2004 V8 4Runner and am towing about 6000 lbs over the Rocky Mountains at up to 11k in elevation, so was strongly considering upgrading my stock transmission cooler to this B&M one.
Has anyone done this? I saw lots of installs on the V6s (which don't have a stock cooler). Is upgrading to B&M on the V8 as simple as plug and play with the existing hoses and brackets?
apv97 is offline   Reply With QuoteReply With Quote
Old 08-30-2022, 04:58 PM #10
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of Bluesky 07 has much to be proud of
Bluesky 07's Avatar
Semantics perhaps, but I believe V6s (with the tow package) don't have a stock external cooler.
Bluesky 07 is offline   Reply With QuoteReply With Quote
coolant , cooling , oil , radiator , transmission
Transmission cooling options JRZEE2000TR4LTD 3rd gen T4Rs 56 06-28-2016 11:34 PM
Transmission Cooling System Joshua.O.Brown7 3rd gen T4Rs 5 05-27-2016 02:12 PM
Transmission cooling hose specs PCF4runner 3rd gen T4Rs 7 11-15-2015 10:29 AM
Possible transmission upgrade 2big4arunner 4th Gen T4Rs 12 01-08-2013 03:31 AM
Transmission Cooling AlexJet Engines / Suspension / Wheels / Tires / Audio / Accessories 10 06-12-2006 04:33 PM
