Originally Posted by ZebRuaj
Anyone know where our heater core is at? I've seen that be the cause in other cars.
Soaked passenger side is usually a clogged AC condenser line.
Originally Posted by rpete
I checked under neath and didn’t see anything hanging or any obvious spots where it could be coming in from. Definitely seems like it’s got to be coming up from underneath somewhere though because everything higher is dry.
The heater core and AC evaporator are both in the same enclosure in the passenger's side of the dash against the firewall, the cabin air filter is on top of the enclosure.
rpete have you or the previous owner if you haven't owned it that long ever had the windshield replaced?
If so and they didn't install/seal it correctly it can leak down inside the A pillar and it hard to detect/see unless you pull the side panel off, several members here have had this issue after a windshield replacement.
Pull the lower side panel under the dash off and have someone use a water hose to flood that side of the windshield and see if you can detect the possible leak down the A pillar.
