Old 05-22-2019, 03:17 PM #1
WiscoRunner's Avatar
WiscoRunner WiscoRunner is offline
WiscoRunner is on a distinguished road
Breaking bolts while removing skid plates
Looking for some advice or options for reattaching my skids. I hit every bolt with PB Blaster etc for the last week and yet almost every bolt has snapped off. Just looking for options to:
a) reattach the skids
b) removing busted bolts
c) I've got two bolts "loosened" but they just spin. Started raining yesterday when I got to this point so I couldn't get in there to far to see what exactly is happening. The two bolts that are spinning seem to hold the rear portion of the front-most skid and the front of the middle skid.
The bolts that snapped, barely took any force at all with a hand ratchet. I honestly thought I just broke them free until the head came down in my socket...
Thanks!
2007 Blue SR5. 2.5" suspension lift. Coastal Offroad front bumper. Verein Deutsch Drahthaar "Ida" co-pilot.
WiscoRunner is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 03:38 PM #2
L8Shift's Avatar
L8Shift L8Shift is offline
L8Shift will become famous soon enough L8Shift will become famous soon enough
L8Shift's Avatar
I only needed to replace a few, so I used riv nuts.
I heard Plus Nuts hold better.
Lessons Learned: Rivnuts Vs. Plusnuts - Points Unknown
2007 T4R Sport V8 4WD, 145K, Seat Warmers, Pioneer NEX
2007 T4R Limited V8, 4WD, 181K, OME 2"
2014 GX 460 Premium
1997 FZJ80 OME 2.5"
2006 T4R Limited V8 - R.I.P.
L8Shift is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 04:05 PM #3
ZebRuaj's Avatar
ZebRuaj ZebRuaj is offline
ZebRuaj will become famous soon enough
ZebRuaj's Avatar
Yay. Another rust belt buddy.
I'd just snap them all off, then drill and tap new threads in and use new bolts.
And apply liberal amounts of anti-seize.
07 T4R Sport Edition V6 4x4
ZebRuaj is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 11:41 PM #4
Antoddio Antoddio is offline
Antoddio is on a distinguished road
Zip ties and move on with your life. They work great.
Antoddio is offline   Reply With QuoteReply With Quote
Old 05-23-2019, 02:16 PM #5
Formidable's Avatar
Formidable Formidable is offline
Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light
Formidable's Avatar
Pick up an M8 x 1.25 helicoil Kit, Tap wrench AND appropriate drill bit. I think it’s 21/64” but you will need to verify. Spent a weekend drilling out broken bolts and fixing the threads. Not fun. Only good news is the threads are now stronger than stock. USE EYE PROTECTION. Only thing worse than drilling out bolts is a corneal abrasion from drilling out bolts.
https://www.amazon.com/dp/B0002SREP4..._7vU5Cb9XGCTHM
Breaking bolts while removing skid plates-e1cd4936-5902-45ae-b2b5-82747261ce00-jpg  Breaking bolts while removing skid plates-560fe198-c9c8-4e50-96f2-7bede2edfc91-jpg
2002 Thundercloud | TRD Supercharger | TRD Headers | URD 2.2 Pulley | Toytec | Addicted Offroad | 4xinnovations | Icon | SCS | BRIDE
BUILD THREAD
Formidable is offline   Reply With QuoteReply With Quote
Old 05-23-2019, 05:56 PM #6
capri_auto capri_auto is offline
capri_auto is on a distinguished road
The welds broke on the nuts in the frame for the ones that are spinning. Grind the heads off or use a cut off wheel. Drill out the broken bolts. The metal is soft so a good drill but makes quick work of the job. Do not use an "easy out"! Once you drill out the bolts use a punch and hammer to bust the weldnuts off and install plus nuts or rivnuts. I used m8 rivnuts this past weekend and installed all new hardware.
capri_auto is offline   Reply With QuoteReply With Quote
Old 05-24-2019, 09:16 AM #7
blackjackck's Avatar
blackjackck blackjackck is offline
Real Name: John
blackjackck will become famous soon enough
Real Name: John
Hope this helps
https://www.top4runners.com/ja/2007/skidbolts.html
2008 V6 4x4 Sports Edition / Build Thread/ FJ Off Road Package, 265/70/17, 2012 FJ Wheels, Husky Liner, LED bulbs, Spare Bumper -current////// SOLD Past vehicles:1996 V8 Landcruiser Rebuilt; 1988 Jeep Wrangler- 2 inch lift with 33' tires; 1976 Jeep CJ 7 (inline 6) - Frame off restoration
blackjackck is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 04:06 AM #8
50zach 50zach is offline
50zach is on a distinguished road
Had my front bolts snap right off after soaking in PB blaster for days. Metal zipties are my best friend as of now
50zach is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 08:50 AM #9
jcaino jcaino is offline
jcaino will become famous soon enough jcaino will become famous soon enough
I had a few snap off when removing the factory skids - was planning on using nutserts/rivnuts, but ended up being able to drill them out and re-tap the threads. Having it up on the lift was key to getting it done.
Started with a small drill bit and worked my way up basically one size at a time until most of the original bolt was gone, then ran a tap through it.
Used a liberal amount of antiseize on the new bolts.
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
jcaino is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 11:41 AM #10
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
Drill out and retap for larger bolts.. get all quality stainless.. bath yourself and everything you love in anti seize.. every time you touch your skid plate
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 10:54 AM #11
Thanks for the input everyone. I've been tied up as far as time goes since I got all the fluids changed since getting the skids off. I'm hoping to get everything drilled out and plan on re-tapping and reinstalling the skids when I can do a full brake job here in the next week or two.
Anyone feel its worth maybe having the skids blasted and repainted while they're off or should I just get the major corrosion off and rattle can them with implement paint and call it good?
Old 06-05-2019, 11:35 AM #12
ZebRuaj's Avatar
ZebRuaj's Avatar
I've been wire brushing and topping off with rattle can on the skids as I see surface rust over the years. This spring, noticed a small fist size gap on one of the front skid corners from over winter. It finally thinned itself enough and gave out. Started looking at aftermarket solutions but I barely leave pavement.
Old 06-05-2019, 07:55 PM #13
Hit em with a wire brush n rattle can em. Not worth it to spend more on them, put it towards some aftermarket ones.
Old 06-05-2019, 08:08 PM #14
runnersT4R runnersT4R is offline
runnersT4R is on a distinguished road
+1 on the tap & re-drill solution. For the rust, I'd scrape off the big "bubbly crusty" rust & then rattle-can it. You don't need to get down to clean metal... those skids are plenty thick. There used to be a Rust-Oleum rattle-can of Rusty Metal Primer that did wonders for me back when I lived in the Rust Belt. Dunno if it's still avail but maybe a similar product. I used that for painting over body rust, left it primered-only for a year in snowy/salty winter roads & it did fine. You could optionally follow it with rattle-can black paint but I personally wouldn't bother.
runnersT4R is offline   Reply With QuoteReply With Quote
bolt , bolts , options , skid , snapped
Trd skid plate (kdss) plus rci Control arm skid plates barcainho 5th gen T4Rs 8 12-06-2017 04:30 PM
5th gen; RCI full skid plates/fuel tank skid LOCAL ONLY (LOS ANGELES) madlib For Sale: T4R Items 3 02-27-2017 03:58 PM
Skid plates bolts Supra725 3rd gen T4Rs 6 08-21-2012 03:19 PM
anybody know where i can find top plates and bolts clemsonxplorer 4th Gen T4Rs 0 10-03-2010 09:48 PM
bolts for license plates dave4242 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-04-2003 05:09 AM
