Old 05-22-2019, 06:05 PM #1
Got2xlr8 Got2xlr8 is offline
Got2xlr8 is on a distinguished road
Retrofit 5th Gen Vented Seats
Thinking of trying to put 5th Gen Vented Leather in my 4th, I have a line on a color matched interior. I have located the part number for the seat temp controller (84752-35010) other than needing a wiring harness, do you think this could work?
2017 Nightfall Mica GX460 Luxury
VLEDs: Highbeam H9 MicroEvolution 3500lm | Reverse | Spidertrax | AFE Pro Dry S
2006 Nautical Blue Metallic Limited V8 w/ XREAS - Retired
Got2xlr8 is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 06:18 PM #2
ac1617 ac1617 is offline
ac1617 will become famous soon enough ac1617 will become famous soon enough
Hell someone retrofitted BMW E90 seats into a 3rd gen 4runner so anything is possible.
ac1617 is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 06:37 PM #3
Called the yard they are including the Controller, and the floor wiring harness. anyone have any idea if there would be any other module/controller behind the dash that would be required?
Old 05-22-2019, 06:43 PM #4
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
Heated seat wiring is simple, nothing to it. I'm sure this can easily be retrofitted into your 4th gen.
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 07:44 PM #5
big51810321 big51810321 is offline
big51810321 is on a distinguished road
Have to admit that I am curious about this
big51810321 is offline   Reply With QuoteReply With Quote
Old 05-22-2019, 09:52 PM #6
montijo505's Avatar
montijo505's Avatar
Following
Old 05-22-2019, 09:56 PM #7
anonymousgromers's Avatar
anonymousgromers anonymousgromers is offline
Real Name: Brody
anonymousgromers is on a distinguished road
Real Name: Brody
I’ve made a post similar to this asking if anyone did it but no one really knew if this was possible will be following this topic.
2004 Toyota 4Runner Limited 4.7L V8 | Practically stock | Gibson cat back exhaust
anonymousgromers is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 01:01 PM #8
After waiting 2 weeks for a call back I called them, no movement on pulling the switch or wiring harness. Rep suggested that for his guys to go pull the part they wanted 20% down on the full order. $400 to pull the switch and harness. without knowing it will/wont work.
Anyone know somebody with a 2014 with H/V seats who can take a pic of the back of the switch?
Old 06-04-2019, 01:23 PM #9
managed to snag a pic of the module from ebay,
looking at it, the switch is likely going to connect to a controller elsewhere, I don't think its feasible to continue.
Old 06-04-2019, 02:35 PM #10
mikewhiskey's Avatar
mikewhiskey mikewhiskey is offline
mikewhiskey is on a distinguished road
What about the airbag system? If you don't currently have airbags in your seats you obviously don't have to worry about integrating, if integrating is possible.
mikewhiskey is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 04:02 PM #11
Johns06yota's Avatar
Johns06yota Johns06yota is offline
Real Name: John Iannacone
Johns06yota has a spectacular aura about Johns06yota has a spectacular aura about
Given it has the wiring harness like you were saying it should be pretty simple. probably the easiest thing to do would look at the repair manual for your 4runner and the one for the new 4runner and find the wiring pinout. if all else fails a multimeter would make quick work of finding which plug does what. I'm still planning to swap in srt8 seats in mine but the ones I ordered at Christmas ended up being damaged in shipping so I just never got them and got a refund. The worst part of this is probably going to be figuring out the seat bracket situation. Also if those seats have airbags test the ohm rating of your current seat airbag to make sure you can plug it in. Otherwise you may need a resistor to mimic the toyota airbag OHM rating. All of which is in the repair manual
__________________________________________________ ___
If you are looking for custom 4runner parts, then look no further!
iannaconeautoaccessories.com
Johns06yota is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 06:42 PM #12
Cloud9's Avatar
Cloud9 Cloud9 is offline
Cloud9 is on a distinguished road
Cloud9's Avatar
But have you actually tried these seats in the 5th gen? I'm not really impressed with them. a lot of cars with these are more a gimmick but the Mercedes ones work well.
2019 TRD pro - S&B intake, Gibson Side Dual Catback black ceramic tips, Sprint Booster. lift coming
2006 4Runner V8 - Doug Thorley Headers/Hi-flow Magnaflow Cats, Gibson Catback Dual Exahust, Volant Air Intake, Sprint Booster, All from Burtman Industries
1996 Limited 3RD Gen, still going strong!
Cloud9 is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 06:56 AM #13
Terminator03 Terminator03 is offline
Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough Terminator03 is a jewel in the rough
Looking at that controller switch, it appears that they are heated and cooled seats, which means there is definitely a computer module that needs to be integrated to have full functionality out of them. I’m sure there would be issues integrating the air bags as well, unless you are really good with studying wire diagrams, and have all the correct modules. Just swapping the seats, if you want them for aesthetic reasons should be fairly straightforward, but getting the electronics working properly would make it more trouble than it’s worth for me personally. The only thing that would be fairly simple would be the seat heaters, especially if your truck already has the switches and wiring.
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
Terminator03 is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 08:44 AM #14
JVC8790's Avatar
JVC8790 JVC8790 is offline
Real Name: John
JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about JVC8790 has a spectacular aura about
JVC8790's Avatar
Real Name: John
Have you confirmed that these seats don't require some kind of CAN connection?
I swapped some Tesla seats into my Volvo a few years back and found that the passenger side was a straight 12v on off swap, but the drivers side controls operated off of CANBUS and wouldn't move or do anything without seeing a signal that I couldn't reproduce.
Just a thought! I hadn't even thought about retrofitting ventilated seats, would certainly make a difference in the summer!
2004 4Runner V8 Limited - TRD Exhaust, LED Interior Swap, Pioneer HU, Tacoma TRD Front Suspension, FJ Rear Springs, 10" + 32" Light Bars, Prius Shift Knob, 275/65R18 Falken Wildpeak, 18x9 Level 8 MK6 Et0, GOBI Ladder, 06-09 Headlight Swap, TOTALED NOV 2019, RESURRECTED APR 2020 Build Thread
1998 Volvo S70 T5 - Custom Airlift Suspension, BBS Nebula Wheels, Brada Seats, Engine Bolt Ons - StanceWorks Build Thread
2010 Subaru Forester 2.5X - Wifes Car
JVC8790 is offline   Reply With QuoteReply With Quote
Old 06-17-2019, 11:30 PM #15
RickF RickF is offline
RickF is on a distinguished road
Got2xlr8, curious what you've decided?
RickF is offline   Reply With QuoteReply With Quote
5th , gen , seat , temp , vented
Vented 5th gen hood - Extreme Mikeson 5th gen T4Rs 77 12-11-2017 02:44 PM
Leather seats too hot. Looking for vented leather seats. jjames34 General Discussions 8 07-23-2017 07:42 AM
05+ Xterra folding seats in 4runner, retrofit possible? mastee 3rd gen T4Rs 3 05-29-2013 06:31 PM
Retrofit memory seats SkipW 4th Gen T4Rs 0 02-05-2006 03:00 PM
vented hood milkfish Engines / Suspension / Wheels / Tires / Audio / Accessories 2 11-01-2003 09:58 PM
