Old 03-30-2020, 05:38 PM #1
chocker chocker is offline
chocker is on a distinguished road
Squeaking noise from front
Hi Guys,
just started hearing a squeaking noise coming from the front driver's side. It squeaks over bumps and when I turn the wheels to the left. It doesn't seem to do it when turning back right. I can't go under the truck as the weather is not favorable right now. I do see that there is clearance between the tire and the truck. I am running 265/70/17 tires which I never had any problems with. I have a 2.5" lift in the front (Daystar) which I never had any problems with. ( It is a couple of years old). I have videos of this but unfortunately I am not able to upload them to the site. Any insight would be greatly appreciated. BTW, I was thinking of getting sway bar bushing to start with even before this happened.
Thanks,
Mark
chocker is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 12:09 PM #2
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Originally Posted by chocker View Post
Hi Guys,
Thanks,
Mark
Squeaks generally either come from rubber or dried up balljoints. I would crawl underneath it and have someone turn the wheel back and forth. Listen for the noise and try to pin it down. Use a long screwdriver up to your ear as a makeshift stethoscope. Place it on each suspect part and see which one is making noise. You can also place your hand on it and might be able to feel the vibration that's causing the squeak.
Upper strut mounts, ball joints, tie rods are most common. Cheers
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 03-31-2020, 09:50 PM #3
Thanks so much, the weather is finally getting a little better so I can go under the truck. I will check the parts and see if I can pinpoint the problem. I will get back with my findings.
Thanks,
Old 04-01-2020, 12:45 PM #4
Well had a chance to look at it closer. It seems to be the lower ball joint. A little hard to pinpoint in that area. I will replace that to start with. Either way it's an original part that had been there for 13 years. No harm in replacing it.
QUOTE=Warwicke36;3465377]Squeaks generally either come from rubber or dried up balljoints. I would crawl underneath it and have someone turn the wheel back and forth. Listen for the noise and try to pin it down. Use a long screwdriver up to your ear as a makeshift stethoscope. Place it on each suspect part and see which one is making noise. You can also place your hand on it and might be able to feel the vibration that's causing the squeak.
Upper strut mounts, ball joints, tie rods are most common. Cheers[/QUOTE]
Old 04-01-2020, 12:48 PM #5
Anyone have a suggestion on a good quilty ball joint with good value.
QUOTE=chocker;3465965]Well had a chance to look at it closer. It seems to be the lower ball joint. A little hard to pinpoint in that area. I will replace that to start with. Either way it's an original part that had been there for 13 years. No harm in replacing it.
Upper strut mounts, ball joints, tie rods are most common. Cheers[/QUOTE][/QUOTE]
Old 04-02-2020, 10:26 AM #6
I just ordered some Moog balls joints (Lower and upper just in case) waiting for arrival.
Old 04-20-2020, 05:41 PM #7
Just received the Moog ball joints that are greasable. I see that the Moog K500017 lower ball joint has a different boot on it. It seems to have a slim boot instead of the balloon type OEM one. It covers the area but I was just wondering if anyone used this replacement and if so, did they just put it on or did they add the larger boot over it. I have attached the photo of the ball joint.
Thanks,
Squeaking noise from front-moog-lower-ball-joint-jpg
Old 04-20-2020, 06:11 PM #8
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
Might as well do the sway bar bushings while you're at it.
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 04-20-2020, 08:43 PM #9
It's funny you say that. I am waiting for the front and rear sway bar bushings I ordered. I am just worried right now that if I pull out the ball joint, will the replacement be ok even though the rubber boot is smaller.
Old 04-20-2020, 11:10 PM #10
I did some research and found out that the boot on the Moog was a newer boot and was to be used the same way as the original one with the bigger boot. I will try it.
Old 04-28-2020, 10:13 PM #11
Got the upper and lower ball joints and started the install. Started with the upper ball joint. Got everything undone except for removing it from the UCA. I saw that it was ready sloppy so it's time. Could not for the life of me press it out. The C clamp would not fit properly so I had a really hard time. I had to put it all back together and I'm going to bring it to the shop. I'll see what it sounds like after they are installed.
Old 04-28-2020, 11:18 PM #12
I banged mine off (hit the flat spot on the spindle) with the 3lb mini sledge lol.
Old 04-30-2020, 09:10 PM #13
When I started on the upper ball joint, it came free from the knuckle with no problems. Bang bang and it was disconnected. The problem was trying to press out the ball joint. I brought the truck to a shop. They got it done by torching it. They said that both ball joints were finished. The upper was so sloppy it was insane and the lower was making major noise when I tried to move it. All done, no more noise. So satisfying driving without noise.
Old 04-20-2023, 11:52 AM #14
810moto's Avatar
810moto 810moto is offline
810moto is on a distinguished road
810moto's Avatar
I got the same problem that just developed on tuesday.
so frustrating and embarrassing hahaha.
was the bottom ball joint what you had torched out and how easy was it overall?
2004 SR5 2WD,285/75 Nittos,RB-1.5"BL,K&N drop in,LED interior Ltg,12v mod,Debadge,Daystar lights,Optronics rear lights,FJ swap,Fog Light mod, All-Weather mats,ES swaybar bushings & end links,Spidertraxx,HCF delete,1/2" toytec spacer,2custom cargoboxes
810moto is offline   Reply With QuoteReply With Quote
Old 04-20-2023, 09:42 PM #15
Ida4runner Ida4runner is offline
Ida4runner will become famous soon enough
You need a press to get it out.
If you're doing this in your driveway I'd just get a complete lower arm with new a new ball joint and bushings, you'll be ahead in the long run and it's 100x's easier.
Ida4runner is offline   Reply With QuoteReply With Quote
front , noise , problems , squeaking , truck
Scraping/Squeaking Noise Coming from front end over 70 mph jgd99 3rd gen T4Rs 0 09-26-2016 05:14 PM
Squeaking noise from the Front achha64 3rd gen T4Rs 1 03-11-2015 11:18 AM
Squeaking noise from front of engine. Help!! Ble3Y Classic T4Rs 3 11-29-2010 11:28 PM
NV005-06 06/16/2006 Interior - Front Seat Track Squeaking Noise CBR_GUY_IA 4th Gen T4Rs 0 07-12-2009 09:42 PM
front end squeaking noise gilligan79 Problems & Warranty Issues 0 02-21-2008 08:52 PM
