Old 05-26-2019, 03:51 PM #1
drewj drewj is offline
drewj is on a distinguished road
Brakes touchy/grabby after hard braking
Hi All,
I have a 2005 SR5 that I bought new from the dealer. I've noticed this problem from time to time and have done some searching here but haven't seen anyone mention the same issue. It's been there since new, and I've since replaced rotors, calipers, etc. over the years but the truck still exhibits the same issue.
Problem: When I hit the brakes hard suddenly, but then release my foot from the brake, I can't touch the brake pedal without the brakes almost locking up. I have to lightly tap the pedal to come to a complete stop. When I take off again, it seems to be fixed.
The last time this happened, I hit the brakes a bit harder than usual but I was also on some very rough pavement (even rougher than normal NJ pavement - haha) and the brakes immediately grabbed as described above.
Anyone have this issue and if so, what was the resolution?
drewj is offline   Reply With QuoteReply With Quote
Old 05-26-2019, 04:36 PM #2
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
I have similar symptoms. I’ve assumed it’s the ABS system doing its thing.
Curious to hear people’s thoughts
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 05-26-2019, 11:02 PM #3
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
15+ year old abs technology. Mine sometimes cycles over rough pavement and a second or 2 past whatever bump I hit.
gaber6 is offline   Reply With QuoteReply With Quote
Old 05-27-2019, 10:48 AM #4
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Mine did the same thing over the Winter, hard panic brake when a knucklehead pulled in front of me followed by over-sensitive brakes...followed by vibration as the front passenger rotor overheated and warped.
Diagnosis: rubber brake hose collapsed internally, creating a 1-way valve which held the caliper pistons extended. When I found this I replaced both sides. The rotor was discolored black, piston boots on the caliper were cooked.
waypoint is offline   Reply With QuoteReply With Quote
Old 05-28-2019, 11:09 AM #5
Yeah, I think that's really what it comes down to. Just wanted to verify here though. Braking on rough pavement will trigger it every time.
Old 05-28-2019, 03:42 PM #6
New shocks/tires and suspension bits might help a little bit but it is likely the truck itself.
brakes , hit , issue , pedal , time
Grinding noise when hard braking LTDSC 4th Gen T4Rs 13 12-10-2019 07:47 PM
TRD pro unsteady under hard braking? GB-man 5th gen T4Rs 20 06-24-2017 06:33 PM
Touchy Grabby Brakes wmgcrowell 5th gen T4Rs 61 01-06-2017 04:10 PM
Hard Pull to the right under braking jsmith21 4th Gen T4Rs 18 07-14-2015 07:13 AM
Clunk after semi hard/hard braking NCrunner2012 3rd gen T4Rs 18 07-10-2012 12:04 PM
