05-28-2019, 03:08 PM
Installing Pioneer radio
Hello all,
I am planning to install a Pioneer FH-S701BS into my 2008
I had this in a 2001 and needed a wire harness for it in order to connect the radio to the existing connectors.
Is there a special wire harness/connector I will need to put it in the 2008?
edit
For my 2001 I had to get the Metra 70-1761 Radio Wiring Harness in order to install it
Reason: added info
05-28-2019, 03:31 PM
A few things to consider, steering wheel controls, do you have navigation, impedance of existing speakers (my 2004 has 2 ohm speakers), antenna adapters and more. Some of us have amplifiers some do not. If I can give you any help it is to know the entire job before buying.
Some places for info are Crutchfield: Car Stereo, Speakers, Home Theater, Pro Audio, 4k TV expensive but helpful. You can just shop using your year vehicle and you will learn about the different adapter harnesses. Youtube videos like YouTube just make sure you get the right adapters for your specific vehicle and not just the one in the video.
do a "search" in the 4th gen forums also, there is a lot of info.
There are adapter harnesses for the stereo, steering wheel, and antennas. I have zero knowledge of your existing stereo but these are questions that need to be answered.
use this webpage to input your vehicles specifics Pioneer FH-S701BS CD receiver at Crutchfield.com Click on "Does it fit your car".
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
05-28-2019, 03:44 PM
Awesome.
Thanks for the info.
My vehicle doesn't have steering wheel controls or amplifiers and no navigation stuff....just a basic Toyota stereo set up.
05-28-2019, 03:49 PM
That Crutchfield link was what I needed.
Thank you again.
05-28-2019, 05:22 PM
if the new 4runner is equipped with the standard radio, the old radio can be a plug and play, also youll be loosing the steering wheel controls. i use idatalink maestro sw for that, now for dash kit, if your car is the standard radio, metra 95-8202 is the dash kit for the double din.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
05-29-2019, 08:39 AM
Great
Thank you.
06-05-2019, 07:51 AM
Question if anyone knows.
I installed the Radio
And of course Toyota has the 2 antennas, so I had to get an adapter for the mini antenna and then connect the two antennas into a harness to plug into the radio.
For the most part the stations come in fine, but they are not as good/clear as they were with the factory radio.
I heard mention of the blue wire being connected somewhere in order to get better signals
What is that about?
Is there a better adapter to use for the mini antenna? Because when I put the adapter on the mini, it didn't feel like it seated quite right.
I used the SCOSCHE MDAB 1988-05 GM Micro/Delco Antenna Adapter to plug into a XCSOURCE SKAA-26 1 Male to 2 Female Auto Antenna Adaptor Cable
06-05-2019, 08:23 AM
Real Name: Dillon
Real Name: Dillon
The 4Runner antenna has an pre-amplifier built in the system, and your reception will be crap f you don’t hook it up. Hook up that lead to a switched power circuit...the new radio harness likely has a blue wire labeled “amp” or “power antenna” you can use for this.
06-05-2019, 08:32 AM
So that would be the Blue wire on the Metra wire harness to the Blue-White wire on the Pioneer harness?
06-06-2019, 01:40 PM
As a follow up
I did connect the Blue wire from the harness to the Blue-White wire on the Pioneer connector. That seems to have done the trick.
06-06-2019, 03:17 PM
Oh our 4runner has a amplified antenna? Which wire is that if I'm looking at the stock harness? Thanks!
2022 Toyota 4Runner TRD OFF ROAD PREMIUM
06-08-2019, 04:46 PM
Real Name: Dillon
Real Name: Dillon
It’s the blue wire in the stock harness.
06-08-2019, 06:02 PM
It will be the blue wire from the Toyota side of the harness, connecting to the Blue-White wire on the Pioneer side of the harness.
06-17-2019, 11:19 PM
I understand the blue-to-blue&white wire concept, but what about the two antenna inputs? Does anyone have a recommendation on an adapter (i.e. Y adapter or similar)? Thanks in advance
06-18-2019, 07:50 AM
You don't need to hook up both. Just hook up the one with the normal sized connector and let the other one dangle.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
