Old 05-29-2019, 12:39 AM #1
ad_robotics ad_robotics is offline
ad_robotics is on a distinguished road
4th gen remove lock/unlock buzzer
Done a bunch of researching and it seems that 3rd and 5th gen'rs have a key fob combination to change the buzzer volume. As far as I can tell, the buzzer volume on a 4th gen can only be modified via mechanic and would cost around $50.
How to remove lock/unlock buzzer on a 2005 4th gen 4Runner.
The buzzer is a piezo located in the back of the engine bay, on the driver's side, right under the hood support strut, on the inside of the wheel well.
Open the hood and locate the driver side hood support mounting point (1.)
Underneath that, you can see a wire going through a hole that leads to the front left wheel well (2.)
You need to take out the plastic ring (2.) (good luck). The buzzer is fastened to the inside of the wheel well by a plastic clip (4.), disconnect that by squeezing it.
Once you pulled the buzzer out (5.), disconnect it (6.) and set the devilish thing on fire *insert pitchfork emoji*. Seal the end of the clip (6.) with duct tape and fasten it to some of the adjacent wires.
2005 Limited V6 4WD
ad_robotics is offline   Reply With QuoteReply With Quote
4th , buzzer , gen , hood , wheel
Lock/Unlock Beep DBrockwell20 4th Gen T4Rs 23 02-10-2023 03:09 PM
Doors will unlock, but won't lock. dman328 3rd gen T4Rs 48 01-02-2019 05:13 PM
Help please door won't lock\unlock Jeffdrive4runner 4th Gen T4Rs 5 11-23-2014 07:59 PM
Unlock/lock Chime 34mod 4th Gen T4Rs 2 05-06-2009 12:36 PM
Lock/ Unlock Button goneyakin 3rd gen T4Rs 14 08-02-2008 01:18 AM
