Old 05-29-2019, 05:03 PM #16
ac1617 ac1617 is offline
ac1617 will become famous soon enough ac1617 will become famous soon enough
Originally Posted by derekdevasia View Post
I go 12,000-15,000 miles every oil change. I'm doing almost 95 percent highway commuting, never had an issue. Been doing this with Mobil 1 synthetic, and the OEM filter for nearly 150,000 miles. Just replaced my valve cover gaskets two weeks ago, and everything is sludge free and clean.
pushing 330,000.
Aside from having no sludge, were you able to verify there was no premature wear in the rod bearings? How about the cam lobes?
What about the oil? Were you able to verify the oil additive pack was still sufficient to protect your engine? How about verifying the oil still had a 30 viscosity and didn't sheer down to a 20 weight?
This is the danger of listening to posts on the internet or making blind assumptions that just because you haven't had any "issues" YET... doesn't mean you aren't causing premature engine wear by extending your oil change intervals past Toyota's recommendations. Oil and oil analysis is cheap, engine repairs are not. An oil analysis would be able to tell you if the oil's additive pack is still sufficient, any premature wear is happening (ex. excessive lead in the oil), and if your oil is sheering. I will never understanding blindly assuming you can extend your drain intervals by 7000 miles because you don't hear a knock from the engine yet just to save $18. Once you DO notice a problem it's too late.
This is not an attack on you derekdevasia but others should not follow your oil change regiment just because your engine hasn't blown up yet. That's as reckless as telling someone "It's been 200,000 miles since I changed my timing belt and I haven't had any issues yet. My wife's 02 has been pushing 250,000 miles on her timing belt without issues!"
ac1617 is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 06:13 PM #17
codeman528 codeman528 is offline
codeman528 is on a distinguished road
AMSOIL 5W-30 every 5k miles over here!
2005 V8 Sport Edition 4WD | Bilstein 5100 | OME 885 and 895 | TRD Pro Wheels | 265/70/17 Falken Wildpeak AT3s | USA Spec Bluetooth Audio | Rago Fabrication Molle Panel | Victory 4x4 Front and Rear Bumpers | BajaDesigns Squadron Sport Ditch Lights | Morimoto HID Retrofit
codeman528 is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 06:45 PM #18
Goldish Goldish is offline
Goldish is on a distinguished road
Mobil 1 5w30 every 5000-6000
2004 V8
Goldish is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 07:34 PM #19
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
He never recommended to anyone to do what he is doing. He simply posted what he does like everyone else has been.
BTW I've seen a timing belt explode well under the 100k mark and some are fine at 200k so I don't think that comparison is accurate. There can be defective timing belts, but you can't really screw up an oil change.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 07:39 PM #20
drewj drewj is offline
drewj is on a distinguished road
I go 7500-10k per change. Have been synthetic since the very first oil change. But now I maybe only drive 5k per year, so it might be less. I get it done once a year - or so.
If I was driving daily, I'd do 10k or maybe 15k. You don't need to change it as often as the dealer/oil companies like to tell you.
drewj is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 08:37 PM #21
And I never said he suggested people to do so. I just said others shouldn't follow what he does.
Old 05-30-2019, 09:23 AM #22
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
my exes dad was a jet mechanic and amsoil supporter. he used their 10 or 20k interval oil/filters on his FJ cruiser/tundra/matrix. i like the 5k conventional change and 5-10k synthetic interval. i do believe people buy into dealer/oil company recommendations but an additional 50% - 100% time interval has never compromised any of my vehicles in the last 15 years.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 09:36 AM #23
Levinz11 Levinz11 is offline
Levinz11 is on a distinguished road
I use whatever full syn is on sale. Change it around 7-8k miles with OEM filter.
Wife's car is 2.0 turbo Fusion with 10k intervals. She drives more so right around the time she is ready for OC, I do both with the same oil.
2003 SR5 V8 4WD. 173K.
1995 SR5 Limited. 3.0, 4x4, 5 spd., 210k, BFG 32x11.5 KO's
Levinz11 is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 10:51 AM #24
470SNC's Avatar
470SNC 470SNC is offline
Real Name: Sang
470SNC is on a distinguished road
470SNC's Avatar
Real Name: Sang
Mobil 1 every 5 to 7k
2003 GX470 Ash Blue Mica "Bianca" Blue Steel 2.0
Demello front bumper, Icon 2.5 ext. travel coilovers w/ reservoirs, Icon VS2.0 rear shocks, Ironman rear conversion kit, Toytec Superflex rear coils, Black Rhino Roku wheels, 295 Toyo RT, Flowmaster Super 10, Inno Shadow 13, Tuff Stuff awning, LenzDesign snorkel, RRW sliders, Outrider lower link mount skids, Depo Sport head lights, Rago Fab ditch brackets, KC G34 LED pods
470SNC is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 12:08 PM #25
Falcon3 Falcon3 is offline
Falcon3 is on a distinguished road
Used Oil Analysis shows my 4.0 with synthetic was getting close to the end of the oil at 10,000 miles, but considering most of my driving is stop-and-go with the 4runner for now, I usually do 5,000. I would do 7500 and sleep well, but I don't like having to remember the odd numbers, so 5k is easy to remember and the oil is cheap.
Falcon3 is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 03:10 PM #26
MT Runner's Avatar
MT Runner MT Runner is offline
MT Runner will become famous soon enough
MT Runner's Avatar
Castrol Edge High Mileage 5-30 every 5-6k.
I know I could go a little longer but as others have said, oil is cheap, engine repairs are not, why not just make sure the oil is fresh and have that extra piece of mind?
I drive about 16k a year, so I’m changing my oil three times when I could probably be doing it twice. For me that $35 or so per year is well worth the piece of mind knowing my oil is never near being too worn out. And my engine probably likes me for it.
2005 SR5 V6
URD headers and MAF Cal
AFE Intake
Dobinson, JBA UCA’s, 255/75R17 KO2’s, Level 8 MK6 wheels
MT Runner is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 09:34 PM #27
Wardbird's Avatar
Wardbird Wardbird is offline
Wardbird will become famous soon enough
Wardbird's Avatar
Because of where I live, northern Virginia DC area, and my commute is usually little driving, and mostly Metro (subway), I tend to change oil based on seasons not miles. The changes between hot and cold weather and the build-up of condensation, or lack of driving time to burn it off, is what usually cause me to change the oil. For instance one of my vehicles gets driven just over three miles a day. So, the engine doesn't heat up enough to burn off internal condensation in the winter.
With the next oil change I am going to switch to Mobil 1 high mileage and I do think quality filters make a difference.
Wardbird is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 10:28 PM #28
hgill's Avatar
hgill hgill is offline
hgill will become famous soon enough
hgill's Avatar
Mobil 1 5w30 with Toyota oem filter - Every 5k miles (Do oil change & tire rotation at the same time).
hgill is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 11:06 PM #29
AZ07Runner's Avatar
AZ07Runner AZ07Runner is offline
AZ07Runner is on a distinguished road
AZ07Runner's Avatar
Mobil 1 0w40 every 5k which is about one years mileage. I did go 14 months once, had the oil tested due to a possible antifreeze seep and it tested fine...could have probably gone a few more months, too. OEM filter.
07 Limited V8 Titanium Metallic
Bilstein 5100s x4, Fronts set on 0 with OME 885s, Sway-A-Way 1.5 rear coils, JBA UCAs, '12 Trail wheels, Cooper AT3s 265/70/17, Mobil1 0W40, Amsoil Severe Gear 75W90 and SS ATF.
(Previous truck: 1993 Toyota DLX, V6, 4x4, Xcab, 5 speed, Pewter Pearl - owned from day 1)
http://www.toyota-4runner.org/4th-ge...ml#post2069269
AZ07Runner is offline   Reply With QuoteReply With Quote
Old 05-31-2019, 07:10 PM #30
tom4416 tom4416 is offline
tom4416 is on a distinguished road
Have been using Mobil 1 5/30 since the second oil change on my 2003 and change oil/filter every 5K and send a sample to Blackstone about every 3rd change. The story is the same every time - a strong recommendation to extend the OCI to at least 7500 miles. I've talked to them on the phone twice and the engineer was emphatic about going at least 7500 miles and more likely 10,000. I used to drive in heavy traffic in the Washington, DC area - same results. Now drive in low/no traffic Tucson and the results are the same. Only Toyota filters and I still stick to the 5K OCI. BTW, Blackstone has never been a proponent of the time versus miles argument, within reason. It now takes me a year to do 5K miles and they are still comfortable recommending 7500 even though that would run up against 18 months.
tom4416 is offline   Reply With QuoteReply With Quote
change , curious , i’m , oil , synthetic
Synthetic or non synthetic gear oil? whats everyone running? dedonderosa 5th gen T4Rs 21 03-07-2019 04:31 PM
Come a long, cable, chain or synthetic rope mjacx General Discussions 12 03-30-2016 02:31 PM
100k + Oil Changes. Conventional, synthetic blend, full synthetic? Jeffrey_VB 4th Gen T4Rs 17 01-12-2016 01:50 PM
Synthetic Differential Fluid - How long between changes? -t-squared Maintenance/Detailing 3 06-25-2013 09:08 AM
synthetic brake fluid and full synthetic powerstering johnathandm 3rd gen T4Rs 3 07-20-2011 10:35 AM
