Old 02-13-2023, 04:27 PM #1
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Weird JBL to Pioneer system issues
Ok heres whats going on. Bought a '08 limited with the non nav JBL system. Radio did not work so i had a spare NAV JBL out of my wrecked '08 4runner. The right channel barely worked and the left side seemed to be overdriven to the point of distortion. So got a Pioneer DMH2600 NEX with the radio adapter and a maestro for the SWC and JBL. Paid for the ready harness from Crutchfield. Still have the same issue but now the right channel works but a humming/ buzzing noise coming from the right channel not affected by RPM, left side still being overdriven. So then I changed the speakers to Infinity Reference components in front with the same in the rear doors and a Pioneer shallow mount sub. Still no difference, then I changed the amp to a spare JBL I had from my wrecked 08 4runner. Still no change.
Next was one of many calls to Crutchfield. First they sent another Maestro, then a maestro adapter to RCA. STILL NOTHING WORKED. by this time I'm really aggravated. At one time they wanted me to send back the pioneer to be fixed and that could take up to 6 weeks because the warranty was out yet I've been complaining about this since about the first week. One advisor said that he would send out a new radio but that got squashed by MGMT. A manager did sent me out a line to RCA converter to try.
A few days ago I looked up my service history on Toyota.com and found out that the interior wiring harness was replaced due to rodent damage. could the dealer not have grounded the harness properly or screwed something up? All these issues are kinda weird. I'm ready to pull it out and try it in my other 4runner with the same setup to see if it is the radio or car.
Buying an amp is not doable right now as I'm out of work due a prior accident. Any help would be appreciated.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 02-13-2023, 04:31 PM #2
Ph03n1x24's Avatar
Ph03n1x24 Ph03n1x24 is offline
Real Name: Mark
Ph03n1x24 is on a distinguished road
Ph03n1x24's Avatar
Real Name: Mark
Try running direct grounds from the HU and MAESTRO to the cars chassis. Make sure your audio and power cabling is not intertwined. I ran direct power from the fuse box acc with a secondary 10a fuse piggybacked on the existing 10a fuse. --> 12V Car Add-a-Circuit Fuse Tap Nilight 12 Pack 12V Car Add-a-Circuit Fuse Tap Standard Mini Micro2 and Low Profile Fuse Taps 4 Types ATO ATC ATM APM Fuse Holder for Cars Trucks Boats
Otherwise you may be into the wiring harness accessible under the trim plate right next to the B pillar to tap into the existing wiring if the problem is between the HU and your speakers.
Also, if using Low Side wired output via the MAESTRA and METRA harness - check the insulation on each speaker wire (Vehicle harness side) to ensure there's no bare wire showing through the insulation where someone might have previously tapped into the wiring using an RCA wire converter or otherwise.
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
Ph03n1x24 is offline   Reply With QuoteReply With Quote
channel , jbl , maestro , pioneer , radio
FS 2018 TRD OR Pioneer W4400 NEX System OR Entune Nav System Aggie2015 For Sale: T4R Items 2 09-09-2019 06:43 PM
pioneer avh3400bh install in 3rd gen help!!!!! weird antenna problem! kelsosv17 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 12-27-2012 02:39 AM
2000 4runner - Iginition System Issues and Security System emtnscs New Members 0 10-12-2010 11:15 AM
Pioneer AVIC Z1 issues with system now FLIR Guy Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-18-2007 11:56 PM
