Old 05-29-2019, 05:17 PM #1
merlinrunner merlinrunner is offline
merlinrunner is on a distinguished road
New engine...?
I've got a 2006 4Runner Limited, 4.7L with 149k on the clock. They tell me I have something restricting oil flow to the left side of the engine. Options are tear the engine down until they find whatever is causing the problem or throwing in a new engine. Cost to tear the engine down looking for the problem is , of course, unknown. Cost to replace the engine is $8500. Looking to the members for opinions on the options and the cost to replace the engine. The vehicle is in excellent condition, notwithstanding the engne issue. It's my primary driver. Any input would be helpful at this point.
merlinrunner is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 05:40 PM #2
djpope09 djpope09 is offline
djpope09 will become famous soon enough
$8500 to replace an engine? That's insane. Can anyone else confirm that as a reasonable estimate?
I know the block is ~$3k, but what goes into the other $5500?
djpope09 is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 06:02 PM #3
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
What symptoms are you chasing?
waypoint is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 06:06 PM #4
MikeinNH67's Avatar
MikeinNH67's Avatar
I had an oil pressure issue that was fixed with "Motor Flush" and cleaning out all the crud in the oil pickup. It's worth trying. How do you know this is happening? Sludging can happen on these when oil changes are prolonged.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 05-29-2019, 06:46 PM #5
Low oil flow to left head area.
Old 05-29-2019, 06:50 PM #6
Discovered by mechanic when he was going into the head to fix another problem.
Old 05-29-2019, 07:07 PM #7
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I would try multiple flushings of the engine's oil passages, I would do this myself but you'll most likely have a hard time getting any mechanic at a shop nowadays talked into trying that because of doing the flushing several times and cleaning/draining out any sludge between flushing it is time consuming, but not as time consuming as tearing into the engine, besides most mechanics nowadays have never done such flushings to clear oil passages, this is an old school fix for sludged up engines to get them back to life when they've been neglected on timely oil changes.
2004 Limited V8
Old 05-29-2019, 07:09 PM #8
waypoint's Avatar
waypoint's Avatar
As evidenced by what? Were you driving along and magically detected low oil flow to the left cylinder head?
Or were there some other symptom(s) you observed e.g. valvetrain noise, P0018 error code, etc.?
Old 05-29-2019, 07:16 PM #9
Real Name: Skip
Real Name: Skip
Was this diagnosis done at a Toyota dealership or a independent garage?
2004 Limited V8
Old 05-29-2019, 08:01 PM #10
waypoint's Avatar
waypoint's Avatar
The 2UZ-FE engine has an oil control valve filter as shown in the pic below from the shop manual. If your problem involves the variable valve timing system, this would be my first checkpoint...could be clogged with sludge and restricting oil flow to the VVT actuator.
New engine...?-2uz-fe_oil_control_valve_filter-jpg
Old 05-29-2019, 08:20 PM #11
zeekevin zeekevin is offline
zeekevin is on a distinguished road
I would get a second opinion, where are you located?
zeekevin is offline   Reply With QuoteReply With Quote
Old 05-29-2019, 08:58 PM #12
Discovered as a result of trying to fix a chattering VVT actuator.
Old 05-29-2019, 08:59 PM #13
Independent garage, but has a good rep in the area as far as I know.
Old 05-29-2019, 09:08 PM #14
Yes, the mechanic showed me that exact picture in the his shop manual and told me the issue could be a clogged filter. After cleaning the filter, and replacing the actuator, the chatter was still present but more so since there was no residual oil in the actuator. This and other evidence such as cam wear, etc., lead him to the conclusion the that the oil flow to that side of the engine was restricted. His guess was a piece of a failed oil filter was at fault.
Old 05-29-2019, 09:11 PM #15
I'm located in Laughlin, NV...not much to choose from around here. Mostly shade tree shysters looking to rip folks off.
cost , engine , problem , replace , tear
