Old 05-30-2019, 06:10 PM #1
Jj51702 Jj51702 is offline
Jj51702 is on a distinguished road
Changing out radiator- do I need to refill tranny?
Hi
I’m looking to have my radiator replaced because it is leaking. From my understanding, when the transmission lines are disconnected a small amount of transmission fluid is lost. Does this need to be replaced or is this amount of loss insignificant?
Jj51702 is offline   Reply With QuoteReply With Quote
Old 05-30-2019, 08:26 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Originally Posted by Jj51702 View Post
Hi
Just losing a little bit of fluid from disconnecting the transmissions cooling lines wouldn't concern me too much, not that much fluid will be loss....but when replacing the radiator you will also be losing the transmission fluid still in the radiator as well, so in this case I would recommend checking the fluid level using the proper procedure and add fluid to get the level where it should be.
Just an FYI, if the transmission fluid has never been changed I would highly recommend to do so at the same time as replacing the radiator, it would be a good time to do a complete fluid replacement IMHO!
2004 Limited V8
Old 05-31-2019, 03:26 AM #3
Any other opinions? I’ve called about 8 nearby shops and half claim no topoff is needed while the others claim anything from 1/4 to 1/2 quart will be lost and replaced.
Old 05-31-2019, 07:51 AM #4
Gatafly Gatafly is offline
Gatafly is on a distinguished road
No, you won't need to. there will only be a tiny amount as it drains back into the tranny when not running.
Gatafly is offline   Reply With QuoteReply With Quote
Old 05-31-2019, 09:07 AM #5
ZebRuaj's Avatar
ZebRuaj ZebRuaj is offline
ZebRuaj will become famous soon enough
ZebRuaj's Avatar
I had a couple drips while removing mines. Not enough to worry about.
07 T4R Sport Edition V6 4x4
ZebRuaj is offline   Reply With QuoteReply With Quote
Old 05-31-2019, 09:56 AM #6
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
A friend helped me with installing a new radiator out about 2 months ago. A few drops of ATF were lost, nothing to worry in the least.
CookieRoe is offline   Reply With QuoteReply With Quote
Old 05-31-2019, 11:12 AM #7
the few drops coming out when disconnecting the hoses is not a concern... but what about the amount thats in the trans cooler in the radiator? that holds about 1/4qt or so.
Old 05-31-2019, 11:37 AM #8
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Sorry about that. I left my trans cooler alone. My radiator was leaking and only replaced that.
Old 05-31-2019, 12:35 PM #9
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Just did my timing belt a few days back, and did my radiator at the same time. I only lost a few drops of fluid, and did not add any back. I've already driven about 400 miles and it seems to be fine. However my fluid looked like sh!t and i will definitely be doing a drain and fill via the lines at some point this summer.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 05-31-2019, 04:54 PM #10
i meant the trans cooler inside the radiator, where the trans lines connect to the radiator there is a small internal cooler submerged in coolant.
but i have read you can undo the upper trans line first & possibly blow into it to push all the trans fluid back into the trans pan.
amount , fluid , lost , replaced , transmission
Looking for DIY 1GRFE Tranny Drain and Refill Stunna1019 4th Gen T4Rs 4 05-08-2018 08:35 PM
How much Transmission Fluid do you lose changing the Radiator pconner748 4th Gen T4Rs 13 04-21-2016 08:54 PM
Changing gaskets when changing diffs/tranny fluids? ShooterMcGavin 3rd gen T4Rs 17 08-12-2014 02:22 PM
Question about changing radiator jskingry 3rd gen T4Rs 2 09-25-2012 08:05 PM
Changing to manual tranny nighthawk 4th Gen T4Rs 3 06-21-2008 03:35 AM
