Old 06-09-2019, 01:31 PM #16
ac1617 ac1617 is offline
ac1617 will become famous soon enough ac1617 will become famous soon enough
Originally Posted by orangeblast22 View Post
Annnndddd.... I'm still stuck.
Last night I pulled my battery to finish up some work on my aftermarket HU install. Started her back up only to find the green 4WD icon on, an orange 4WD icon with an X in the middle, and my VSC off.
I read online... Followed instructions in the driver's side sun shade... Drove around my neighborhood an hour...drove back and forth in my drive way like a mad man for an hour...and nothing.
Turned it on this morning, still there.
Feels scary to drive because it's so tight in the turns. I don't feel safe, but it's my daily driver and I have to resolve this.
I also don't understand, why does it do this when I pull the battery? I've pulled the battery several times before but it's doing this now... Don't get it.
Personally I'd stop using it as a daily driver until you figure it all out. Sounds like the center differential is now locked and on dry pavement that's a big no-no. If there is no other option you might just have to bring it into the shop to resolve if you can't yourself. You are putting a lot of stress on your drivetrain right now.
ac1617 is offline   Reply With QuoteReply With Quote
Old 06-09-2019, 01:55 PM #17
orangeblast22 orangeblast22 is offline
orangeblast22 is on a distinguished road
I'm not sure the center differential is locked because if I press the button, the orange 4wd symbol blinks and I hear a beeping sound. I think this is the proceaa to go about engaging a locked differential.
If this is the process to lock the center differential, then what is mode is my car currently in? Plus I was doing 70 on the freeway last night with these issues and I didn't have any problems except for the tight turning. And I cannot afford to not drive my car as it's my daily driver.
2006 v6 4x4 Sports Edition in Titanium Silver
orangeblast22 is offline   Reply With QuoteReply With Quote
Old 06-09-2019, 02:23 PM #18
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
You said you put in new radio?
Did you forget to plug the 4wd dial back in?
I turned the switch one time i had the dash apart and the 4runner did not like it...don't turn the 4wd dial when its unplugged.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 06-09-2019, 02:29 PM #19
Why do you think the turning is tight? That's a locked center differential son.
Old 06-09-2019, 02:31 PM #20
So what would pressing the Lock Center Differential button do then at this point?
Old 06-09-2019, 02:56 PM #21
_chassis_ _chassis_ is offline
_chassis_ is on a distinguished road
orangeblast, can you post a few photos of your instrument panel, the center diff lock button and the 2WD/4WD selector knob?
Is your differential lock light on? If yes, pushing the button will unlock the center differential and the steering will loosen up.
2005 4Runner SR5 V6 4WD
_chassis_ is offline   Reply With QuoteReply With Quote
Old 06-09-2019, 02:58 PM #22
There is no seperate lock and unlock buttons for the center differential, it's all done with the same button. Your steering being tight is a guaranteed locked center differential I'm not sure why you are trying tow argue against that observation.
You say when you press the lock diff button... The orange light with the X in the middle flashes but I assume it never goes away? That's the center Diff trying to disengage (my orange light also flashes when it's disengaging) but can't because it's stuck.
I mean it's your truck, keep driving it all you want on dry pavement with tight steering. I'm just saying I personally wouldn't do it as Toyota also doesn't recommend driving on dry pavement with a locked diff. You can keep convincing yourself it's not locked and the tight steering is... Whatever you want it to be I guess.
Old 06-09-2019, 03:10 PM #23
Hey hold up now, I'm not trying to argue anything. I'm simply trying to better understand what mode my 4runner is in right now and what I need to do to get it back to normal.
I thought pressing the button, the blinking orange symbol, and the beeping noise was my 4Runner was actually trying to lock the center. Seems I am mistaken so I will revisit this.
Edit: it's fixed. I was a fool and inexperienced with this situation and misread what my 4runner was doing. Thanks for helping me understand better.
Old 06-09-2019, 04:45 PM #24
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Will you elaborate on..."it's fixed" please, what was the issue and how did you resolve it?
I'm not trying too put you in the spot light for not knowing how to use the 4WD system, only hoping you will elaborate to possibly help others who may end up having the same issue!
2004 Limited V8
Old 06-09-2019, 05:08 PM #25
Sorry I just thought it was obvious that if your orange light with the X is on... And you notice the steering is very stiff.. that the center Diff is locked haha.
Anyways good to hear you resolved it.
Old 06-09-2019, 05:15 PM #26
If I had to guess, OP didn't understand that the diff lock button is to both lock and unlock the diff. He was probably thinking you switch to 4H with the knob and use the diff lock button to lock the diff... But to unlock you just use the knob (that's why he was confused what was the purpose of pressing the diff lock button if the orange locked light was already on). Add the fact that it sometimes takes a while after pressing the diff lock button for the diff lock to unlock (and the orange light flashes while doing so) he didn't think it was unlocking.
Someone should make a video and sticky how this all works haha.
Old 10-15-2019, 11:37 PM #27
RTrickster86 RTrickster86 is offline
RTrickster86 is on a distinguished road
Don't mean to jump in on the OP post, but since it looks like his issue was easily resolved, perhaps you can all help me with a very similar conundrum that doesn't seem to have such an easy solution:
07 SR5 V6 w/around 140k- my wife's rig.
I recently built a gravel driveway down to our lower back property and took her rig down there to grab a small motorcycle trailer that I park down there, and put it in 4wd on the way back up to avoid chewing up the new gravel road.
The rig was in (P) when I shifted into 4hi. It went into 4wd just fine. I noted that the green 4wd icon was solidly illuminated, and the yellow diff lock symbol was flashing. I thought this was odd because I never hit the diff lock button. The yellow VSC off light is also solidly illuminated.
Once back up to the front of our house I disengaged 4wd, and noted that the symbols on the dash remained as described above. No big deal, as I've occasionally had our 4runner take a little bit to disengage 4wd. However, this time it simply never disengaged. We drove the rig about 15 miles that evening, and I tried anything and everything to get it to disengage, including coasting forward and back and finding a loose road to ensure no strain was left on the drive-train.
Making the situation worse is that the vehicle as stuck with the diff lock on! Even though the icon is blinking, it is most definitely on. I've had fully locked rigs before, and know the strain this puts on the drive-train. I brought it home and parked it ASAP.
The 4wd switch is doing absolutely nothing. It does not beep when trying to switch to 4lo when in (P), as it normally would. The actuator motors on the transfer case don't make any noise at all when adjusting the switch, and it also will not shift to 4lo when in (N). My parents also have the same model 4runner, and their actuator can audibly be heard on their rig with the ignition in the accessory position, shifting between 2wd-4hi, and then 4hi-4lo. With ours - nothing.
I've tried swapping the 4wd ECU from their 4runner, and that did not help the situation any. I know the transfer case actuators are problematic on these things, but I'm still not sold that is the issue, as it seems most people have issues with it initiating 4wd after a long period of disuse. In this case it shifted to 4wd just fine, and is now seemingly is locked there.
Is there a possibility this issue is tied to a faulty front differential actuator instead of the actuator on the transfer case? I'm thinking perhaps the front diff actuator engaged enough to lock the front end, but never hit the limit switch, which then locked up the ECU and entire system, so it won't even try to disengage?
I've banged on both actuators with a rubber mallet, but no joy. Very confused, as I have not been able to find a single documented case where someone experienced this exact issue.
Thanks all
RTrickster86 is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 12:15 AM #28
I'm thinking the process faulted at the circled step in the attached graphic freezing the entire operation. Just seems weird that I get no buzzer when attempting 4lo, and no noise @ either actuator motor.
Help, I'm stuck in 4WD-4runner-4wd-control-png
Old 03-11-2021, 11:37 PM #29
hanusa2005 hanusa2005 is offline
hanusa2005 is on a distinguished road
I have the same exact issue as trickster. Are there any links to a solution to this problem?
hanusa2005 is offline   Reply With QuoteReply With Quote
Old 03-11-2021, 11:51 PM #30
Same issue as trickster what was the fix?
2wd , 4wd , noticed , stuck , switch
Stuck in 4WD Hi Time4Hockey 4th Gen T4Rs 14 12-27-2021 01:34 AM
Key Off, Stuck in Acc Kyogie 3rd gen T4Rs 5 04-07-2017 08:25 AM
Cone washers stuck stuck stuck 4eigner 3rd gen T4Rs 14 04-03-2015 03:49 AM
rear hatch stuck is stuck tried everything.. tristentrd28 3rd gen T4Rs 4 11-09-2014 12:45 PM
How to get un-stuck smackitsakic 4th Gen T4Rs 7 12-24-2009 05:48 AM
