Old 06-06-2019, 08:59 PM #1
KaseyMcc's Avatar
KaseyMcc KaseyMcc is offline
KaseyMcc is on a distinguished road
KaseyMcc's Avatar
265,000 mile major maintenance items
Hi all,
As the title might suggest, I’m getting ready to do a bit of maintenance on my beloved 2004 V8 4wd 4Runner at 265,000 miles and looking for suggestions as to what to take care of vs what to leave alone. Overall it runs fine, I stay up on regular maintenance but I’m planning on doing some more major items soon, including:
Timing belt/water pump
Replace ALL fluids (transmission, front/rear diffs, transfer case, radiator, power steering, brakes)
Grease driveshaft (remove and grease, not just grease zerk it)
Serpentine belt
Valve cover gaskets (have a slight seepage on driver side bank)
Spark plugs
PCV valve
Since I’m doing the Tbelt and water pump, should I go ahead and do cam seals while I’m in there or anything else? I don’t have any visible leaks aside from the valve cover, but figure while I’m in there I should since to my knowledge the previous owner didn’t do them at its first TB change; however some say if they aren’t leaking don’t change them. Figure maybe I should change the tensioner and idler pulley while I’m at it too, but don’t currently have problems there that I’m aware of. Otherwise, it’s pretty mechanically sound so despite the fact that other things COULD be replaced, I don’t really see the NEED to do so yet. Thanks for any suggestions/tips that might come!
2004 SR5 4WD V8 , Titanium Silver, sunroof, HCF delete, K&N drop-in, Interior 6000K LED swap, map light mod, Denso Iridium TT 4702 spark plugs, Hankook DynaPro ATM tires, SilverStar Ultra lows/highs/fogs.
KaseyMcc is offline   Reply With QuoteReply With Quote
Old 06-06-2019, 09:06 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I would not do the camshaft seals unless they're leaking because they're hard to get just right so they don't leak, I would however do the idler and tensioner because of you don't and they go bad you will have to do the whole job again.
2004 Limited V8
Old 06-07-2019, 10:55 AM #3
4RunnerMexico 4RunnerMexico is offline
4RunnerMexico is on a distinguished road
If you're running your original alternator, replace the brushes in it.
You basically have to remove it to do the timing belt anyway, and the alternator by itself is a pain so do it now while you have it apart.
27370-20130 is the part number, only takes like 5 minutes to pull the old ones out and put new in.
4RunnerMexico is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 12:38 PM #4
_chassis_ _chassis_ is offline
_chassis_ is on a distinguished road
I didn’t see any chassis or body related items in your list. How are the:
Stabilizer bar links
Stabilizer bar bushings
Steering tie rods
Radiator (any leaks?)
Battery hold down (mine was nearly rusted out at 200k miles)
Moonroof lubrication
2005 4Runner SR5 V6 4WD
_chassis_ is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 12:47 PM #5
Dylan's Avatar
Dylan Dylan is offline
Dylan is on a distinguished road
Dylan's Avatar
PCV replacement takes 5 minutes, here's my write up:
V8 4Runner PCV valve replacement with pics
The spark plugs are pretty easy too, as long as they aren't stuck. The passenger side plug closest to the firewall is tough to access, so make sure your socket set has a good extension and possibly a flex connection. It was a weird angle accessing that plug. All seven other plugs were pretty easy. I belkieve I used NGK Iridium plugs. Those or Denso are OEM, if I recall.
As for the fluids - I've done all of them personally except for the radiator. I used Mobil 1 Full Synthetic (75w90 i believe) for the gears and transfer cases. Make sure you have a fluid pump.
2004 SR5 V8 4WD White - Full LED Swap - Pioneer BT Stereo - Lite Racing UCAs - Toytec Bilstein 5100 Front 3"
Superflex Rear 2"- Spidertrax 1.5" - 255/75r17 Destination AT - SS Brake Lines - Prothane Bushings - SE Brake Upgrade - Full Synthetic
1994 SR5 V6 4WD Black - Bilstein HDs - OME 900 - 31" Destination AT
Dylan is offline   Reply With QuoteReply With Quote
Old 06-07-2019, 01:36 PM #6
KaseyMcc's Avatar
KaseyMcc's Avatar
That's a good idea! I wouldn't have thought of that, thank you!
Old 06-07-2019, 01:51 PM #7
KaseyMcc's Avatar
KaseyMcc's Avatar
Steering tie rods
Good eye! I actually left chassis off because I've done the CV joints, sway bar end links and bushings in the last year or so (well, except on the rear--so I guess I could get those done), as well as new brakes (rotors,calipers, pads) in the last six months. I don't think I'm losing any fluid from the radiator, battery hold down is good, just replaced battery a few months ago as well. Didn't think of the sunroof, rather not even have the damn thing!
I would like to go nuts and do wheel hub assemblies, upper and lower ball joints, all the way around but will probably save that for until I've got one going bad.
I think I will replace some U joints though, have a clunk when shifting from reverse to drive that I imagine is one of them going bad. I just greased them all a few weeks ago and they all took, however I didn't check for play.
Old 06-07-2019, 01:59 PM #8
KaseyMcc's Avatar
KaseyMcc's Avatar
I actually just did the PCV valve last night! Haha!
Old 06-08-2019, 03:03 PM #9
2003-4x4runner's Avatar
2003-4x4runner 2003-4x4runner is offline
2003-4x4runner will become famous soon enough
If your going to do the valve cover gaskets. You should replace the Spark Plug Tube Seal Gaskets, since you have the valve covers off.
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
2003-4x4runner is offline   Reply With QuoteReply With Quote
don’t , grease , i’m , maintenance , valve
Major discounts on various items. FMFwarrior Off Topic 1 09-14-2016 07:13 PM
Major mile stone achieved last night! tyr0981 3rd gen T4Rs 12 10-02-2013 05:42 PM
Several Major Preventative Maintenance Things DONE!!! BamaDrewski 3rd gen T4Rs 9 03-11-2012 05:30 PM
Upcoming Major Maintenance ???'s Mf Baker 3rd gen T4Rs 6 11-19-2011 04:40 AM
What major items are NOT covered by the Platinum Toyota ext warranty? Threxx~ Problems & Warranty Issues 10 04-07-2008 06:31 PM
