Old 07-30-2019, 09:05 PM #16
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm is a glorious beacon of light Inv4drZm is a glorious beacon of light Inv4drZm is a glorious beacon of light Inv4drZm is a glorious beacon of light Inv4drZm is a glorious beacon of light
MY GARAGE
Inv4drZm's Avatar
MY GARAGE
Somebody makes something like this.
TACOMA REAR DISK BRAKE CONVERSION - PERFORMANCE BRAKES UNLIMITED
2005 4R Sport 4WD "The last of the V8s!" - Dirty Deeds 20" SS Exhaust - Icon 2.5 Resi's. - 1.5" BL - SCS SR8's - 35's - Dana 60 - Build Thread
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 07-31-2019, 02:28 PM #17
Inv4drZm's Avatar
MY GARAGE
Inv4drZm's Avatar
MY GARAGE
It looks like the bearing assembly gets pressed into the backing plate so it wouldn't be an easy swap.
Old 08-02-2019, 11:13 PM #18
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE is on a distinguished road
Mike07SE's Avatar
Originally Posted by Inv4drZm View Post
@Mike07SE any progress?
Sorry!
I did get to try this out before I headed off on holiday, just not the time to reply. I redid my OEM parking brake as I was using the Autotrain for my travels and wanted them functional.
The Scion caliper is no-go. Simply way too small to accommodate the 4Runner between the rear mounts and rotor size.
2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers. Mostly stock - for now.
Mike07SE is offline   Reply With QuoteReply With Quote
Old 08-25-2019, 05:34 PM #19
Inv4drZm's Avatar
MY GARAGE
Inv4drZm's Avatar
MY GARAGE
My original idea of mounting a bracket to these studs in red should work. We can probably do all 4 studs though with a CNC'd bracket that looks like the one below. The only problem is the studs need replaced with longer ones, and to replace the studs the backing plates/hubs need pressed off the shaft. Good thing I have a complete axle assembly sitting in my garage to pull parts and measure from. I just ordered the Wilwood mechanical caliper.
Old 08-26-2019, 12:24 PM #20
hinmo24t hinmo24t is offline
hinmo24t has a spectacular aura about hinmo24t has a spectacular aura about
Originally Posted by Terminator03 View Post
That’s what really bothers me about the inspection procedure here. My ebrake will hold my truck in neutral on an incline, but with the torque of the v8, there is no way in hell it can hold th truck at 1500-2000 rpms like they test it. The test should actually be how the “parking brake” would actually be employed, such as parking on a downgrade. I had the same issue with my v8 Explorer, even with new parts it couldn’t hold under throttle, but would actually work as intended for incline parking.
fellow M******* - and im glad my dad always told me to make sure the ebrake works when buying a used vehicle. not for using them, but for passing inspection/not having a surprise repair.
hinmo24t is offline   Reply With QuoteReply With Quote
Old 08-29-2019, 07:12 PM #21
Inv4drZm's Avatar
MY GARAGE
Inv4drZm's Avatar
MY GARAGE
Should work...
Old 08-30-2019, 10:25 AM #22
Inv4drZm's Avatar
MY GARAGE
Inv4drZm's Avatar
MY GARAGE
Questions:
Is anybody interested in a group buy for these dual caliper brackets, to install you would need to have the backing plate pressed off the axle shafts to install a set of longer studs that I would supply. Also you would need to cut the factory dust/rock shield around the caliper.
Wilwood mechanical calipers ($200)
Extended studs ($20)
Have a shop press out the backing plates ($40)
Modified parking brake cables or new Wilwood cables ($0 or $100?)
My CNC'd brackets ($?)
So maybe $450 to rip out the OE parking brake system for good?
Old 08-30-2019, 11:57 AM #23
turbo8's Avatar
turbo8 turbo8 is offline
turbo8 will become famous soon enough
turbo8's Avatar
Just wondering if you looked into a line lock kit?
Electric Brake Line Lock Kit
97 4runner 3.4l, 5spd, 4wd trd s\c, urd 7th injector, tc upper arms, Fox 2.5" extended travel coil overs, Icon 2.5" piggy back rear shocks, ome 2" lift rear springs, fj cruiser wheels,custom front skid, Modified trail gear rock sliders, tundra brakes, 275/70r/17 bfg AT ko2, true track, Corbeau sport seats, trs h1 hid retrofit.
2011 BMW 135I 6spd
2009 Lexus LX570
turbo8 is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 12:03 PM #24
Inv4drZm's Avatar
MY GARAGE
Inv4drZm's Avatar
MY GARAGE
Yes but it won't help in case of brake line failure. They would work as purely a parking brake however.
I like the simplicity and redundancy of a separate mechanical system that can replace the drums.
adjusted , brake , caliper , parking , properly
brake rotor/caliper/pad replacement - caliper piston, too? amheck 4th Gen T4Rs 16 11-08-2017 09:29 AM
Brake caliper question - which caliper mfg doesn't lock up? bergs 4th Gen T4Rs 6 03-14-2015 09:18 PM
Another sticking caliper, parking brake issues viggen337 4th Gen T4Rs 5 11-23-2014 09:09 AM
Is driving 07 T4R with the parking brake shoes on, only hurting the parking brake’s jow 4th Gen T4Rs 2 05-15-2013 02:31 PM
Broke a caliper bolt..any idea's?? jstutz101 4th Gen T4Rs 2 06-12-2012 08:45 PM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
