09-20-2019, 07:06 PM
#16
Originally Posted by schwein
soooo can these be used for other vehicles as well? specifically my mother in laws 2010 BMW X5 Diesel that literally fails emissions every 2 years and requires some 2000 dollar part to get through every time!
please PM me. thank you
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
09-22-2019, 09:34 AM
#17
Very slick. Will have to look into installing these when I install headers.
09-23-2019, 04:59 PM
#18
Yes
@ duffdog
is your source for these. I will be getting a 2nd One also. Installed 1st on Passenger Side Downstream O2. Designed for use with OEM Toyota O2 Sensor.
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
09-24-2019, 02:20 PM
#19
Originally Posted by duffdog
It doesn't "trick" the o2 sensor. The mini cats provide a legit obd2 compliant cat signal which makes your computer believe that you have brand new cats installed.
I guess that is still a form of trickery, but the signal is not simulated at all, it reads as a perfect catalytic converter in techstream.
well played
10-08-2020, 09:29 PM
#20
I need two of the mini cat. Sent you a msg, not sure you got it.
10-09-2020, 02:16 PM
#21
got it, reply sent to your email.
2005 Blue SR5 v8
07-19-2022, 04:44 PM
#22
Would like to purchase 2 please.
I have a 2005 4.0L and need the adapters for the 2 downstream sensors. Not sure how to PM you as I only see public profile when I click on your username. My email is [email protected] if needed. Thanks.
07-20-2022, 05:47 AM
#23
Real Name: Skip
Real Name: Skip
Due to Spammers you have to have 15 posts before you can start a thread or send a PM.
Unfortunately I do believe that
@ duffdog
has stopped making and selling the "minicats", I have mentioned him in this post so maybe he will reply and elaborate, but he may not since he doesn't visit the forum that often anymore.
2004 Limited V8
09-14-2022, 06:49 PM
#24
@ duffdog
Hi. Unfortunately, my life has become too busy for me to sit at a lathe and manufacture individual parts. I am working on a solution that will work in all cases and on all cars that will cost nearly nothing and also pass visual smog in CA.
2005 Blue SR5 v8
10-07-2022, 05:33 PM
#25
Just installed DT long tubes on my 05 and the O2 sensors are throwing a CEL, even with spacers. I see
@ duffdog
is no longer making the mini-cats - is there another solution or will I just have to live with the CEL?
