06-09-2019, 04:04 PM
Say Hello to my Lil Friend
Mini Cat is Here for O2 Sensor...Thank You
@ duffdog
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
06-09-2019, 08:25 PM
Ooh, I’ve never seen one like that before... usually they look like the spark plug extension things, but have catalyst material in them. This one is stealth so even a visual inspection wouldn’t catch that... How does it actually attach to the sensor tip, though?
2004 black SR5 V8 4WD with TRD dual exhaust, Thorley headers, AFE dry filter, Sprint Booster, Icon 2.0 rear shocks, OME 895E springs, Fuel wheels with 265/70/17 Wildpeak AT3W tires, more to come...
06-09-2019, 10:18 PM
You tap it over the Sensor. Sensor Must be OEM to Work. Its a Tight Fit. It will Never be seen on a Visual inspection as it is in the Y-pipe on the Sensor. Very Stealth. No O2 Simulator or Spacer. Very Cool.
06-15-2019, 04:45 PM
Real Name: Skip
Real Name: Skip
@ duffdog
Any way to get a source for this little device??
@ duffdog
2004 Limited V8
06-15-2019, 08:36 PM
@ duffdog
Sir you would be Absolutely Correct
@ duffdog
06-16-2019, 08:26 AM
Very slick! Sure wish I knew about this before I did the spacers. It’s working perfectly now, and went through emissions testing fine, so probably not worth messing with at this point, but good to know about for future projects as this seems to be a big problem as vehicles age. I’ve seen “mini CATs” before, but they are just a bit of catalyst inserted into spacers, which would still be a problem for visual inspection. This is the perfect solution, especially for those who have already spent a ton of money replacing CATs and other stuff, yet still have the CEL.
06-17-2019, 01:15 PM
I manufacture them myself. PM for details
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
06-17-2019, 01:38 PM
Do you only need one of these? and does it go into the rear o2 sensor?
06-17-2019, 02:00 PM
Depends if you’re throwing codes on both banks or not. I’d do both sensors at the same time, regardless.
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
06-17-2019, 02:01 PM
Thanks for the input! I'll have to look into getting two of them since I have the Doug Thorley headers.
06-17-2019, 06:32 PM
Yes Rear O2 Sensors. I am getting a Second one also to have Both O2 Sensors covered.
09-19-2019, 09:25 PM
Im interested. Brand new here. Don't know if I can receive a PM...?
09-20-2019, 02:32 PM
soooo can these be used for other vehicles as well? specifically my mother in laws 2010 BMW X5 Diesel that literally fails emissions every 2 years and requires some 2000 dollar part to get through every time!
2003 - 4Runner Limited V8 (Sold)
2014 - 4Runner Limited V6
2019 - GX460 Premium V8
09-20-2019, 06:53 PM
Registered User
Real Name: Jay
Registered User
Real Name: Jay
So this is all that's needed to trick the ECM into thinking the sensor is working properly even with no cats?
09-20-2019, 07:04 PM
It doesn't "trick" the o2 sensor. The mini cats provide a legit obd2 compliant cat signal which makes your computer believe that you have brand new cats installed.
I guess that is still a form of trickery, but the signal is not simulated at all, it reads as a perfect catalytic converter in techstream.
2005 Blue SR5 v8
