Jason B
Old 06-11-2019, 05:15 PM #46
rokr1292 rokr1292 is offline
rokr1292 is on a distinguished road
So the part that rusted is the air injection lines, as part of the secondary air injection system?
I see someone mention that the headers for earlier year 4th gen v8s dont have these lines, is that the only difference? could you feasibly use the older headers on a newer v8 that has the air injection pump bypassed/blocked off?
I've wondered if that system could be deleted for a while now, and this is just what I was thinking reading this thread.
rokr1292 is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 05:36 PM #47
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
Angry
Where is Jason B? People need some answers on this.
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 05:50 PM #48
Cloud9's Avatar
Cloud9 Cloud9 is offline
Cloud9 is on a distinguished road
Cloud9's Avatar
You can see by the oxidation on the value cover that is turning white, that there is severe environmental issues. When aluminum oxidizes, it turns speckled white, instead of a rusty brown color like steel, each have their own reaction color. I'm talking about the Toyota™ valve cover, see the white on it? (aluminum valve cover) and the BOLTS ON IT are the same color as the rail, and those bolts sit higher up than the rail. This is SEVERE to see happening on the valve covers. Factory headers in this condition you'd go through multiple sets. Wherever you are currently located it's bad, very bad. My point is it's either serious road salt and the frame under your truck is probably worse. I would seriously look into POR-15 on the frame.
I said earlier I wasn't going to get into the how's and why's but I'm an engineer and have built my own headers when I was younger for diesel trucks and in race applications. This is definitely where you live.
2019 TRD pro - S&B intake, Gibson Side Dual Catback black ceramic tips, Sprint Booster. lift coming
2006 4Runner V8 - Doug Thorley Headers/Hi-flow Magnaflow Cats, Gibson Catback Dual Exahust, Volant Air Intake, Sprint Booster, All from Burtman Industries
1996 Limited 3RD Gen, still going strong!
Cloud9 is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 06:11 PM #49
Marfy's Avatar
Marfy Marfy is offline
Marfy will become famous soon enough Marfy will become famous soon enough
Marfy's Avatar
Bro - I don’t understand you. You work for DT? For the third time, you are missing the point completely. Let me simplify it for you: Look at the header, it looks completely fine. Look at the injection tube. It looks rusty as hell. The point is they sold a product that is not stainless steel fully and portrayed that it was. They cut corners and this is the result.
My original manifold was actually fine despite your claims of severe conditions.
[Sold] 2007 Limited - V8 4WD
Stock Rear RAS / Bilstein 5100s / OME 885 / RB 1.25 BL / BFG KO2s - 275/70R17 / SCS Ray 10 - Brushed Gold /
XenonDepot Hid Kit (lows) / Aftermarket Yellow Fogs w/ XenonDepot HIDs / DT Premium Long Tubes / Custom Y w/ 2 cats deleted / full custom exhaust pipe with magnaflow / aFe CAI / MAF Calbrator
Marfy is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 06:15 PM #50
Cloud9's Avatar
Cloud9's Avatar
Bro - I don't understand you? I think it's been asked where you live multiple times and you won't tell anyone. I'm trying to help you if you you answer the simple question above. I do recommend though with these trucks to do POR-15 to the frame. It's worth it if you plan on keeping your 4Runner a long time. I have NO more rust thanks do doing this 4 years ago.
Old 06-11-2019, 06:22 PM #51
Marfy's Avatar
Marfy's Avatar
Yes we have salt on our roads in the winter, I’m not trying to hide where I live.
I know you’re an engineer so work with me here, but one simple question:
Why does the injection tube look different than the header material?
Old 06-11-2019, 06:28 PM #52
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Yeah guys just POR-15 the headers too. Problem solved.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 06:29 PM #53
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
The point isn't that the OP lives in a rust-prone region. I think his original complaint is that his Doug Thorley headers are severely rusted despite the fact that he was lead to believe they're made of stainless steel which resists rust to a greater degree than the lesser grade of steel he discovered was used in manufacturing this product.
His other complaint is that rust on his Doug Thorley headers that were purported to have been manufactured from stainless steel, is not covered by Doug Thorley's warranty.
I believe the OP is reasonable in his expectation that the Doug Thorley headers will resist rust to a greater degree than they have been able to so far as well as his expectation of successfully making a warranty claim with the manufacturer.
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 06:50 PM #54
Cloud9's Avatar
Cloud9's Avatar
If only life were so simple One look at the valve covers tells me anything that's put on that truck is trouble. I can go snap a pic of mine if you want and I'm in DC, not the nicest place to live but I've seen some areas where the whole frame is gone. I still polish what I can see visible from when I open the engine just to keep it clean. That's something all should do occasionally so there is no build up.
Old 06-11-2019, 07:00 PM #55
ac1617 ac1617 is offline
ac1617 will become famous soon enough ac1617 will become famous soon enough
Honestly man I don't know why are you still arguing and wearing Doug Thorley's coin purse as a chin. The fact of the matter is Doug Thorley advertises their headers are Stainless Steel (one of the BIGGEST reasons to use SS is because they are rust resistant) and OP along with others has shown that's NOT the case and very misleading. What relevance does OP living in salty roads have??? The headers are SUPPOSED TO BE STAINLESS STEEL AND NOT RUST AS THEY ADVERTISE.
You also typed a message to me which is impressive considering you have such a firm grasp on Doug Thorley's hot dog saying Toyota's Headers crack at 120-140k. Well considering my 2007 4runner has only 140k KMs on them I'd say they lasted pretty well... that's 12 years so far in rust country without issues. OP lives in the same conditions as I do and after 2 years those Doug Thorleys sure as hell don't look like they will last another 2.
Christ.
Do the math, Doug Thorley headers AREN'T cheaper than OEMs if they rust through after 4 years.
ac1617 is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 07:04 PM #56
Marfy's Avatar
Marfy's Avatar
Fairly sure he was being sarcastic, engineer. Why haven’t you answered my question?
Also, yes, look at the terrible shape my rig is in. Anything you put on turns to shit. I wheel it through serious mud all the time... what else have you spewed?
**UPDATE** - DT has made right - Buyer Beware - Doug Thorley Headers-d91511ca-b249-434b-98cf-432e214c9a07-jpg
Old 06-11-2019, 07:12 PM #57
Cloud9's Avatar
Cloud9's Avatar
They will crack eventually. Just like concrete. All concrete cracks, it's just when will it. I know mine and what my cousins 2008 did and the other guys I wheel with. It's a design issue with Toyota and we should all really be after Toyota here. They should be paying us for this issues. It's know if you read these forums that all V8 4th gen headers crack. Why isn't Toyota doing anything?
And what state are you in? You said salty area, WHICH? I don't know why you are so defensive on where you live??? After I wheel I wash it off with a foam brush and it looks brand new like yours I like the wheels. But the engine if you leave it go will look like crap.
Old 06-11-2019, 07:32 PM #58
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Lol. How about a class action lawsuit against Doug thorley for fraud claiming they are completely coated and won't warranty their knowingly defective product.
Unfortunately you would have to prove they knew they were selling a defective product.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 07:38 PM #59
Cloud9's Avatar
Cloud9's Avatar
I'm going to sue TOYOTA since they made me spend all this money to buy new ones, twice! Toyota is a bastard. I really would have died getting these for the 3rd time. No Toyota didn't and wouldn't warranty the TWO sets of cracked headers I bought from them. That's a real lawsuit. These trucks are ticking time bombs but they are the last 4Runner V8! I'm happy with the better gas mileage though.
Old 06-11-2019, 07:39 PM #60
Marfy's Avatar
Marfy's Avatar
Product page lists stainless steel as material...
**UPDATE** - DT has made right - Buyer Beware - Doug Thorley Headers-b0f55171-5200-4417-8488-0bf62f520b3d-jpg
air , headers , injection , thorley , tubes
!!Doug Thorley Headers 4.7L V8!! BootyFister 4th Gen T4Rs 224 08-30-2022 09:12 PM
Doug Thorley Headers w/ or w/o EGR? DavidAlexander 3rd gen T4Rs 8 07-13-2016 10:57 PM
Doug Thorley Headers rossk35 5th gen T4Rs 0 03-19-2014 03:03 AM
Doug Thorley Headers kraftwerkauto 4th Gen T4Rs 3 10-12-2012 11:25 AM
Doug Thorley Headers Beancounter25 Engines / Suspension / Wheels / Tires / Audio / Accessories 8 08-10-2009 08:27 PM
