06-11-2019, 06:18 PM
Real Name: Russell (OB #9908)
What's This Extra Plug Near the Passenger Side Fog Light?
I was nosing around under my '07 Sport today and found this extra plug that branches off from the passenger side fog light wiring (the fog is the connected plug). There isn't one on the driver's side. Anyone know what it's for? It's obviously not anything critical but I'm curious.
06-11-2019, 06:24 PM
passenger side, i would check the washer pump area.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
06-12-2019, 03:22 PM
I got one also!
________________
2007 SE V6 Titanium
06-23-2019, 11:25 AM
I came across the same thing yesterday. Any answers on this?
2008 Toyota 4Runner Limited 4x4 V6 Shadow Mica
06-23-2019, 11:30 AM
This harness is most likely global part for other models like Prado or Lexus GX So that would explain extra plug.
Sent from my Redmi 4 using Tapatalk
06-23-2019, 07:31 PM
I’ve seen some 4th gen JDM Hilux Surf with the parking sensors just above the fog lights. Tiny little circles in the front bumper with sonar sensors in them. Might be just a electrical rough-in for that option. Since they’re all built in Japan , benztech might be right and they just decided to use the same harness and left that plug as is.
I haven’t come across this in my ‘04 so it might be specific to later years only?
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
06-23-2019, 10:59 PM
This makes sense to me. I may check the plug for power at some point as I have a mod idea for which it may be useful.
06-23-2019, 11:37 PM
it could be for the washer pump, have you check for any fluid coming to the tailgate window?
06-23-2019, 11:44 PM
Yes, washers are working front & rear.
06-24-2019, 01:08 AM
i was snooping around mines and i didnt see anything, the only thing i see mines branches off to the ac port, headlight high and low and parking and signal. that plug look similar to the one on the steering pump.
01-07-2021, 09:04 PM
Real Name: Doc
Real Name: Doc
While replacing my '08 OEM fogs with LEDs today, I also noticed this "extra" OEM plug next to the passenger-side fog lamp assembly.
Haven't tested it yet, but does anyone know if it's hot or not?
Can it be used for something like an LED bar?
Stock 2008 Driftwood V8 4WD Limited with X-REAS, est. late 2020. Build page to come...
01-08-2021, 12:53 AM
Real Name: Doc
Real Name: Doc
Found it!
So here's what I found for some fella's '07 Tundra by Googling a solution...
For those who're curious, looks to be for "parking assist ultrasonic sensors" on rigs other than ours. From Tundras.com:
What are the 2 empty plugs attached to fog light wiring? | Toyota Tundra Forum
Now I'll need to test its "hotness."
Unlike me, I hope it is.
01-08-2021, 01:12 AM
Not to hijack but speaking of extra plugs...... I was wiring in a USB plug into one of the blank spots on the center console and there is a white plug that is not connected to anything under there. I kept thinking I unplugged it when I pulled the center console up but there was nothing to plug it into lol
01-08-2021, 02:20 PM
Probably for the AC 110v port which I’m guessing u don’t have?
385,000 Km
Titanium Metallic
01-08-2021, 02:48 PM
I do have it and it functions correctly after I reinstalled the center console cover. I checked the seat heater's as well, everything works.
Strange.
