Old 06-14-2019, 02:16 PM #1
cruiser08tt cruiser08tt is offline
cruiser08tt is on a distinguished road
A/C trouble
story is.. after installing the Domello bumper I cked the a/c line for (hot side)clearance.. so after a few months of driving around somehow the line was making contact with the edge of the bumper and manage to chaffer thru the line enough to cause a leak.. after a wk I finally received a brand new OEM hard line and replaced it.. side note A/C was working prior to changing this line out.
At this point I vacuum the system with a kit I purchased online and used the youtube tutorial .. everything seems good system doesn't appear to be leaking and held pressure for over an hr..
So final part was to add freon after a few attempts I noticed the clutch compressor not engaging but a/c system is blowing but no cold air.. clutch compressor was not engaging
I don't have a helms as Im sure it would help but heres what I've cked and done..
1. system holds vacuum
2. a/c in the car works from low-high, a/c light not flickering so relay is good? but I changed and put a new one in and did not solve it.
3. checked the clutch compressor adding voltage and it does work
questions:
1. are there any other fuses or relays I should attempt on checking or replacing?
2. I see the Hot side switch but did not find the low side pressure switch which from I read is supposedly be behind the glove box. was possibly wanting to bypass this by jumping it ..
3. can I manually add freon by simply jumping the clutch/compressor applying power directly to it
4. cked the plug (3 prong) that connects to the compressor and noticed there was no power coming thru it even with the a/c turned on
thanks in advance..
2007 LimitedV8
cruiser08tt is offline   Reply With QuoteReply With Quote
Old 06-14-2019, 03:13 PM #2
Cloud9's Avatar
Cloud9 Cloud9 is offline
Cloud9 is on a distinguished road
Cloud9's Avatar
A lot of shops will check this out for a flat fee. You might want to check into that to see where the issues is and it might be simpler than you think.
2019 TRD pro - S&B intake, Gibson Side Dual Catback black ceramic tips, Sprint Booster. lift coming
2006 4Runner V8 - Doug Thorley Headers/Hi-flow Magnaflow Cats, Gibson Catback Dual Exahust, Volant Air Intake, Sprint Booster, All from Burtman Industries
1996 Limited 3RD Gen, still going strong!
Cloud9 is offline   Reply With QuoteReply With Quote
Old 06-14-2019, 03:36 PM #3
tom4416 tom4416 is offline
tom4416 is on a distinguished road
Not sure why you are trying to do this without a proper set of manifold gauges as you will either under or over fill the system. The low side switch has to detect enough pressure to kick on the compressor which then excites the high side sensor as well. A proper balance between the two is the only way to properly fill the system. Also, what kind of "kit" can pull thirty inches of vacuum on the system - that takes a two-stage pump to do it properly. IIWM, I'd go to a certified shop and let them do everything the right way and see what you end up with.
tom4416 is offline   Reply With QuoteReply With Quote
Old 06-14-2019, 03:41 PM #4
yeah thats my last resort is to take it to a shop..the kit purchased was a simple diy self kit that comes with vacuum pump and manifold/gauges that seems to work for a lot of people.. its not a highend dealer system.. I always like to try to solve it myself first .. from researching it seems like low freon is causing the clutch not to engage but its not possible to add freon if clutch doesn't engage.. so im just trying to narrow it down.. its a headache but always nice to be able to do it yourself when possible.. actually I think I skipped an important step.. will update..
2007 LimitedV8
Old 06-14-2019, 04:58 PM #5
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
it is possible to add some freon without the compressor engaging.the freon in the bottle is already compressed at high pressure, say about 60psi or so...so on hooking up to your low side, some freon will flow into your ac system...leave it for about 3minutes, till natural flow stops .and usually this quantity is enough to excite the compressor to kick in, i think about 70grams flowed into my system the last time i tried this
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 06-15-2019, 03:38 PM #6
update.. after going thru the process again, I found out the adaptor valve used to puncture/screw onto the freon canister was defective.. purchased one of the bigger can with the gauges, hooked it up the low side.. it took less then a minute before the clutch engaged .. now I have cold air..
2007 LimitedV8
a/c , clutch , compressor , line , system
Trouble Codes - Scan Gauge - Trouble CXS 4th Gen T4Rs 1 04-11-2013 11:04 PM
Trouble others have seen! weary1 Gallery 2 02-03-2013 10:59 PM
Trouble with 2L Perry350 Australia 0 10-25-2011 08:19 PM
265/65/17 to 265/70/17 = trouble? DG&BRM Off-Roading 6 03-02-2011 02:54 AM
im in trouble!!! 4x4v8 4th Gen T4Rs 5 08-19-2005 01:19 PM
