06-15-2019, 09:58 AM
Master cylinder leaking....need to fix....help
I have a 2004 v8 limited and the master cylinder is leaking....i have identified the leak as coming from the piston (leaking slightly but still leaking) i ordered a $55 kit to fix this.....that said i've never done this before and have been trying to find a write up....anyhow the local toyata place wants $3200 to replace the whole thing when i really thing it just needs a new o-ring.....anyhow any help is appreciated....thank you
06-15-2019, 02:45 PM
Real Name: Skip
Real Name: Skip
[QUOTE=moloss;3306183]I have a 2004 v8 limited and the master cylinder is leaking....i have identified the leak as coming from the piston (leaking slightly but still leaking) i ordered a $55 kit to fix this.....that said i've never done this before and have been trying to find a write up....anyhow the local toyata place wants $3200 to replace the whole thing when i really thing it just needs a new o-ring.....anyhow any help is appreciated....thank you[/QUOTE
Below is a PDF file for overhauling the master cylinder.
Step #15 is the step that you need to do to remove the master cylinder piston which is where you have the leak and need to replace the o-rings and or seals, etc., then step #47 is where you reinsert the piston in to the master cylinder.
There are many other steps in the document that you don't and or shouldn't have to do since your issue is a leak from the piston/cylinder of the master cylinder.
2004 Limited V8
06-15-2019, 04:16 PM
brake booster oring??
i have the exact same problem, please record or video or take lots of pictures, should you go ahead with the repair, i changed the accumulator+oring a couple of months ago, it didnt resolve the problem.
do keep me in the loop
is this the part you bought??
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
Reason: more info
06-15-2019, 04:52 PM
Real Name: Skip
Real Name: Skip
The PDF I posted above is the one I mentioned in your topic/post of your issues, I was looking for your post to post it there as well, so I'm glad you seen this topic so you have the file to help you with your's!
It took me a while to find the PDF on my computer, and then figure out how to post it.
I have CRS (Can't Remember Shit) so I'm glad I don't have to keep looking for your post since I can't remember the topic!! LOL
2004 Limited V8
06-15-2019, 06:00 PM
Also interested in where you got the parts from! Need to do mine soon as well
06-15-2019, 06:15 PM
Real Name: Skip
Real Name: Skip
Here's 2 different sources for the part/kit you should need, be sure to enter your year model. etc. to be sure they also fit your year model, these links do fit my 2004 model.
04493-60350 - Toyota Parts Deal)
Overhaul Kit - Toyota (04493-60350) | Toyota Parts
2004 Limited V8
06-16-2019, 10:58 AM
Goodness thank you for posting that.....the part isn't here yet
04493-60350 - Toyota Parts Deal,
This is what i ordered....hopefully it's the correct part
I will keep y'all posted when it gets here and how it goes.....thank you very much
06-16-2019, 11:00 AM
06-17-2019, 04:39 AM
Originally Posted by AuSeeker
Just checked, seems 05 runner brake booster does not use that part, being that the brakes are different for 05 to 09 and 03/04,
now am really stumped, as am yet to see an 05 upwards resolve this internal leak problem
06-17-2019, 06:57 AM
Real Name: Skip
Real Name: Skip
I would check your build date, if you have a very early 05 the master cylinder maybe the same as the 04s, my source lists 2 different master cylinders for the 05 and one of them is the same as the 04, but only one for 06 and later, you may want to contact an online dealer and give them your VIN and see if that overhaul kit work for yours.
I haven't found one for the later models, but I will keep looking when I have some more time.
2004 Limited V8
06-17-2019, 08:13 AM
mine is oct 2004, checked with an 04, my brake master cylinder is different
07-04-2019, 06:22 PM
Ok so iÂ’ve been on vacation (got home yesterday) decided itÂ’s time to tackle this.....I get under the dash on the drivers side thinking iÂ’ll take off the 4 nuts and disconnect from the brake pedal.....easy peasy.....nope I canÂ’t even get any of my wrenches on the nuts.....there is no room....iÂ’mnot a big guy but letÂ’s just say I barely fit never mind I canÂ’t get a wrench on anything.....ideas?
Reason: Misspelled words
08-01-2019, 03:18 PM
what did you finally end up doing
