Originally Posted by Neil
Hi,
Any thoughts regarding why the power outlet and cigarette lighter fuse would blow after installing pioneer avh-271. I also installed a parking beake bypass and I think everything is hooked up correctly. Non jbl, no steering wheel controls. Thanks
The typo aside what exactly is the red high lighted mod you mentioned, I did a forum search and no hits so I would like to know??
Edited: Never mind, I found the mod after a google search, still not sure what your issue is other than something in your install has a short in the circuit, I would go over your connections again insuring you don't have a ground wire hooked up wrong or a hot wire hook to ground, etc.. I would first try disconnecting the e-brake mod first and see it that solves the fuse issue, if not reconnect it and keep checking each wire connection one at a time until the fuse issue is resolved and then reconfigure what caused the issue.
Electrical issues are a pain and sometimes the only way is to work one wire at a time, if you disconnect several wires and the issue goes away you really don't know which wire was the problem.
