Old 06-16-2019, 12:00 AM #1
UrbanRunnerNY UrbanRunnerNY is offline
UrbanRunnerNY is on a distinguished road
Remove and reinstall XREAS front shocks
Tore apart my complete front suspension to install ToyTec spacers. Only then i realized that XREAS line gives no slack and I couldn’t remove the coilover to knock out the 3 studs and install spacers.
Doing this on the floor, can i unbolt just the front shock with XREAS, then successfully reinstall it? If it is possible, where should i disconnect it? Since I'm doing this in the floor, is it ok that that the diagonal of the shock I am working on, suspension is compressed? I ask because i know XREAS shocks are connected diagonally.
Thanks in advance!
2009 White UrbanRunner
2023 White TRD Pro
UrbanRunnerNY is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 12:23 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
there is disconnection points at the frame rails, but truck needs to be up, otherwise you loose fluid, i would ditch the x-reas shocks all together and just reuse the springs, as long your springs are not sagged, its a cheaper alternative to use aftermarket springs and shocks when doing suspension, doing the spacers with a tired suspension parts is not worth integrating.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 12:31 AM #3
Boort's Avatar
Boort Boort is offline
Boort will become famous soon enough Boort will become famous soon enough
Boort's Avatar
Thanks in advance!
Here are the details on Xreas from the 03 FSM. Gives the details on teh disconnection points. As mentioned earlier you'll need all 4 wheels off the ground to close the system at the disconnect points and break the connection.
I'll second the remove the system and replace with aftermarket if you can afford to do so.
If you keep the Xreas and need the center sections I have a pair in the shed pulled in working condition when I removed mine at ~80k miles.
Free if you can pick up.
Boort
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Boort is offline   Reply With QuoteReply With Quote
Old 06-16-2019, 06:58 PM #4
I re-read the FSM procedure, but i still dont see where to disconnect. Also, it only mentions that the opposite shock needs to be fully extended, not all 4.
At this point, i have 2 questions:
1. where is the right place to disconnect the front shock XREAS if i plan to reinstall it?
2. Say i am working on front passenger side, do both front passenger (one I'm working on) and the rear driver (diagonal opposite) have to be fully extended OR just the rear driver?
Love this forum, thank you all!
2023 White TRD Pro
Old 06-16-2019, 07:30 PM #5
each shock has the one way check valve disconnect point about 10-12" down the line from where it banjo bolts to the shock itself. they are a 2-3" long union of 2 nuts, you hold one end & turn the other & they split apart & the one way check valve stops fluid from coming out.
this is an x-system so technically the opposite corner should be what needs to be off the ground along with the side your working on. however, it would be easier to just lift the whole truck instead of messing with lifting 2 opposite corners.
i will 2nd the suggestion of replacing the xreas entirely, if you have anywhere near 80k miles chances are its shot or not working as good as it should. i just replaced my xreas in my 08 2 weeks ago & even though the xreas had no leaks & was "working", it is night & day difference with new shocks & springs & did not cost that much.
Old 06-17-2019, 08:48 PM #6
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
See the “X-REAS Delete...” thread linked in my sig for info & pics. Also happy to answer any questions. Hate to tell you but the fronts are a real PITA. You’ll also need a 22mm wrench.
Honestly, I had such a tough time just disconnecting the damn things to remove them that I can’t imagine reinstalling them, but I’m sure it can be done with enough determination.
All things considered, I also recommend just replacing the X-REAS if you can do it now. The day isn’t that far off anyway so why do it twice?
Bluesky 07 is offline   Reply With QuoteReply With Quote
floor , front , remove , shock , xreas
XREAS. Dealer wants to replace front shocks only. BigRod 5th gen T4Rs 4 08-10-2017 05:50 PM
Xreas front shocks change cost d_cool 4th Gen T4Rs 10 11-07-2009 12:27 PM
