08-27-2013, 02:10 PM
Another Blown Head Gasket
My issue started a few months ago with a rough idle at startup. It lasted a few seconds then stopped and the engine ran fine. Then a few weeks later the rough idle lasted a bit longer and the check engine/vsc/atrac lights came on. So a quick diagnostics scan and it came back with the dreaded P0306 cyl. 6 misfire. I also noticed the engine coolant reservoir was pretty much empty.
The rough idle would come and go, some weeks it was fine, other weeks it happened every day. Then a few weeks ago I had the usual rough idle, but I started to notice misfiring while driving. I could feel the engine loose power for a second especially while accelerating. So I bit the bullet and took it to the dealer. $90.00 and two trips later they told me it is the 6cyl injector ($600 repair).
Well, after reading on this forum I decided to do my own diagnostics. I borrowed a comp. gauge from Autozone and did a compression test.
Should be: 145psi min - 185psi max, with a 15psi max diff. between cyl.
My results:
Cyl 1 = 160psi
Cyl 2 = 30psi
Cyl 3 = 170psi
Cyl 4 = 40psi
Cyl 5 = 160psi
Cyl 6 = 165psi
My conclusion, blown head gasket. Local shop and dealer quoted $3-3.5K for repair. I love my 4r and had no issues until this one, but I just didn't have $4k to spend on repairs.
So I traded it in at the dealer, they subtracted their cost for the 6cyl injector ($400) and new tires (70k miles on my Dest AT). I now have a new 2013 Camry SE.
Best of luck, and I hope no one else has this issue but i'm betting others will.
Nate
2005 4runner, v6, Sport, Stratosphere Mica, 4X4, JBL, Moonroof, 115V outlet, Pinstripe
Added (so far):
Homelink, Husky Cargo Mat (grey), 35% tint side windows, OEM all weather floor mats, OEM Hood Protector, 6-Disc JBL, Valor Exhaust Tip, Silverstars, PIAA Super Silicone Wipers, Nuvi 765T GPS, Firestone Destination AT's, Sirius Sat. Radio, K&N CAI
08-27-2013, 02:36 PM
That blows. Head gasket issues are one of my worst nightmares
08-27-2013, 04:40 PM
Just remember you traded in something that you could probably fix yourself in a weekend for 5 years of car payments.
Parts wise your talking 200-400 dollars depending on how much you replace. To do it on the cheap you just change out any gaskets and don't replace any parts you don't have too (like water pump, t-stat, etc) and for the most part a 100-150 tool set has everything but the torque wrench to do the job. A 30 dollar Hanies manual will outline the job and keep you honest with instructions on how to do it. The most importantly reason to do it is the self sadisfaction of doing it yourself and saving a ton of cash while learning how to work on your own vehicle.. But that is just me.
That said it is a shame the dealer didn't catch it sooner. It's a shame all they did was diagnoise it with the computer and what I assumed they didn't do is check the spark plug (pulling it out should have revieled a discolored plug).
08-27-2013, 04:51 PM
How many miles were on it?
08-27-2013, 05:02 PM
Real Name: Mike Davies
A bad HG is not the end of the world. $3k to fix it is freaking ridiculous however.
If ignorance is bliss, why aren't more people happy?
08-27-2013, 05:12 PM
Has there been any head gasket failures on the later year 4runners? 2007-2009?
Seems like all the failures are pre 2006 years.
I know Toyota made a change in the head gasket. Someone posted on here that when they purchased a new head gasket from the Toyota dealer it was redesigned/updated. It would be nice to know when this head gasket parts update was during the production of the 4runner.
2009 Trail Edition - ICON lift, Total Chaos UCA, BF Goodrich Mud Terrain KM2 285/70/17's, SCS Stealth 6 Matte Gunmetal finish, K9 2.2m Roof Rack.
08-27-2013, 06:50 PM
Makes me worried about mine..... Oh wait, no it doesn't.
2017 Ram 3500 4X4 - The hauler.
2003 SR5 4X4 4Runner - 412K+ Off-road Toy.
1997 Civic SFWD 674hp 530tq - Because racecar.
08-27-2013, 08:37 PM
Same as what Hearno asked, How many miles on the engine before failure?
2004 T4R Limited 4X4 | 4.0L V6 | TRS Custom Retrofitted HID 6000K Headlights | 3000K HID Fog Lights | K&N CAI w/ Vented MOD | Stock Limited Wheels | 265/70/17 Cooper Discoverer AT3's | FJ spring & Bilstein 5100 shocks all around | LED License Plate Light Swap | Interior LED Light Swap | Cobra 29 LX CB Radio w/ Wilson 'little wil' antenna | Spidertrax Wheel Spacers (currently off) | And more to come...
08-27-2013, 09:06 PM
Real Name: 660hp/488tq Evo X
The task to do this job is not that easy. The entire front n top needs to come off at the point u have just about a block left in the truck.
I have an 06 and have the same problem. I am building mine up though.
Need lights???...Text me @ 3054239215
IG: @CREVOZ_X
08-28-2013, 07:56 AM
I can do basic maint, but this repair was way beyond my comfort level. The local shop said it was at least 20hrs of labor. My 4r was right at 127,000 when I traded it in.
Added (so far):
08-28-2013, 10:28 AM
Real Name: Brian
Real Name: Brian
Bummer. 127k gets me worried... I'm creeping closer and closer. Seems like a lot of other guys had well over 150k when theirs went. Keeping my fingers crossed that I never have to deal with it, but I think I'd go the same way trade it in to a dealer.
2017 Tacoma TRD Sport Double Cab 4x4
SOLD: 2004 4Runner Limited V6 4x4
08-28-2013, 11:15 AM
Does it make sense to trade in a broken car to a dealer? I would guess that the dealer will hard core low ball you if they know you have a head gakset problem. Probably give you $3k for something that is worth $15k without a head gasket issue?
IF, they give you more for your broken trade in they will probably bump up the price on the new vehicle that you want to purchase to make you THINK you got a good deal.
To the OP, how much did the dealer give you for the trade?
If I were you, I wouldn't even tell them about the HG issue and just trade it in. You spent $600 or so for the injector, its their fault they misdiagnosed the issue so I would not feel bad at all not telling them about the issue! Lots of times dealers do not even test drive a vehicle when you do a trade.
08-28-2013, 11:23 AM
I don't think the dealer knew about the HG, only the injector issue they had misdiagnosed. That my take of the OP.
08-28-2013, 11:31 AM
Okay, that's better than.
Most likely that vehicle will go to auction so it does not matter much if its injector issue or HG issue for the dealer.
08-28-2013, 11:36 AM
It's hard for me to define what is easy or what is with in someones comfort level. My rule has always been that if it just requires basic hand tools and it's outlined in a service book it should be easy. About the only thing extra a HG job needs is a torque wrench for install.
Remember the shop is most likely charging you Flat Rate which means someone determine how long it takes to do the job on average and that is what they pay the mechanic. If the mechanic can do it in 8 hrs they still get paid 20 and you get charge 20. A friend of mine who is a Toyota mechanic can do a tundra frame swap in 12 hrs, flat rate is around 36hrs I believe.
I can pull a Subaru engine is 2hrs and do the install in about 4. My first time it took me 2 days but once I knew what I was doing it was a lot faster. Now the Subaru 2.5l engines had head gasket problems!
Chmura remind me not to ever buy anything from you. It's one thing to not know there is a problem and sell/trade something in, it's another to be dishonest and try to decieve the next owner be it the dealership or private sale.
That said head gaskets should be a non replacement item IMO. They should be good for the life of the engine. A well taken care of engine should go 250K without needed a HG. My father put 240K on a Toyota Cressida and he even over heated it a few times due to a radiator leak, the HG never let go. It was retired due to rust but the driveline was always reliable.
