Old 08-31-2020, 10:25 PM #1
Parkss1181 Parkss1181 is offline
Parkss1181 is on a distinguished road
06 headlight conversion
So I’m looking to get the 06 conversion and I have these headlights I’m looking to swap over and I’ve been reading the swap threads. My only question is since these are after market headlights am I just following the instructions for the swap with these aftermarket headlights? [ATTACH]
Thanks!!
06 headlight conversion-adjustments-jpg
2003 SR5 Sport Edition
Parkss1181 is offline   Reply With QuoteReply With Quote
Old 08-31-2020, 10:28 PM #2
Old 09-01-2020, 12:54 AM #3
JD914's Avatar
JD914 JD914 is offline
JD914 is on a distinguished road
JD914's Avatar
Yeah, it should be the exact same procedure.
04 V8 Limited
Lifted, lit, locked, protected
Coffee machine and crock pot equipped
JD914 is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 02:28 PM #4
SilverBullet01's Avatar
SilverBullet01 SilverBullet01 is offline
Real Name: Taylor
SilverBullet01 is on a distinguished road
Real Name: Taylor
if you get the chance I would love to see a before and after of the lights and their output. Did the 06 swap myself, but I might get rid of the lights I bought they keep getting moisture (and I want to do a proper LED retrofit in them)
'05 Galactic Grey Mica sport 4.7 4WD
SilverBullet01 is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 04:56 PM #5
Berty_K's Avatar
Berty_K Berty_K is offline
Berty_K has a spectacular aura about Berty_K has a spectacular aura about Berty_K has a spectacular aura about
Berty_K's Avatar
My two cents, so feel free to ignore.
If you're looking to upgrade your headlights and you're fairly handy, I'd recommend you do a full HID retrofit. Go buy a set of projectors off the retrofit source or lightwerkz and install them into your OEM headlight housing.
Cost should be similar (or cheaper) and you'll get even better output than stock or aftermarket '06+ projectors.
I ran a HID kit for about 2 years in my '08 before switching to a full HID setup (Morimoto D2S 5.0). Halogens w/ Stock Projectors < HIDs w/ Stock Projectors <<<<< HID retrofit.
The swap was pretty intimidating for me, but wasn't as hard as it seems once I got started. I knocked out a conversion for my 4Runner as well as my wife's CRV.
'08 Silver SR5 V6 4x4: OEM+
Berty_K is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 05:56 PM #6
With the DRL wouldn’t you want LEDS since you would be adding them to the headlights? Cause I’m pretty sure I read 05 and lower DRL are in the bumper and 06+ are in the headlights. So if you want both to work leds would be the way to go due to leds pulling way less amperage
Old 09-01-2020, 09:59 PM #7
Shiftless Joe's Avatar
Shiftless Joe Shiftless Joe is offline
Shiftless Joe is on a distinguished road
I've been running these for about a year with no problem, although I caulked the top and side areas heavily before install to prevent any water issues. Using standard Toyota bulbs for the high and low beams, and a Lasfit LED for the driving/turn bulb with a resistor on each side. You may have to de-pin your two wire marker light plug and shove them (and a hot tap from you DRL) into a three wire connector for this light to work, or get 6 wire taps and some pigtails and hardwire it.
Light output is comparable to new OEM.
Shiftless Joe is offline   Reply With QuoteReply With Quote
Old 09-01-2020, 10:41 PM #8
Az4runnin's Avatar
Az4runnin Az4runnin is offline
Az4runnin will become famous soon enough Az4runnin will become famous soon enough
Az4runnin's Avatar
This Does Not Work. Already tried and Nothing but Issues with Running DRL's in Bumper and 06-09 Headlights together.with LED's
2003 V8 Limited 4x4 Black. JBA UCA's, TRD Pro Wheels. OEM LED Tails, 2012 FJ Springs F/R 5100's F/R 1.75 Cooper AT3 4S 265-70-17. Bye X Reas, Wet Okole Seat Covers Weathertech liners.
Az4runnin is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 08:24 AM #9
Thank you for your input everyone. I’ve actually decided to just keep the headlights installed right now. They are the black housing SPECD Headlights and I can’t really find a reason to justify spending the money on these! Very much want the 06+ look as well as the grill upgrade but I’m gonna save the money and do those mods later on.
conversion , headlights , iphone , i’m , swap
Headlight Conversion BLKRUNNER 3rd gen T4Rs 42 02-03-2020 11:03 PM
06+ Headlight Conversion - Headlight Cutoff Gen4SR5 4th Gen T4Rs 5 05-24-2019 01:24 PM
HID Headlight Conversion zbeydoun 5th gen T4Rs 8 04-10-2014 05:02 PM
Headlight Conversion Kit H4 fj40er Classic T4Rs 2 09-10-2012 12:55 PM
06 headlight conversion wknd60 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 03-07-2008 12:47 AM
