Originally Posted by _chassis_
Something isn’t adding up.
Please provide this information:
- what did the radiator tanks feel like before you changed the radiator?
- what does the instrument cluster gage read for water temp?
- what do you mean by both tanks are not getting hot? What does not mean by your definition?
- have you run the interior heat at the highest temp and fan setting? What did you experience?
- did you open the radiator cap? What did you see?
- is the de-gas bottle (burp tank) full?
I just got off the road from 2.5 hours of highway driving at 75mph pulling a 3,300 lb boat. The radiator should be smoking hot, right? It isn’t. Both tanks are warm, arguably very warm. But not hot. I can touch them with my hand for as long as I like. Temp gage is dead in the middle between C and H. Burp tank is full. Radiator cap when removed shows a brim full radiator. Interior heating functions normally.
Please provide more information and post your findings.
- sorry didnt think to feel the tanks on the old radiator, thats why im asking others to feel theirs after a 20-30 minute drive.
- gauge reads halfway between cold & hot as it always has.
-didnt say "both" tanks are not getting hot, just the driver side. pass side gets very hot within ~15 minutes. driver tank & lower hose are cool after 30 minutes.
-yes, heat gets hot as normal... but temp & fan settings dont matter for coolant flow, coolant fully runs through the heater core regardless of fan/temp settings.
-i opened the rad cap & coolant is full to the top.
-overflow bottle is filled properly between the 2 lines.
thanks for the reply, maybe you didnt read the whole post but most of what you asked is stated in there. does any of the new info you asked about help anything?
im mainly looking for others to confirm what their driver side tank does after a 20-30 minute drive, which in 80* temps should be long enough to fully warm up both tanks. or thoughts on if it could be trapped air.
