Old 06-18-2019, 05:47 PM #1
trod0 trod0 is offline
trod0 is on a distinguished road
Anyone run different springs with 6112’s?
Has anyone ran different springs with their 6112’s? The springs they come with are 14in and I have a set of 16in Toytec’s that would fit the set up. Has anyone run 16in springs with them? Would the 2in spring be to much? Any experience or info would help. Thanks
trod0 is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 06:27 PM #2
Toyrundrive Toyrundrive is offline
Toyrundrive is on a distinguished road
Wouldn't that give you zero down travel?
Toyrundrive is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 06:37 PM #3
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
That depends entirely on spring rate. If it has the same spring rate as the factory springs then you will get 4" more lift at the same preload so yeah, no downtravel.
14" to 16" doesn't change anything. What are the spring rates? Why are you wanting to upgrade?
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 06-18-2019, 06:47 PM #4
Only reason would be is to run a full 3in up front. I believe they’re both rated at 600#.
Old 06-18-2019, 06:57 PM #5
That would give you 6" of lift and blow out your shocks if you actually used them hard
You might get 1/4 mile out of your CV axles.
You would murder your wheel speed sensor wires and brake lines
Get a top plate spacer
Old 06-18-2019, 07:14 PM #6
Inv4drZm's Avatar
Inv4drZm's Avatar
Your front lift is limited by the shock length, or the upper control arm contacting the coil or running out of joint movement. So no chance of hurting your wires or brake lines. Since these are the limits, when you lift a tire driving offroad your front end won't explode.
If I'm thinking correctly, since they are both 600#/inch springs they would still need preloaded the same amount to obtain the same amount of lift. Just the longer spring will keep the preload collar up higher so no real difference.
Unless you are running out of thread room below the preload collar and need a taller spring?
Old 06-18-2019, 07:19 PM #7
That’s what I figured, I’ll end up with top plate spacers. I was just thinking of the 16in springs on the lowest setting but it’s not worth the risk
Old 06-18-2019, 07:37 PM #8
I read 6112 and thought that was the code for the ome shocks, my bad. I don't have bilsteins.
Old 06-18-2019, 07:40 PM #9
Yep, you'd have a bad time if you could actually achieve 6" lift. I thought op wear referencing ome not bilsteins. Either way you're right you wouldn't destroy everything.
Old 06-19-2019, 06:55 PM #10
Inv4drZm's Avatar
Inv4drZm's Avatar
I did some more digging and it looks like 16" coils are for long travel coilovers, the ones for +2 or +3.5" wide kits. So they won't fit standard length control arms/coilovers. 14" is the max for standard width.
King 16" Coil Spring Pairs for 2.5" Coilovers
Old 06-19-2019, 07:37 PM #11
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I haven’t tried anything other than the included springs.
6112 has height adjustment using the spring perch. Wouldn’t the original spring with a 2” perch setting be the same as running a 2” taller spring with the spring perch in the 0 lift height position?
Old 06-19-2019, 10:44 PM #12
phqduphead's Avatar
phqduphead phqduphead is offline
Real Name: Kyle
phqduphead is on a distinguished road
phqduphead's Avatar
Real Name: Kyle
I put king 650# 14” on my 6112’s and had a 1/2” top spacer. I was getting around 3.5” lift and my cv’s we’re good even doing difficult trails. I do have the diff drop. I ended up putting icon extended travel 2.5’s on and don’t really notice a difference in off road capability. It does ride a little nicer on the highway though.
06’ Sport 4WD, locked on 33’s
phqduphead is offline   Reply With QuoteReply With Quote
16in , 6112’s , run , set , springs
FS Nor cal Bilstein 6112 600lb springs Karnivor707 For Sale: Suspension/Wheels/Tires 6 05-05-2019 10:02 PM
how do I acquire new 6112 springs only Mr Wolfgang 5th gen T4Rs 12 04-08-2019 01:45 PM
600# lift springs for 6112 struts Badmeat 5th gen T4Rs 7 05-10-2018 07:12 AM
Matching rear springs to Bil 6112 sport2004 4th Gen T4Rs 0 07-27-2017 02:41 PM
Bilstein 6112 Springs 5Sport 5th gen T4Rs 2 01-05-2016 09:21 PM
