Old 05-01-2021, 12:44 AM #16
TimeCrunch TimeCrunch is offline
Real Name: Mr.Crunch
TimeCrunch is on a distinguished road
Originally Posted by SA-Overland View Post
I have installed 7 sets of LT Doug Thorley headers on 4th gens. Stock suspension, body lift, huge suspension... they are all the same. Suspension and body lift doesn't have any impact on headers. They fit just fine. If somebody has to "dimple" them then they are installing them wrong. Edit: To ensure the steering coupling bolt doesn't hit, the entire coupling can be moved down to avoid the headers.
I was reading about bolt scraping in another thread too. I've installed zero so far, Thank You for the response. I know the suspension lift would have no effect. Just wasn't sure about the 1in body lift.
Do I need to buy anything to adjust the coupler? Will it just be apparent when I'm down there? Thanks again!
TimeCrunch is offline   Reply With QuoteReply With Quote
Old 05-01-2021, 09:12 AM #17
SA-Overland SA-Overland is offline
SA-Overland is on a distinguished road
A pneumatic air hammer with extended bits will help you greatly. To install the headers, you will need to separate the steering shaft anyway. The hammer just helps for adjusting when it's all back together.
Also, friendly tip, remove both motor mounts. I'm able to install headers in about an hour total by doing that.
SA-Overland is offline   Reply With QuoteReply With Quote
column , headers , long , steering , tubes
Doug Thorley Long Tubes! Mike07SE Engines / Suspension / Wheels / Tires / Audio / Accessories 49 12-19-2019 01:29 PM
FS: 1/2" Bodylifts for 3rd gens emelianenkov For Sale: Suspension/Wheels/Tires 258 01-22-2016 09:48 PM
FS: 1/2" Bodylifts For 03-09 emelianenkov For Sale: Suspension/Wheels/Tires 250 07-07-2014 12:12 PM
Long tubes? special_K Engines / Suspension / Wheels / Tires / Audio / Accessories 3 09-14-2013 07:38 PM
Finally Installed DT Long Tubes liqourish Engines / Suspension / Wheels / Tires / Audio / Accessories 5 10-14-2009 11:12 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
