Old 06-23-2019, 09:11 PM #1
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
Front sway bar link replacement - only in pairs?
About half the internet experts claim that front sway bar links should be replaced in pairs. Does anyone know what Toyota says?
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 10:04 PM #2
95supra 95supra is offline
95supra is on a distinguished road
no real reason to replace them in pairs other than they would both have the same amount of miles on them. you can just replace one if needed
95supra is offline   Reply With QuoteReply With Quote
Old 06-23-2019, 10:59 PM #3
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Anything suspension should be replaced in pairs. I don't think Toyota would bother documenting something like this when there are so many variables. You are just wasting labor money and creating the next failure point by replacing one.
Old 06-24-2019, 01:51 AM #4
Toyrundrive Toyrundrive is offline
Toyrundrive is on a distinguished road
When I break them I tend to only break one at a time, so I replace one at a time. However, I recently broke a link for the third time and removed the bar altogether. No major complaints. Can't drive it like a Supra anymore though...
Toyrundrive is offline   Reply With QuoteReply With Quote
Old 07-18-2019, 02:19 PM #5
2003-4x4runner's Avatar
2003-4x4runner 2003-4x4runner is offline
2003-4x4runner will become famous soon enough
If old and worn out, Replace in pairs.
Also, you don’t want one breaking off and damaging the CV boots. Front sway bar links are way cheaper then replacing a CV boot.
2003 V6 BLACK SR5 4X4-Runner
OB #1334
https://www.instagram.com/ob_1334/?hl=en
Dad's Travel Service.
We drive around till we find it. No map's needed!
2003-4x4runner is offline   Reply With QuoteReply With Quote
Old 07-19-2019, 06:41 PM #6
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
You can replace just the bad one and be fine.
There's no compelling reason to do both, but if one's bad the other could be close. At least check it.
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 07-19-2019, 09:25 PM #7
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
I've found that most things wear out in pairs anyway. And if you're going through the trouble of doing one it does make sense to do the other... however, this rule only applies, for me, when doing something that's just "had it's day and needs replaced"
Things that I broke... because of some change I made or just me hammering on it too hard, I would likely only replace the failed part.
For endlinks, it would depend on why it failed. End of life, replace both. If broke due to abuse, just replace the one that broke.
If broken several... may want to re-access the bigger picture.
Keros is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 02:58 AM #8
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
I removed my front sway bar and the links. Nothing to worry about in the future.
radlynx is offline   Reply With QuoteReply With Quote
Old 07-21-2019, 11:23 AM #9
waypoint's Avatar
waypoint waypoint is offline
waypoint has a spectacular aura about waypoint has a spectacular aura about waypoint has a spectacular aura about
waypoint's Avatar
Keros spelled out a reasonable approach. The swaybar is a spring, similar in function to a torsion bar. It's purpose is to transfer force from one wheel to its companion on the other side of the vehicle. This means that as one endlink has upward force applied to it during cornering, the opposite side has downward (opposite) force applied to it. The endlinks work as a team.
So, as Keros described, for normal wear I replace both endlinks. If one side is failing for some other reason e.g. being struck by a rock during off-roading, the broken one gets replaced...and I'd investigate armor options to protect it.
If the swaybar is bent, it will preload both endlinks (in opposite directions) and accelerate wear. It may be necessary to remove the swaybar and check it for straightness on a level surface.
waypoint is offline   Reply With QuoteReply With Quote
bar , front , links , pairs , sway
Front Sway Bar Link Upgrade? NEKExplorer 3rd gen T4Rs 24 04-13-2016 02:09 AM
Front sway bar end link question lcbjr77 4th Gen T4Rs 1 12-20-2015 10:06 PM
Front Sway Bar End Link sanderson5 3rd gen T4Rs 3 02-10-2015 10:46 PM
99 4 Runner sway bar link replacement pghchuck 3rd gen T4Rs 1 04-17-2013 10:02 PM
Sway bar repair and link replacement Nelsonmd 3rd gen T4Rs 2 08-30-2010 07:55 PM
