Old 06-24-2019, 10:04 PM #16
RobD RobD is offline
RobD will become famous soon enough RobD will become famous soon enough
Originally Posted by Bluesky 07 View Post
I got the Toyota evap cleaning kit and while I know this little hose under the hood dripping water must be the condensation drain, my cautious side says, “Hey, why not ask before blasting a whole can of cleaner up in there?”
So this must be it, right?
That's where I blasted mine. I recommend pinching the drain tube around the hose you're going to shove up there. Mine started firing cleaner back down it before the can emptied. Have a container of some sort to catch the stuff that comes out of it.
RobD is offline   Reply With QuoteReply With Quote
Old 06-24-2019, 10:08 PM #17
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Did the cleaner today and was a bit underwhelmed, but I suppose it’s a good thing when a ton of disgusting gunk doesn’t come out of your HVAC system. To anyone considering this, I’d say save your time & money for something else unless you’re having symptoms like A/C odors or a blocked drain.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 06-24-2019, 11:08 PM #18
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
Thanks, I really appreciate that. What size? Does it slip into or over the current tube?
5/16 I believe. I used a barb connector and hose clamps to connect the two lines.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
Old 06-24-2019, 11:30 PM #19
Seymore Butts's Avatar
Seymore Butts Seymore Butts is offline
Seymore Butts will become famous soon enough Seymore Butts will become famous soon enough
I used this kit on Saturday and the draining fluid looked a little yellow, just like in the photo above. There was a strong ammonia smell from the foam, so I think it is meant to be only an antimicrobial agent for treating musty smells.
The second can, which one is instructed to spray 45 seconds during three different vent settings, only lasted for two 45 second bursts. Reduce the spray time to 30 seconds if you want to use it for all three vent positions.
This kit completely eliminated the musty smell from my AC system. For how long? We'll see.
Here's Toyota's video on how to use the two can kit:
YouTube
Seymore Butts is offline   Reply With QuoteReply With Quote
Old 06-25-2019, 07:29 AM #20
Bluesky 07's Avatar
Bluesky 07's Avatar
Thanks, let me try some tubing I found in my garage. If it’s not suitable, I’ll definitely take you up on this.
Old 06-25-2019, 07:35 AM #21
Bluesky 07's Avatar
Bluesky 07's Avatar
YouTube
Thanks for the heads up. I wondered whether it would be enough after watching that video when I bought the kit.
It’s interesting as well that the video instructions differ from that was on the foam can. The video says to do it in half can increments (guesstimating what half is I suppose) while the can says to fire off the whole can. It didn’t seem to me that is much liquid drained out as foam went in, but there’s no way to know.
Old 06-25-2019, 06:08 PM #22
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Once the foam reverts back to liquid the volume would be much less.
2004 Limited V8
Old 06-26-2019, 10:48 PM #23
Bluesky 07's Avatar
Bluesky 07's Avatar
Extended the A/C drain line today.
Before
Gear (+ a couple of zip ties)
After - from above
From below
Costs less than $5.
@JONBOY345 , thanks again for offering the fuel line. Found some tubing in the garage.
Old 08-09-2023, 07:46 PM #24
JustRidin JustRidin is offline
JustRidin is on a distinguished road
Just did this today. Thanks for bringing this up.
JustRidin is offline   Reply With QuoteReply With Quote
blasting , condensation , drain , side , “hey
Craigslist Humor sambishop 3rd gen T4Rs 20 12-09-2022 10:53 AM
Condensation on ac drain hose? tombob55 4th Gen T4Rs 0 08-18-2017 09:43 PM
A/C condensation drain? Zuke 4th Gen T4Rs 3 06-22-2011 10:34 AM
I got hit by the Good Humor man! mjfrank 4th Gen T4Rs 5 11-06-2007 12:59 PM
War Humor Iman74 Off Topic 0 10-01-2004 08:04 PM
