Old 11-14-2023, 06:26 PM #1
TeryT's Avatar
TeryT TeryT is offline
TeryT is on a distinguished road
TeryT's Avatar
Master Cylinder probably Leaking into Booster
I'm pretty sure my master brake cylinder is leaking into the booster. Earlier this year I kept having to add fluid on my 2003 V8 (240 K miles), especially when driving in the mountains (because light was coming on), but I could find no apparent leak anywhere. The shop I took it to said it was just the rear pads worn down . . . which didn't make sense, but I had them replaced anyway in July. It seemed like the leak stopped (or maybe I stopped paying close attention) at that point.
Just this past week the light came on again and same thing - no apparent leak anywhere, and no loss of pedal or braking.
I now think the master is very slowly leaking into the power booster.
So has anyone had this issue and has replaced the master cylinder on a 4th gen (V8)? What kind of cost am I looking at?
2003 V8 4x4 Sport 4Runner TRUCK OF THE MONTH SEPT. 06 - still tows a 25' ultralite Rockwood 2502 travel trailer all over creation!
MODS: GlowShift tranny temp gauge; Hayden 526 tranny cooler/fan combo; Hopkins Insight brake controller; Bilstein 5100 shocks
Hensley Arrow hitching system - quite simply the best for zero sway towing!
TeryT is offline   Reply With QuoteReply With Quote
Old 11-15-2023, 08:08 PM #2
MikeinNH67's Avatar
MikeinNH67's Avatar
There is no vacuum booster on these trucks like what there used to be. These use a motor for pressure so there's no way the fluid is being sucked into the engine, unless I'm mistaken. If you are losing it then there must be a leak somewhere so you should see the fluid under the car or behind the brake pedal.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 11-15-2023, 09:31 PM #3
TeryT's Avatar
TeryT's Avatar
Yeah, and there's the rub - I've been under it, as well as a mechanic and an oil tech a number of times over the past 4-5 months, and no one sees nutin!
Old 11-16-2023, 02:53 AM #4
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
As mentioned if the maser cylinder is leaking past the piston there would be fluid coming out the back of the master cylinder, you won't find that leak from under the vehicle, you need to look under the dash where the master cylinder push rod connects to the brake pedal, you my have to pull the rubber boot off the back of the master cylinder or not if you losing as mech fluid as you say it maybe leaking past the boot.
2004 Limited V8
Old 11-16-2023, 12:22 PM #5
TeryT's Avatar
TeryT's Avatar
I've looked at both sides of the firewall and haven't seen anything. I'd think with that much fluid I'd see some evidence, even without pulling the boot off.
The shop said next time the indicator light goes off to bring it in and they'd do a pressure test on the master.
UPDATE: Just checked again and finally see a leak coming down the frame near the firewall - so finally the mystery is solved! The next question is can the master cylinder be rebuilt or better to go with new one?
Old 11-16-2023, 04:22 PM #6
MikeinNH67's Avatar
MikeinNH67's Avatar
Seems you have a trail to follow now. Can you tell exactly where it's coming from? Maybe take a pic of the area to share? As far as I can see you can't buy just part of the expensive assembly but I thought I've read that there's rebuilt units. Would stink to pay a grand for what may be just a bad seal.
I dug around a bit and found these posts. There's probably more.
Brake Master Cylinder Leak
anyone have electric brake booster problems/failure?
2003 v8 4runner ABS Pump Problem! Any Solutions?
Mike
03 4runner Limited
booster , cylinder , leak , leaking , master
Master Cylinder, Seal, or Booster PatrickStapler 3rd gen T4Rs 5 08-10-2020 03:12 PM
Brake booster or master cylinder Wakko 3rd gen T4Rs 5 06-26-2019 07:56 PM
Master cylinder/ booster question mmml4 3rd gen T4Rs 10 02-28-2019 08:56 PM
3rd Gen Brake Booster/ Master Cylinder Question. UnderFire 3rd gen T4Rs 15 03-02-2015 06:58 PM
brake booster or master cylinder oaknapa098 3rd gen T4Rs 4 11-27-2011 07:42 PM
