Old 06-30-2019, 10:56 PM #1
charleypartanna charleypartanna is offline
charleypartanna is on a distinguished road
Sunroof gasket needs replacement: any tips?
Hi folks!
My sunroof gasket on my 2008 Unlimited seems to leaking. I thought it was the windshield that I recently had replaced, but I had the leak evaluated by the shop and they showed me why they believe it’s the sunroof (which sounds/looks accurate to me).
The gasket is original (2008) and the California sun has undoubtedly taken its toll. It is shrunk on one side in particular which leads to water running into the channel. The leak only seems to occur during automatic car wash/dryer, but I would like to address it nonetheless.
Anyone ever replaced the gasket? If so, any tips? I’m handy and like working on my cars, but I’m guessing this job may be a pain and I’ll be willing to pay to have it done. Any other parts you’d recommend replacing as long as I (or someone else) is going in there?
Thanks all!
Charley
2008 Limited Edition, Shadow Mica. OME 3" lift (diff drop, rear guards). BFG AT2 275/65R18. PFran interior LED.
charleypartanna is offline   Reply With QuoteReply With Quote
Old 07-01-2019, 11:55 AM #2
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Originally Posted by charleypartanna View Post
Hi folks!
Thanks all!
Charley
Pretty sure the gasket isn't your problem, there are four drain lines up there, one for each corner. If you are leaking from the sunroof, check the drains first, they can clog with dirt and leaves and such
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 07-01-2019, 02:01 PM #3
81runner, good suggestion. However, that’s not the issue. We cleared and tested the drain lines — they’re all clear.
Since posting this, I’ve read some more posts on this topic. It sounds like there are two options. Buy the expensive replacement part (integrated glass and gasket). Or seal it shut. I’m probably going to seal it, thinking black RTV might work well.
Any other suggestions?
Thanks all,
Charley
Old 07-01-2019, 04:08 PM #4
villaphoto's Avatar
villaphoto villaphoto is offline
villaphoto is on a distinguished road
villaphoto's Avatar
I ran into this issue with my 4th gen as well. I popped into Rancho Toyota Recycling up in Rancho Cordova and found a new sunroof assembly for $250( dealer wants approx. $600 just for the glass). I dropped the headliner installed the new assembly in about 3 hours, which I could do faster now that I know what I'm doing. After that it was like having a brand new sunroof in, no leaks or anything.
villaphoto is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 12:05 AM #5
Snagglepus Snagglepus is offline
Real Name: Chuck
Snagglepus is on a distinguished road
Real Name: Chuck
Moon Roof Gasket
Yes, the rubber seal is part of the frame and glass. I don’t think purchasing just the gasket is possible. I have a 2007 which was leaking and causing the frame to rust. After replacing the frame and glass with previously owned one from the local junk yard I realized that maybe my original glass had not been synced correctly and took years of unnecessary moisture. I would check your local yard for a match and replace it (no need to take out the headliner-just 4 star screws) and then follow the sync procedure to be sure it closes as designed. If you find a used frame and glass without any rust you can be sure the gasket is a good one and then you just have to sync it. My local source sold me the entire moon roof for $150-even though I only needed the glass/frame. I left the motor and other parts for the next poor sap. Ha.
Snagglepus is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 02:39 AM #6
MY06T4R's Avatar
MY06T4R MY06T4R is offline
Real Name: @professorj2
MY06T4R is on a distinguished road
MY06T4R's Avatar
This is how I fixed mine
I went to the local junk yard in Columbus, Ohio and pulled and bought the sunroof glass only, took about 5 minutes and they charged my about $20. When I got home it took about 5 minutes to replace. Mine was not leaking but did look like crap from the sun wearing out the seal. You won't even have to take the headliner down to replace the glass. If someone has not done a write up, I can do one with pics or video and details.
06 V8 SPORT, TOYTEC BOSS 2.0 LIFT, JBA UPPERS, DIFF DROP, SWAY BAR DROP & RELOCATE, 2010+ POWER STOP CALIPERS, ENERGY SUSPENSION BUSHINGS THROUGHOUT, URD OFF ROAD Y-PIPE, GIBSON STAINLESS CAT-BACK, URD FUEL PUMP WITH EXTERNAL FILTER, K&N, XD RS3'S NITTO 255/80'S & MORE
MY06T4R is offline   Reply With QuoteReply With Quote
Old 07-17-2019, 11:52 AM #7
AZ07Runner's Avatar
AZ07Runner AZ07Runner is offline
AZ07Runner is on a distinguished road
AZ07Runner's Avatar
I don't have much rain here in AZ, but I found that the sunroof leaked only during the automatic car washes, too. I saw that the high pressure blower to remove water was pushing the sunroof down and water was getting in. Other than that, no leaks. Quite possible you need a new gasket, but maybe just don't use the car washes. I stopped going due to this.
07 Limited V8 Titanium Metallic
Bilstein 5100s x4, Fronts set on 0 with OME 885s, Sway-A-Way 1.5 rear coils, JBA UCAs, '12 Trail wheels, Cooper AT3s 265/70/17, Mobil1 0W40, Amsoil Severe Gear 75W90 and SS ATF.
(Previous truck: 1993 Toyota DLX, V6, 4x4, Xcab, 5 speed, Pewter Pearl - owned from day 1)
http://www.toyota-4runner.org/4th-ge...ml#post2069269
AZ07Runner is offline   Reply With QuoteReply With Quote
Old 09-05-2022, 01:29 PM #8
miftah miftah is offline
miftah is on a distinguished road
MY06T4R , I request you to post the pics of the repair if you still have the pics and/or video.
miftah is offline   Reply With QuoteReply With Quote
Old 07-20-2023, 01:34 PM #9
eshin84 eshin84 is offline
eshin84 is on a distinguished road
Hi MY06T4R, I was wondering if you would be able to post a write up, pics, or video detailing how to replace the sunroof glass on a 4th gen 4Runner without having to take the headliner down? Thanks in advance!
eshin84 is offline   Reply With QuoteReply With Quote
Old 11-16-2023, 11:47 AM #10
MY06T4R's Avatar
MY06T4R's Avatar
I will try to get something posted here shortly, sorry for the delayed response, I didn't see my notifications until today.
gasket , i’m , leak , replaced , sunroof
Any tips on cleaning headliner/sunroof liner? StreetCreeper 3rd gen T4Rs 31 02-16-2021 06:48 PM
2005 sunroof/moonroof rubber/gasket/seal Yaff 4th Gen T4Rs 3 02-11-2011 01:07 PM
My Timing Belt and Valve Cover Gasket Replacement Tips yotaah 3rd gen T4Rs 6 12-07-2010 03:24 PM
Outside mirror replacement tips? Martinjmpr 3rd gen T4Rs 0 09-17-2009 01:52 PM
Sunroof Gasket Lubrication Atomic 4Runner 4th Gen T4Rs 3 01-15-2007 09:01 PM
