Hey
The plastic body parts could use a face lift.
What have you used to paint yours?
I am looking for some thing that wont peel off right away.
I have not had much luck in the past with painting plastic or abs which ever they make the bumpers stuff out of.
Thanks
03 Toyota 4Runner 4x4 V8
96 Toyota T100 4x4 150k miles (traded)
97 Toyota Corolla CE 167k miles (totaled)
94 Toyota p/u 4x4 150k miles (traded)
87 Toyota p/u 270k miles (sold)
Some manufacturers make paint for the specific application... Dupli-color is one that has paints designed for bumper covers and plastic trim, but I'm sure that others are available. As with any paint job, preparation is key. Follow the paint manufacturer's recommendations, but you generally want to evenly scuff the surface for improved bond, clean the surface so it's free of all dust and oils, prime, and paint. Something else to remember is to take your time... multiple smooth, even, LIGHT coats will typically produce the best results. Hope that helps some.
__________________ Doozi's 2006 Sport Edition V6 4WD - Titanium Metallic - purchased 09-13-10
Dobinson's F: C59-302/GS59-220, R: C59-677V/GS59-575 / LR UCA's / Medic links / LT285/70R17 DuraTracs on Countersteer Type-X wheels / WeatherTech DigitalFits and Window Visors / Rear Diff Breather Mod / J.A.'s Fog Light Mod / Centric Premium rotors w/ Akebono Pro-Act Ultra Premium pads / LED interior lights / HIDs (4500k lows) / Man-A-Fre engine+tranny skids / RCI MetalWorks T-case skid / B.A.M.F LCA skids / CBI front/rear, Sherpa Equipment Company roof rack, WKOR sliders welded on, Panhard Correction Kit... Lovin' it!
It depends on how good you want the finish. Do you want to sand out scratches prime then paint or just paint over the existing paint and scratches?
If you want to do a good job sand out the scratches with 320/400 grit sand paper then prime (two coats). Sand the primer with 500 grit (get the orange peal out) then paint. As for paint your can get your paint code off the drivers door (ex 1E7, 4Q2, 1F7, 202) Toyota colours. Go to a local paint shop and ask for single stage paint (the clear is mixed in with the colour) very easy to spray. Do two coats.
If you don't want to prime and just paint over the old paint all you have to do is scuff the paint with red scotch brite pad (automotive store should have it) then paint ( two coats). Make sure to sand your edges well so there is no peeling issues
I painted a car a while ago and for the plastic they have a "flex" agent or an additive, so when the plastic moves the paint moved too. Make sure to look for that. I don't remember what my buddy used a few years ago.
And then some.
Does any one have any helpfull info?
Did you look at the link I left?
First lightly sand the plastic with 400 grit (take off the shine), DupliColor has an Adhesion Promoter used on plastic, then DupliColor Filler Primer, DupliColor Perfect Match (look for your color code) and finally DupliColor Clear Coat.
I painted my side mirrors and I must say it looks good and it passed the Wife Test!
Good luck.
2016 Trail MGM. P265 70/17 Falken Wildpeak AT3W. Matte Black TRD Wheels. Leveled with 2" spacer. Heated Front Seats. All LED interior. Mud flaps deleted. TRD Air & Oil Filter. TRD Oil Cap. FJC Shifter. Subaru Kicker tweeters. Hikari LED Low Beam. Cougar Motor LED DRL/High beam. Hood "scoop" and lower door wrap.
2006 SR5 4WD V6 - Owned from July 2009 with 38,200 miles to March 2017 with 150,100 miles.
I'm reviving this thread in the hopes that someone has actually done this (as opposed to offering general tips on how to paint plastic) and can offer some advice on which product to use, color matching, process followed, etc. I bought a used 2003 and I can live with the condition of the cladding, but unfortunately the previous owner replaced the driver side rear corner of the bumper with an unpainted replacement part. Rather than having to buy a new part, I was hoping I could paint it and was looking for tips.
