Old 07-25-2020, 11:06 AM #16
bring_it_on's Avatar
bring_it_on bring_it_on is offline
bring_it_on will become famous soon enough bring_it_on will become famous soon enough
Originally Posted by j4x4v8 View Post
I’m thinking about an eventual dual battery setup (dual Group 34 AGM with this Offgrid4x4 kit).
To alleviate the concern you brought up I was going to get an 180amp ‘high power’ alternator (like this one). IIRC the 4th gens alternators are 130amp. I’m wondering if the 50 extra amps is enough to really make a solid difference.
If you are going for a dual battery set up, then a DC to DC system will ensure that your house battery is adequately charged with the correct profile for it (AGM or Lithium). The Red Arc 25 Amp system also has an MPPT built in (which would be $80-$120 as a stand alone product) so it is essentially two devices in one. OffGrid4x4 can probably build the same kit for you with a DC to DC charger. It may cost a $100 more but still a fair bit cheaper than buying a new alternator.
2019 TRD Off Road| 285x70xR17 Falken WP AT3W| Dobinson C59-314/GS59-700 & C59-505/GS59-701| Total Chaos UCA| RCI front skid plate (steel)| C4 Fab. Low Pro. Bumper| Extreme LED Light Bar (bumper)| Baja Designs Squadron Sport Fog Lights (Amber)| Bud Built Ultimate Rock Sliders| Front Runner slimline II full-size Roof Rack with Wind Fairing| C4 Fab Summit Hatch Ladder| ARB CKMA12 Air Compressor| Xenon Depot HID Low Beam Head Lights|Renogy-20 Amp DC-DC Charger|Battle Born LiFePO4 Auxiliary Battery| Goose Gear rear drawer system (8")|National Luna 52L Legacy Fridge/Freezer| Alu-Cab tilting fridge slide (Small/Medium)| ROAM Adventure 8' Awning
bring_it_on is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 11:59 AM #17
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
If you are using anything other than two starter batteries where an ACR would be more than adequate, especially a mixed chemistry like AGM or Lithium, then you have a very strong case to use a DC-DC charger.
I still feel there are better options to consider than the RedARC.
If you accidentally draw down the system killing both batteries, the RedARC solar charge controller won't be able to recover system because it needs 12v DC to function.
Personally I like having separates, especially when they provide more options and control, along with data and monitoring capability.
Even with the system completely dead the Victron MPPT would be able to recover and put charge back into the batteries. I use their DC-DC chargers too and together I find them to be a better option.
The Victron controller also has bluetooth for monitoring. You can see trending and live data for solar and battery monitoring. I like to nerd out on this stuff so I find it pretty useful. Also eliminates to need for a bunch of battery or voltage monitors.
Old 07-25-2020, 03:41 PM #18
Quite a few good DC to DC systems out there to pick from. The reason I mentioned Red Arc was because the dual-battery kit builder chosen here uses the RA 1225 in its system builds.
I actually have the Victron smart Orion shortlisted for my application in case I ever need to move from a single large battery to a dual battery setup on my rig over time. Since I’ve sent 4 gauge wires back to the trunk all that will entail is a lithium battery in a box with those wires running into the charger instead of the fuse box. So an anderson plug into the charger will be all that I need and can disconnect when not in use and remove the battery box. Hoping that with a solar panel and a 92 Ah main battery I won’t need it but if I begin to do long duration remote trips it’s good to know that there is a relatively easy fix that I can wire up easily. Now just waiting for lithium batteries to get cheaper
Old 07-25-2020, 10:06 PM #19
Bumbo's Avatar
Bumbo's Avatar
Nice! Sounds like you are on the right track. I went the DIY route for the lithium batteries and save a lot of cash.
My favorite thing about using a DC-DC is it allows you to move away from a 12 volt system.
I find very little need to stay 12v native, especially if you want to move into a lithium setup. The most power dense cells available (like 18650) have a voltage that falls perfectly into a 24v range, so that's what I have been using.
I have a traditional dual battery, but I also run a portable 24v setup in my 4Runner using the Victron Orion 12v to 24v DC-DC, but have plans to build it into the little cubby space above the passenger rear wheel well.
Lots of gear is already 24v compatible, most fridges are 12/24v, most LED lighting works off 24v, Viair and ARB both make 24v versions of air compressors, better inverter choices, more efficient, and smaller cabling requirements for the same power.
I know it's a little odd to move away from 12v but i've tried it both ways and it's worked out well.
Old 07-26-2020, 10:36 AM #20
I've considered that, just as a project to feed my curiosity as much to power the rig. I hope competition puts some downward pressure on prices and 75 Ah 12V LIFEPO4 can be had for around $500 in the near term. I don't mind spending that or slightly more if that means I get a 7 or 10 year warranty and roughly 3000 cycles out of it.
I have one question on the portable systems that one builds. I know on a permanently mounted dual battery setup, we need to ground the aux battery. If I were to do it I would just run the negative cable to the same chassis ground where my starter battery is grounded. But suppose I have a lithium battery in a removable box. I realize that the DC to DC is going to be grounded via the starter battery and linked up to the aux battery in the box but is that all that is required? Do I need to create a chassis ground for the portable unit on top of that?
Old 07-26-2020, 07:40 PM #21
Bumbo's Avatar
Bumbo's Avatar
It's easier to just think of portable systems as isolated. Like a flashlight or any other battery operated device.
The only time you really chassis ground is on systems using an automatic charging relay. When the ACR is engaged, both batteries are connected in parallel. They share a common ground and positive, and is charged by the same alternator, and participate in the same loads when combined.
Systems charged by a DC-DC are not required to share a chassis ground. The batteries are not in parallel, which is why recommended when dealing with AGM voltages, other chemistry, or other system voltage.
Many of the Orion models are completely isolated, these are the ones I use for various reasons. The flow of current is generally directional and is limited by the DC converter. The biggest downside to isolated converters is efficiency. They might be 88% efficient where a non-isolated converter could be 95%.
You can achieve your goals now at that price if you were to DIY ~ $500/kWh, using brand new LifePO4 cells.
Batteries are fun, I like that you considered it. For me, building has less to do with cost, and more to do with the shape of the battery and where you can make it fit.
Either way, have fun, sounds like you are on the right path.
Old 08-15-2020, 09:12 AM #22
So I'm getting ready to order my Victron smart MPPT (75/15) given that my rig is now all wired up to accept it and a fridge. Do you think it is necessary to also have the Smart Battery Sense to allow the MPPT to monitor the temperature at the battery and adjust charging accordingly? I'll be charging the starter battery with the MPPT located all the way at the back and will be backfeeding solar charge to the battery via the blue sea fuse block I installed in the rear jack storage area.
Old 08-15-2020, 02:06 PM #23
Bumbo's Avatar
Bumbo's Avatar
It's one of those items that would never hurt, it will be more accurate... but personally I don't use them.
1. If I need to adjust something, ill do it manually after taking measurements myself.
2. We are not pushing such a high level of current where line resistance become a huge concern.
You can always add one down the road if you want it.
Old 08-15-2020, 03:34 PM #24
Thanks! I'll hold off on it for now and can plan to upgrade to it in the spring when I install a larger starter battery.
Old 08-29-2020, 03:54 PM #25
So getting ready to build my auxillary battery set up. Should get the battle born 50 Ah on Monday and have most of the other stuff delivered on expected soon with the exception of the victron smart shunt which is out of stock pretty much everywhere I looked (expected mid September ship date).
My plan is to either source a box or look into a wooden box built to size with some marine carpeting. Trying to avoid the latter so will go down to the hardware store to see what off the shelf tool boxes can be re-purposed. I had a group 24 NOCO battery box sitting with me but it doesn't look robust enough to last a long time. Interested in the Rigid and Makita options so will check them out. They are a lot bigger than a battery and the fuse block set up but if they are robust enough for this purpose I might just also mount the charge controller in there though the DC to DC is going to be vehicle mounted.
Would love to here if ya'll have any recommendations..Here's a rough outline for sizes -
- Battery dimensions - 6.75 x 6.88 x 9 (inches)
- Fuse block dimensions - 3.5" x 3.5"
- Victron smart shunt - 4.5" x 2" x 2"
Would prefer to mount the battery right side up as that takes the least amount of width in the box. So basically am looking for a 12-13 inch wide box with a foam covered wood acting as a separator that snugly holds the battery in place. The remaining space is where I'll mount the fuse block and the shunt. The top needs to have some room to clear a terminal fuse and also enough gap to accommodated a flush mounted breaker on the lid.
Would love some ideas here on what off-the shelf storage system can be re-purposed..
Edit: The 22" tool box's are just too big even if I leave room for an additional 50 Ah battery down the road. The only viable medium sized tool box that I really liked was the Milwaukee but at 16" x 9" it is also a tad bit too larger. The NOCO Group 24 is probably the smallest I could comfortably squeeze in the battery, fuse block, shunt and wiring but there is really nothing, with higher quality, that works in that form factor. I was able to get a great deal on the Milwaukee because of a few dings and scratches (right about where I plan on installing a circuit breaker ) so going with that. Will follow up once I'm into the build..
Some advise on how best to secure the battery inside would be very valuable given I'll have more real estate than the battery (for room to grow).
Old 09-05-2020, 05:05 PM #26
Just finished wiring up my DC-DC charger and cabling (still need to mount a housing/holder for the Anderson connector when not in use). Just using a cable cuff for now until I figure out a proper way to house the wiring and connector. The real estate above and to the right of the charger is reserved for a victron phoenix inverter in the future since I don't need the portability of an inverter so it won't be in the box.
Now on to building out the battery box and then mounting the solar panel
Dual Battery Vs. Portable Battery-img_3481-jpg  Dual Battery Vs. Portable Battery-img_3482-jpg
Old 09-18-2020, 07:51 AM #27
Here's my completed (still need some aesthetic improvements but overall it fits and checks out) portable auxiliary battery. Relatively simple to put together. 50 usable Ah (LiFePO4), 20 A DC-DC charge capacity, 10 Amp MPPT built in. My DC-DC is outside the vehicle but the box can accommodate a Victron 18 or 30 A DC-DC unit.The battery has a max continuous current of of 60 amps.
2 Anderson SB50 connectors (one dedicated for unregulated solar) and 2 Powerpole connectors along with a USB type C, QC 3.0 port, one cigarette lighter port and a couple of 2.1A USB ports. The USB Type C/QC port has a small voltage read out but the box has a built in Victron Smart Shunt so I get capacity use data via bluetooth so didn't really need that feature (type-c ports are really hard to find). Choice of materials and components was in part driven by stuff that I had already purchased for a more standard dual battery installation (another G-34) which I chose to reuse for this instead of return. I had initially thought about building my aux box around a Trojan 100 Ah deep cycle AGM battery but that would have entailed a larger box, which would have weighed closer to 80 lb and would not have been practical or portable. My current setup has about the same usable battery capacity and weighs only 26.4 lb.
My next DIY project will be to do something similar to @Bumbo and build a DIY LiFePO4 battery from raw cells and BMS. I reckon I could fit about 100 usable Ah of capacity into the same form factor though safely securing the system into the box (the current battery fits snug and will survive off-road abuse) will be a challenge.
Old 03-06-2021, 10:57 PM #28
4RunAmok's Avatar
4RunAmok 4RunAmok is offline
4RunAmok is on a distinguished road
4RunAmok's Avatar
I really dislike hard sided panels for mobile use.
You should consider flexible panel... they make for a decent middle ground. They do cost a little more and are not as efficient, but they pack away nicely.
I have a 60 watt folder and it easily keeps up with my fridge and tops off the battery.
Mine stays up there 100% of the time, requires no setup/tear down, and keeps solar going into the battery all day long, even while I run into 7-11 or the grocery store.
Only gripe I have is I have to hop up on my sliders once a month or so, and make sure it's clean
Mitch - Build Thread
Silver '06 4Runner V6 Sport Edition 4WD
Certified Emergency Vehicle Electrical Technician/12 Volt Vehicle Upfitter
4RunAmok is offline   Reply With QuoteReply With Quote
Old 05-21-2022, 07:05 PM #29
formerly formerly is offline
formerly is on a distinguished road
A bit of a thread jack on someone's old thread here, but...
I'd like to run a 100 watt appliance (Starlink) for 8+ hours a day. What would it take to do that?
I installed a group 31 battery last year but don't have any additional accessories yet. My x2power group 31 battery is 100ah. So thats 12v X 100ah = 1200 watt hours, right? Is there a significant loss for running an inverter to get 120v?
We plan to be driving several hours every other day, on average. We likely will not always need to run the starlink during the day, but need the option.
I'd like to avoid solar if possible.
2016 Trail
formerly is offline   Reply With QuoteReply With Quote
Old 05-23-2022, 12:39 PM #30
Bumbo's Avatar
Bumbo's Avatar
Did you get the 100 watt value of spec off the spec sheet, or actually measure it?
Chances are that is the peak load (during transmit), not the RMS load, which would work in your favor in terms of sizing.
Your rough math is correct... 12v x 100ah = 1200 watt hours total capacity.
AGM; Your cycle depth should be half that, so 600 watt hours usable. Deeper discharge you will start to expedite reduction of service life.
DC to AC conversion efficiency is generally 80-90% efficient depending on the size and quality of inverter. Above 90% is generally found in VERY good efficient units that are sized correctly.
If you have big inverter, you can always add a small one to supplement small loads.
The Starlink equipment probably runs on DC power...? Check the wall plug output voltage. If so consider using a DC-DC converter and pickup some efficiency there.
Example of small inverter and DC-DC converters.
https://www.victronenergy.com/upload...-1200VA-EN.pdf
DC-DC converters - Victron Energy
Best thing to do is meter actual power consumption over a 24 hour period of normal use, and then size the battery accordingly.
apex , battery , dual , power , things
Portable "dual battery" for fridge Bumbo General Discussions 12 09-24-2018 12:03 PM
Anyone look at these portable box dual battery setups?? stephan07 5th gen T4Rs 10 01-29-2018 07:39 PM
Cheap Dual Battery, Battery! SirWilliamGoes General Discussions 21 05-30-2017 10:59 PM
Portable second battery setup? Swarty 5th gen T4Rs 11 07-23-2016 02:04 PM
Multi Battery Isolator and Dual Battery Selector, $60 - Pocatello, ID tjhaf2007 For Sale: Non-T4R Items 17 10-16-2013 11:00 PM
