Old 07-07-2019, 03:20 AM #1
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
Frequently breaking rear sway bar - Any solutions??
So, recently observed my rear sway is broken yet again, i dont wheel, though go offroad infrequently to exercise the 4wd, i have rancho quick lift struts with 1.75inch lift at the front, and 1.5inch lifts at the rears.
am puzzled at the frequent breakage, so my questions are
1. Could i weld the broken sway bar and reuse?
2. Are there beefier sway bars i cud install, as i noticed the sway bar is just a hollow metal tube
3. If the above 2 scenarios are wrong - ie would transfer the stress to the next weaker link. what is the next weaker link that this stress would be transferred to???
4. I am not comfortable running without rear sway bars, cos i pulled off/broke one of my rear brake lines last time, due to too much articulation -
Frequently breaking rear sway bar - Any solutions??-img_20190627_195100__01-jpg
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 08:41 AM #2
Trumpet Trumpet is offline
Trumpet will become famous soon enough Trumpet will become famous soon enough
Had a similar issue on a Subaru, yeah I know
Ended up using a oversize 22mm VS 19mm diameter sway bar. Then ended up replacing the sway bar links annually. The increased stiffness really helped handling though.
Regarding yours, there has got to be something going on for two stock bars to fail. I'd look into that before putting another sway bar on.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
Trumpet is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 08:57 AM #3
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
addco 2003-2009 Toyota 4Runner, 2005-2013 FJ Cruiser - ADDCO 2301 Rear Sway Bar (7/8 Diameter) [2301] | $129.95 | SD Truck Springs | Leaf Springs, Helper Springs and Suspension Parts
chaz is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 11:14 AM #4
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
this is just a guess but that 1.5" rear left could have offset your rear axle just enough to put that pressure on the sway bar links were they are breaking. An adjustable aftermarket panhard bar like this one would align the rear axle as it was before the lift.
RM43014 - Rokmen Adjustable DOM Panhard Bar for 03+4Runner / 07-14 FJ Cruiser
jrm is offline   Reply With QuoteReply With Quote
Old 07-07-2019, 03:22 PM #5
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
I have the ADDCO bars on my V8 '05. They are monstrously stiff. They give the truck way more confidence than it is due in corners.
My passengers in the rear seats no longer clunk heads together when driving around, which was why I got the ADDCOs.
They also eat endlinks for breakfast, it seems... replacing another set tomorrow.
However, the panhard bar @jrm recommended is a better place to start than a stronger sway bar, I think.
Keros is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 06:10 PM #6
Update:
Upon inspection, the endlink itself was fine as were the bushings. However, the OEM endlink had actually wallowed out the hold in the sway bar and thus had become loose and mobile in the hole (even though the bolt was tight).
There's alot of force transmitted through the sway bar, so it's no surprise this happened. The shop cut off the (relatively new) OEM Toyota endlinks and replaced them with MOOG links, which do not appear to suffer the design flaws the Toyota endlinks did. I had them add grade 12.9 washers to protect the bar from being ripped up.
The MOOG endlinks have a much larger ball housing with a greaseable zerk fitting. The shaft is WAY bigger. And the bar-end bolt has a nut fitting cut into the ball side of the bolt to hold with a wrench while installing and removing the [much larger] nut.
Which endlinks to buy? atleast on purchase inspection, the MOOG is far superior to the Toyota. We'll see how they hold up to a heavy flogging up some mountain roads and through winters.
Old 07-10-2019, 12:03 PM #7
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
If you lifted the rear at the coils but did not extend the sway-bar end links it maybe causing more tension on the bar.
You can use 2nd gen 4runner end links. They are 1" longer, and on the cheap.
A couple other heavy duty versions to be had also.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 01:19 PM #8
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
You could just take the whole thing off, throw it in the trash and simply get stiffer rear springs. I'm not exactly sure why anyone wants a rear sway bar for off road. The entire point of going off road is to let the suspension articulate and the sway bar prevents this.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 03:29 PM #9
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
I Have broken mine as well. I now disconnect it every time I go off-road and reconnect when im doing pavement time. Eventually as DUFFDOG said, ill be getting stiffer springs and removing it all together.
I usually just disconnect the endlink from the body side on top.. remove the bushings fold the endlink down with the sway bar and let it move around.. ive done it several times.. and then easily reconnect it when im done.. DOesnt interfere with anything, under heavy flex it clanks a little bit on the lower links..
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 07-10-2019, 08:40 PM #10
this is the lift i used at the rear.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
so would try the option of using 2nd gen endlinks. am thinking of welding the broken sway bar and use it with the 2nd gen end links for a while, lemme see how it holds up
Old 07-11-2019, 12:20 PM #11
Rodtheviking's Avatar
Rodtheviking Rodtheviking is offline
Real Name: Chris
Rodtheviking will become famous soon enough
Real Name: Chris
https://www.amazon.com/Skyjacker-SBE.../dp/B00112G22Q
I went with these, nice and tight and sets the bar level with the ground like factory. You have to drill out the bar to 13mm for the bolt.
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
Rodtheviking is offline   Reply With QuoteReply With Quote
Old 07-11-2019, 03:16 PM #12
Mantilgh Mantilgh is offline
Mantilgh will become famous soon enough
Sorry, I don’t have any info that can help you, but was wondering how you like the Rancho Quick Lift and if you used their spacer in the rear or went with a different set up.
Mantilgh is offline   Reply With QuoteReply With Quote
Old 07-11-2019, 07:18 PM #13
THE ranchos are holding up ok, over 4yrs now and counting, changes the stance of the truck in a few minutes, nope for the rears, i used daystar spacer kit, see below
Old 07-15-2019, 01:14 PM #14
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
That Daystar looks like the same/identical rear 1.5" spacer as the Rancho branded one.
On car-part.com you can get that rear sway-bar for $75-$150.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 07-16-2019, 05:10 PM #15
Thank you.
Good to hear!
bar , bars , lift , rear , sway
Rear storage solutions that don't take up floor space? mc813 5th gen T4Rs 32 12-09-2019 06:42 PM
right rear shock keeps breaking spmarfatia 3rd gen T4Rs 10 10-02-2016 02:13 PM
Front sway bar removal and extended rear sway bar links. morphious 4th Gen T4Rs 25 11-29-2015 01:36 PM
Rear tire rub... solutions? Atrox Caeda 3rd gen T4Rs 1 08-15-2012 05:06 PM
front sway bar links keep breaking :( Jc12 3rd gen T4Rs 10 05-06-2012 04:08 PM
