Old 07-08-2019, 01:01 PM #1
spc54's Avatar
spc54 spc54 is offline
spc54 is on a distinguished road
spc54's Avatar
2006 4th Gen AC Question....
So looks as if I have the dreaded Evaporator Core problem, truck is a 2006 with 158k miles...
My question is, we have two other cars, live in FL. Will it make matters worse to just use a few cans of something such as
https://www.amazon.com/ZeroR-Z134-Re...s%2C168&sr=8-7
To just make it through the warmer months??? Or will it further damage the system?!
Thanks!
2006 4Runner Limited 4.7l V8 4x4
2014 Corvette 3LT Z51
2018 IS350 Fsport
FUTURE 2020 GX460
spc54 is offline   Reply With QuoteReply With Quote
Old 07-09-2019, 10:38 AM #2
what is the "dreaded evaporator core problem"? is it leaking? if its not leaking, adding more freon wont help anything, if it leaks & is low on freon then adding the correct amount will help temporarily untill it goes low again.
& that freon in the link is not 134a, its some new type that says is compatible with 134a... but you can buy the right 134a anywhere for $5/can or less. use the correct freon if its low, if its another problem you might want to have a professional look at it or repair whatever is wrong with the evap core.
Old 07-14-2019, 03:32 PM #3
Dscruggs Dscruggs is offline
Dscruggs is on a distinguished road
Personally I think you are ok. If you leak strictly 134a, you can refill basic 134a. DO NOT use the stuff with the "stop leak" ingredients. Once that stuff hits oxygen it turns hard causing more problems down the road.
Dscruggs is offline   Reply With QuoteReply With Quote
Old 07-14-2019, 03:41 PM #4
still curious what the "dreaded evaporator core problem" is ??
Old 07-14-2019, 04:08 PM #5
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
The evaporator is buried deep within the dash assembly, if it develops a leak the entire dash and everything behind it, electrical, AC duct work, dash reinforcement bar..EVERYTHING up to the firewall has to be removed to access the evaporator/heater core housing to replace the evaporator, very labor intensive and if not put back together correctly many issues can be had afterwards, hence the "Dreaded" description!
2004 Limited V8
Old 07-14-2019, 09:42 PM #6
BigMike18 BigMike18 is offline
Real Name: Mikey Barger
BigMike18 is on a distinguished road
Thanks!
What you want to do is put some UV Dye in there to see if there is a leak anywhere in the system using a black light to spot a leak because adding more refrigerant is practically useless
BigMike18 is offline   Reply With QuoteReply With Quote
make , matters , question , system , warmer
2006 V8 Timing Question ben550 4th Gen T4Rs 1 12-15-2014 02:51 PM
2006 Tow Question crazeazn 4th Gen T4Rs 5 07-05-2013 01:35 PM
One more question on the 2006 sport lasallen 4th Gen T4Rs 24 06-23-2006 01:28 PM
2006 4wd V6 question GRIMACE 4th Gen T4Rs 7 11-07-2005 01:52 PM
2006 NAV question LukeSKY 4th Gen T4Rs 11 10-19-2005 05:48 PM
