Old 07-08-2020, 09:46 PM #661
Tgore76 Tgore76 is offline
Tgore76 is on a distinguished road
Originally Posted by snowboardwcu View Post
Hey all! Just had mine done about 6 weeks ago. Headers shorties, ypipe, cats, exhaust. Did a whole new suspension at the same time. I can't even explain how much I love driving this truck now. Super responsive even with the AC on. Sounds incredible.
If I'm easy on the gas I saw an increase from like 15/16mpg to 18/19mpg. City driving and with my extra love of the gas I'm still around 15/16 but it was closer to 14 before. Definite gains.
Don't know how much difference the suspension work made. 3" lift between billys at 1.85" and FJ coils. Did all control arms and some other things, truck is level.
Running Faulken 275/70's and had a little rub on the JBA UCA so had to do spacers.
Rig is awesome is all I can say. Everything was pricey but I got a new truck! Highly recommend!
Which FJ springs? Moog? Did you replace front coils?
Tgore76 is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 12:39 PM #662
snowboardwcu snowboardwcu is offline
Real Name: George
snowboardwcu is on a distinguished road
Real Name: George
yeah they were the moog FJ springs. i dont have a lot of experience in different shock/spring setups but it seems to be a balanced pairing. the rear hops a bit from time to time (and it did before too so idk)
setup wise, iirc, bilstein 5100's all around on 1st setting, new moog springs all the way around, JBA uppers, OEM lowers (only fronts, i haven't done the rear arms yet), cornfed spacers & spyder spacers. everything is level and got 3" gain across the board.
most offroading i really do is outer banks every year on the beach. absolute unit there.
2005 V8 170k
Doug Thorley Shorties, Magnaflow Cats, Gibson Exhaust
Falken Wildpeak AT3 265/70-17
Gen5 Brake Upgrade
Transmission Fluid Coolant Line Replace
snowboardwcu is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 11:35 PM #663
Rannd's Avatar
Rannd Rannd is offline
Rannd is on a distinguished road
Rannd's Avatar
So I think I have a leak with my new headers. Has anyone had issues with gaskets or anything leaking on them?
2007 Toyota 4Runner Limited - My Build Thread
Rannd is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 11:55 PM #664
bbix333 bbix333 is offline
bbix333 is on a distinguished road
Did you use the included Doug Thorley gaskets or did you get new OEM? Did you retorque the header bolts after 200 miles?
bbix333 is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 10:21 PM #665
Rannd's Avatar
Rannd's Avatar
I had the shop use the gaskets included with them from Doug Thorley.
I haven’t taken it back to the shop but I am next week to have the AC fixed, I’ll ask them to retorque them.
Kinda wish I went with cats now, I can’t drive with the tailgate window down because it smells so bad haha
Old 08-11-2020, 10:55 AM #666
Rannd's Avatar
Rannd's Avatar
Shop re-torqued them and still sounds like a leak.
Also getting codes P0420 and P0430 even with the 90 degree mini cat eliminators. Checking engine light and other lights still showing up.
This has been one of the most frustrating modifications I've ever done.
Old 08-11-2020, 12:56 PM #667
awhitney1 awhitney1 is offline
awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about awhitney1 has a spectacular aura about
How can you tell you need your headers bolts need re-torqued?
awhitney1 is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 01:06 PM #668
How much did the shop charge to re-torque the bolts?
Old 08-11-2020, 03:45 PM #669
Rannd's Avatar
Rannd's Avatar
Nothing, I had it in there already for replacing the AC and heater core. My friend owns the shop and I trust they did it.
Would spraying water mixed with some soap on the headers show where the leak could be? When I'm in the truck with the windows down, it sounds like a leak.
Old 08-11-2020, 04:07 PM #670
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I was thinking of trying this with mine, with the headers cold, but they will warm up fast, and it might instantly evaporate.
I've noticed a tick with mine as well if the windows are rolled down, and I'm driving around houses or something to reflect the noise back. I'm pretty sure the ticking is a normal header thing but wanted to double check the header flanges weren't leaking.
I would think if they were actually leaking, then the noise would be terribly loud. I've started my truck with open headers before, and driven with a small-ish crack shortly after a header and it sounds like a completely different truck.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 08-11-2020, 04:15 PM #671
I've gone about 600 miles since installing the headers. With the windows down and accelerating, i'm hearing a little bit of a tick noise.
Old 09-17-2020, 03:18 PM #672
Just a reminder to remember to re-torque your header bolts after a few hundred miles. I just re-torqued mine recently and was surprised how loose they were! Got at least a couple turns re-torquing the header nuts and in the process, i noticed i'm missing two stud nuts. No wonder I was hearing a ticking noise. Luckily I was able to get ahold of Titanium Works and they were able to send me two replacement right away.
Old 03-11-2021, 09:36 PM #673
4Climber's Avatar
4Climber 4Climber is offline
Real Name: N/A
4Climber is on a distinguished road
4Climber's Avatar
Real Name: N/A
I have a set of 2003-04 Shorty Headers from this group buy + the Y pipe for sale.
If interested head to the post on the buy/sell section or this link.
Cheers,
4Climber is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 01:12 PM #674
bjornberg's Avatar
bjornberg bjornberg is offline
Real Name: Brent
bjornberg is on a distinguished road
bjornberg's Avatar
Real Name: Brent
Exhaust leak has come back getting worse over the last few weeks. Looks like it's happened to a few others. Gonna torque down the bolts first and hope it's not the gaskets. Anyone had to replace gaskets yet?
05 V8 Limited - Titanium Metallic - Build Thread
Gobi Stealth rack | King 2.5" Coilovers | Custom length 2.5" King rears | Insain Fab BMC | SPC UCAs | AIP bypass | SCS Ray 10s | BFG KO2s | RCI aluminum skids | RCI sliders | ARB Dual Compressor | ARB Diff breather | DT long tubes | Custom y-pipe | Gibson cat-back
bjornberg is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 06:12 PM #675
I had to get my bolts retorqued and had the gaskets replaced at the end of the y-pipe. Not sure how bad the gaskets were before hand, but after retorqing the headers stud bolts and gaskets at the end of the y-pipe, all was good
03-04 , 05-09 , buy , group , headers
05-09 4.7L Doug Thorley Headers, group buy Jason B 4th Gen T4Rs 346 04-16-2019 07:12 AM
Doug Thorley Headers w/ or w/o EGR? DavidAlexander 3rd gen T4Rs 8 07-13-2016 10:57 PM
