01-25-2016, 10:12 AM
Real Name: Jared Veillon
Driver side lean?
What's the easiest way to get rid of the driver side lean after installing my Daystar lift? It's not too bad but I notice it...
2007 4runner Limited 2wd, Daystar 2.5/1.5, 275/65R18 Cooper at3, blacked out headilights, LED interior and exterior, HID low beams and fogs, 20%tint, map light mod, fog light mod, DRL mod
01-25-2016, 10:57 AM
Real Name: Neil
Real Name: Neil
Many find the drivers side will have a lean "almost" always as the steering box, battery and gas tank are all on drivers side. I am adding a 5 mm trim spacer to the drivers front coil when I install my new suspension this weekend. To my limited knowledge there is not much you can do except deal with it or to add another trim spacer (I'm not sure this can be done with your spacer kit), replace your entire suspension with new (stock coils could be tired), or try to find a different spacer configuration for the front where the front drivers spacer ends up roughly 5mm taller than passenger.
Good luck....
1st was an 87, 2nd was a 95 and 4th gen is a 04 V8 Sport. OME 885/Toytec RCC2.0HD, SPC UCA's, RCI Sliders with top tread, Airlift 1000, and BFG ATKO2's - 265/70/17's. Tekonsha brake controller, EBay interior LED's, and Kenwood DDX 594 radio. Yakima roof rack for all seasons up top.
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
01-25-2016, 11:30 AM
Thank you sir, if it continues to get on my nerves I will try adding the spacer on the front or change the coils all together.
01-25-2016, 12:37 PM
After I installed my Daystar leveling kit, my 4Runner was leaning or sagging on the drivers side. I corrected it by installing a spacer on the right rear coil. Very easy install. Cornfed suspension will make a custom rear spacer for you depending on what size you need. The price was great, and it shipped out fast.
03-09* Toyota 4Runner Cornfed Suspension Lift kits
01-25-2016, 01:02 PM
Real Name: Danny
Real Name: Danny
Metal Tech springs. They have a driver specific spring so you don't need the spacer in the rear and they're only another 20 or 30 bucks over the Superflex. They also ride nicer.
01-25-2016, 02:36 PM
Thanks guys!
@ jason
do i have to disassemble the front strut to put the 3" spacer in or does it install on top of the strut assembly?
01-25-2016, 02:38 PM
Official Vendor
Official Vendor
Yes, you do. It's a split spacer design on the front. One above coilpack and one below. This is best way with least amount of stress. You can rent coil compressor from Advance or Autozone for like $20, and I think they refund you when you return them.
For 4Runner/SUV Accessories, please visit www.burtmanindustries.com
My 4Runner website
https://www.youtube.com/user/burtmanindustries, New YouTube channel! please subscribe and I'll make more videos!
[email protected]
DO NOT PM - text/call 717-319-2100 (24/7)
02-18-2017, 09:19 PM
I know this thread is old but Im just debating on getting a driver side rear spacer to correct the drivers side lean. I just had the toytec 3" lift installed and cant help but notice it sagging to the left. I don't have the tools necessary to do this install so I would need to take it back to the shop that did my lift.
My question is.. if I take it to the shop, are they going to understand what Im trying to accomplish or are they going to think its crazy to just put a spacer on one side?
'14 MGM 4R - Dobinsons C59-314 - Toytec Superflex - Bilstein 5100s - Cooper Discoverer ST Maxx - SCS SR8 - Front Runner Slimline II
02-19-2017, 08:19 PM
Also if you have XREAS you can keep the shock in with the bottom bolt without disconnecting xreas
Sent from my ZTE B2017G using Tapatalk
02-19-2017, 09:39 PM
I used Wheelers 1/4" spacer to get rid of that driver side lean, my truck sits level with it on. 22.5" on both left and right measurements after lift.
http://wheelersoffroad.com/product/t...ly-top-spacer/
07-29-2019, 09:09 PM
4Runner is lower on passenger side
My 4Runner was hit on the passenger side tire, my dad changed the lower control arm and went to get an alignment, the place where I took it wrote on the receipt needs 2 bottom lower control arms, needs smaller tires because it scrapes, last but not least the height needs to be lowered. So my 4Runner is lower on the passenger side I donÂ’t know why? Can someone help me out with this one. I donÂ’t know if the top control arm needs to be changed.
07-31-2019, 03:36 PM
Official Vendor
Official Vendor
I can fix you up with a custom passenger side spacer to fix that, call or text me 717-319-2100
Also, anyone else, if you don't know, our lift kit FIXES the driver side lean all these trucks have!
Burtman Industries
My 4Runner website
[email protected]
