Clunking from brakes. Not driveshaft?
I’ve had this happen. It is caused by a slight notch being worn in the front pad pins. When you press the pedal, the pads catch and then release as they pass over the notch in the pin - causing the clank sound as the pads make abrupt contact with the rotors.
Replace the pins (and the pad springs while you’re in there) and you’ll be good to go.
Edit: I would check the condition of the front caliper pistons, looking for any corrosion or anything that would restrict movement within the bore, as a slightly sticky piston can cause this same noise.
